Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
I have a Kenmore french door, bottom freezer model #596.76502500. It's approximately 4-5 yrs old. Within the past week it leaks water from underneath the bottom, approximately twice a day. My husband pulled the refrigerator out from the wall and checked behind it, he can see no evidence of a blockage. We have copper tubing so he doesn't think it would be broken tubing. We disabled the icecube maker and that has not solved the problem. There is also a thin coat of ice on the floor of the freezer drawer. We are thinking of shutting the unit down and letting the ice melt and then turning it back on, that perhaps that would clear up the problem--sort of like a reboot. What do you think?
  • kmvetter Sep 30, 2010
    I just talked to my husband and relayed your response. We are going to try your suggestion(s) tonight. I will get back to you with the results.
    Thank you.
    Kathy
  • 944 Answers
Hi ,
This problem could arise due to various reasons so lets find out what could it be the cause.
The defrost system controls the defrost heater inside the Refrigerators.Please test the defrost system.Use multimeter to test it.
1)In the back of your freezer compartment is the drain hole. It's very common in Kenmore for the drain to freeze up. With the drain hole plugged up, your freezer will continue to defrost the evaporator, but not the water in the drain hole. So the water builds and freezes, builds and freezes until it eventually overflows into the air diffuser for the fridge causing the leaky fridge problem.
2) If the water is coming from the freezer but you think that the defrost drain pipe is clear, then it may be coming from the ice maker. Check the ice maker for cracks in the unit's body or a misalignment of the water supply line. Make sure that the water supply spout in the freezer lines up with the ice maker's water supply cup.
3)Check the ice maker copper water supply line, your ice maker water filter, and the plastic ice maker water supply tube for any cracks, splits or connection leaks. If you find any leaks, remove the leaking part and obtain a replacement at the hardware store.
4)Your leaking refrigerator may just have a cracked or damaged drain pan. Your fridge regularly drains water into this pan to prevent water pooling in the fridge itself. Evaporation takes care of the rest. Look underneath your fridge where the drain pan sits and pull it out for inspection. If it has a crack or is otherwise damaged, contact the appropriate retailer about getting a replacement as soon as possible.
5)If your leaking refrigerator is draining inside as opposed to onto your floor, you're probably dealing with a clogged defrost drain. Your fridge is constantly producing condensation inside the freezer, and that condensation drips down the defrost drain into a drain pan underneath the unit. This defrost drain can become clogged with debris or, more often, it freezes shut. Look in your refrigerator manual to locate your defrost drain, and take the appropriate steps to unclog it (inundating your drain with warm water will often do the trick).
Note:Switch you Refrigerators for more than 24 hours and let the frost melt fully use hair dryer and now switch on and check you are getting leak.You will not get any leak
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 30, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 30, 2010
    Good thank you..All the best.
Water dispence slow
do you know if it is a whirlpool made model, 27ft french door, ice maker in ceiling, they had issues with a seal between ice compartment and ref side- leaks freezing air to water tank area, freezing tank. other wise if its not the filter -then water flow to unit. ck where it connects to ref, if good( should have steady stream with press. replace ref valve if bad look at your valve in wall or at sink.
Sep 14, 2012 | Kenmore Refrigerators
I have a Maytag model MFI2568AES french door bottom freezer refrigerator. I have had problems with the control panel not working. We have been able to get ice but could not switch to water. Now i cannot...
don't think you need a new unit . and most of use like the service . the filter does not prevent the ice maker from working . but the water valve does and the tempt in freezer must be 15 deg or lower . ck your fan inside and underneath. both muts be going . hope this helps mm .. and ck with another service theat will be helpfull. mm
Aug 01, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
Leaking everywhere
sounds like the door was sprung and is not sealing properly,check around door carefully for air leaks,miss handling causes this, did the same guys deliver the last one, just a thought
Jan 31, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Ice build up in freezer and temp in fridge section not very cold
just needs to be defrosted ice is blocking the vent for the bottom defrost it and should be good
Aug 28, 2009 | Samsung RF265AA Bottom Freezer French Door...
Kenmore elite bottom freezer icing up
if it has an ice maker fix or adjust the over flow for the ice try.
Jun 18, 2009 | Zanussi ZEBF250W Bottom Freezer...
Water leaking from bottom of LG french door freezer on bottom
yep, total defrost is the 1st thing to do. if you want to speed the process, see the following page how to do is good luck
May 27, 2009 | LG LRFD25850 Stainless Steel French Door...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
182 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
