Question about Vacuums
I CANT FIND MY GAME BOY CHARGER!! - Vacuums
  • 490 Answers
Have you looked in the back seat of the car? in your bookbag? under your bed? behind or in the cushions of the couch? Your sister may have it. Or did you leave it at a friends house? You can get a cheap replacement at radio shack or walmart if you just can't find it. Farmerbear at FixYa.com
Posted on Sep 30, 2010
Won't hold a charge
this is a problem that all cordless power tools that have an internal battery in them face eventually , the battery goes bad and without tearing it apart you cant replace them
make sure its the battery went bad , verify that charger is working and charge lite is on
Jul 22, 2015 | Dirt Devil 9.6V Gator Hand Vac, BD10085
Can I buy a charger?
You need to get the make, model number and check online for local parts distributor or contact the Manufacturer direct. If you cant get one, check what voltage is on its input and output. There may be a specialist electronics store that has a "generic" charger which will work.
Jul 01, 2015 | Vacuums
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Hey my duracell CEF 23 battery charger has a detachable wall plug at the end, and what my question is what is the area after you disconnect the wall plug component for? i cant figure it out
It allows you to use other plugs besides US style two prong plugs, such as UK, or European or Australia type plugs. It's designed to use most any plug on the planet.
Aug 09, 2010 | Vacuums
Handle is loose and won't snap down and lock into position
This is usually caused by a build up of dust in the flexible pipe. It stops the pipe from compressing down and so you cant push the handle down far enough to get the latch to click home.
Try stretching the hose to its fullest extent and while someone has ut stretched, give the lengthe of the hose a good beating to knock the drit in it loose. Alternatively, if you can remove the hose, fill it (and boy will it expand and slosh about!) with a mixture of hot water and floor cleaner (I use flash) Slosh it about intil the hose is full of gunk, then pour it away. Then, put the hose in your airing cupboard (Stretched out!) overnight to dry. When you put it back together it should now compress enough for the latch to clich home.
Mar 01, 2009 | Euro-Pro NV31 Infinity Vacuum
Lost charger
You have to call electrolux and order one their numbner 800-896 9756
Jan 18, 2009 | Electrolux EL1000A2 Pronto Bagless Stick...
Replacement charger
I have a SV777R, cant find anything about this stupid product. Looks like I need a battery
Jan 17, 2008 | Euro-Pro Shark Cordless Stick Vacuum...
Vacuums Logo
23 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
