Question about Gigabyte 3D Galaxy II CPU Water Cooling System GHWIU02 Water Cooling Kit
I bought my watercooling system about 6 months ago...now it just got a crack in the resivoir near the twist cap!!! do i send it in to be replaced or am i screwed with it?? plz help..its leaking :(
    Brigadier General:
  • 10,406 Answers
This question is a duplicate of:
http://www.fixya.com/postanswer.aspx?thid=6225637&prdid=924822&ctgid=28&ref=unsl
Posted on Sep 30, 2010
Car backfires
did it start to back fire right after you worked on it or after if be for you have some wires mixed up if after maybe a cracked distributor cap or bunt valve
Nov 26, 2015 | 1997 Dodge Grand Caravan
Steamy car window
I would not waste money on a radiator cap. The motor is shot ( probably a blown head gasket or cracked head) You probably will get weeks or until it blows up and the highway patrol puts you off the road with a hefty fine to boot.
Mar 29, 2014 | 1996 Ford Mustang
I have a 1994 Toyota Camry XLE 4 cylinder. its been having problems overheating so I was just putting antifreeze and water in it for about a month. I replaced the coolant sensor and the thermostat, still...
Sounds like a leaking head gasket. The head gasket can allow coolant to leak into the cylinders, and compression to leak into the cooling system.
May 20, 2013 | Cars & Trucks
Oil Level increasing without any oil being added.
Is it water cooled? Whats the colour of the oil? Black or more of a milky white colour?
If the colour of the oil is slightly creamish and it watercooled; it might be a top gasket thats blown
Feb 04, 2013 | 2011 Honda CBR250R
Heater is alternating hot and cold air, opened hood to check resivoir and its empty, fluid all aroud the tank of my 2002 ford taurus ses?
You need proper fluid level for consistant heat you may have a leak or crack in overflow bottle,Either replace it or find crack and epoxy it.Remember to run car with cap off for a little while while heat is on max to make sure all air is out of system. good luck
Dec 11, 2011 | 2002 Ford Taurus
I am putting new rear disc brake pads on a 94 Izuzu rodeo,I have to push the piston in to put new pads on. Should i remove the cap on the reservoir,if so which reservoir is for the rear brakes?
Yes loosen the cap so the fluid will be able to back up into the resivoir as you push the caliber back. There is only one master cylinder resivoir. It is the one mounted on the brake booster or near it. The small resivoir is for the clutch if you have a manual shift.
Mar 30, 2011 | 1989 Isuzu Pickup 2WD
My 98 MGM check engine light came on and II had it checked and it turned out to be the gas cap. I replaced the gas cap and all was well for about 6 weeks. then two days ago the check engine light came on...
emission problems are common, there is a evap canister underneath near the tank. also sensor built onto it. sometimes water get into there especially seeing the year they crack. its best to go to a tech who expeience with th evap system.
Sep 20, 2010 | 1998 Mercury Grand Marquis
No wate coming out the dispeser
The plastic water resivoir in the fridge compartment is frozen. Need to locate the resivoir which is at the bottom of the fridge and by using a hairdrier, warm the plastic resivoir for about 6 minuites. Suggest you turn the fridge off while doing this. retry and dispence water.
Jun 06, 2010 | Samsung 26.1 Cu. Ft. Side-by-Side...
Replaced motor, worked for a month now has a cracked head
the bottom hose came off,or broke thats where ur problem started, the engine over heated and only cracked head didnt seize the engine if u had stopped when the anti freeze or the temp light showed wouldnt have damaged engine, u wrote ran perfectly for month so enginge was good and in law installed correctly,problem was lower hose and not stopping vehicle before extensive damage was done
Dec 14, 2009 | 2005 Mazda 6
Smell of gas fumes underneath vehicle near fuel tank
I also have a 2004 XC90 and a couple of months ago I had the exact same probelm... after multiple visits to my dealer's auto shop they figured out that it was the fuel pump. They replaced the fule pump and the smell disappeared. Good luck!
Oct 14, 2008 | 2005 Volvo XC90
Gigabyte 3D Galaxy II CPU Water Cooling System GHWIU02 Water Cooling Kit Logo
248 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
