Question about Philips Televison & Video
House took lighting strike and my LCD TV will not power up. Have TV apart and the fuse is good. Heat sinks are warming up and do not see any burnt spots or blown capacitors.
  • Philips Master
  • 8,457 Answers
All the ICS on the boards are dead.Replaced the power supply board,it dead.Be prepare to replaced the Tuner board too.50% it dead also.Tries websites like Shopjimmy.com,Ebay.com to buy refurbishes boards like the power supply board and the Tuner board.
Posted on Sep 30, 2010
  • s_nugent Sep 30, 2010
    It appears my power supply is built on to the board. Am I seeing that right? Will I need to replace the components seperately instead of the whole power supply?
  • Chi Chu Oct 02, 2010
    Lighting currents have massive power and statics electricity.All those ICS on the power supply board are dead.Those ICS are dead,the power board is useless,ICS control all the major functions around the board.Must replaced the whole power supply board,first,see what happen.Go from there.
My Pfaff 1471 lights up, but does not run. This model has no fuse. I checked the foot pedal with an ohm meter, & it sends a variable signal. My house took a direct lightning strike 2 weeks ago, &...
Were the base plate pugs into the power leads, you should read about 6-18 is ohms. Open and short is a bad transformer.
Also there are fuses, 2-3 right next to the transformer, small blueish and round are the shapes. They go bad often.
Sep 22, 2011 | PfaFF Sewing Machines
Have a Sony Bravia KDL-40v4100 Flat panel, had a bad storm, lightening strike in front of house, now the tv will not turn on.
Now tv turn on?Front LCD screen panel power light indication flashes or totally dead?Yes,than the power board is dead,that the board where power a/c cord plug into it.Take the tv aparts.That the power supply board,require changing.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 27, 2010 | Sony BRAVIA KDL-46V3000 Television
I had a near lighting strike that took out the cable and the tv
You have to check the DC voltages. First check across the high voltage electrolyte capacitor to know whether you are getting DC. Check the capacitor DC rating and you should get the the voltage less than the rating by 30% less.
If no DC present check the diodes or Diode bridge. If these are OK check the SMPS circuit components.
Jul 08, 2010 | Sanyo DP37647 37 in. LCD TV
Element FLX-3710 37" LCD tv will not turn on
power supply problem of course...set is not dead so line fuse would be good as you said...regulating power supplies are very stable but do contain >>>CAPs<<< caps can leak ,swell do to heat ,etc.
check for visible signs of damage to caps. on circuit board...check regulating transistor( on heat sink)
the >>> on off on off routine<<< makes me think check caps!!!!!
May 19, 2010 | Element Electronics FLX3711B 37 in. LCD TV
Lighting strikes
check inside /glass fuse/if not power supply might be damaged/uk ohm supplies and repairs
May 01, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a KP-46WT510 and have replaced both STK chips and 1 fuse on the power supply board. Under the heat sink there is another fuse burnt. The value of the fuse needed is 3.15 A. I put in a 3 A fuse and...
I have worked on about 5500 projectors in the past 10 years.
There is a dead short already somewhere so you cant blow anything else up if its a fast blow fuse.
Disconnect the Convergence Amp from the pwr sply then power it up for a few seconds with your 4amp fuse. Does the fuse still blow? If so, check the HOT transistor. (3 pin chip againts the largest heat sink)
Good luck
Dec 30, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Jan 14, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
Lightning affected Lcd tv
Panasonic 32"LCD Mod,TX32LXD70A
Jan 02, 2009 | Panasonic Televison & Video
TV won't turn on
Hello Marie,
I am sorry to hear about your situation. Most tv's do have an internal fuse, so if you open the chassis (which is the back part of the tv and slide it out and away from your circuit boards) the fuse will be located where the cord comes into the circuit board. Look for burnt or scorched spots on your circuit board also while you have the back off. I am sorry to say that most often than not in cases of lightning strikes the damage is expensive to repair and replacement of the devices is usually cheaper. Since the strike got a lot of your devices, it is not looking good. If you have further questions or need more assistance please let me know and I will be more than happy to help.
If you do not mind please rate my help, I would appreciate it. Thanks
Aug 13, 2008 | Polaroid 15'' HDTV Monitor FLM-1511
Lightning strike
This model is famous for capacitors being bad in the low voltage regulators on the signal board. Also has been known for cold solder connections in the power supply to the convergence IC. I don't have my notes at home but I belive that model only uses one IC for convergence, STK393-570. You cant see it from the back because of it being hidden by its heat sink.
Jun 23, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Televison & Video Logo
81 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
