Question about SNK Blackmore Mobile Electronics Blackmore Mobile Blackmore In-dash Multimedia Player and Navigation GPS Units GPS Receiver
I have a new bdd-nav6 and the gps would not load and then the touchscreen stoped working. is there a way to reset it or to reinstall the software that runs it ??? all things work except the GPS and the touch screen
Touchscreen on a Garmin nuvi 1350 doesn't work
My touchscreen on Garmin nuvi 1390 not working too and .calibration it's help alsoI did twice hard reset my GPS Garmin Nuvi 1390 and nothing happening and after I tried different trick,when I turned GPS off I hold the top left corner screen.The screen exchange for calibrations and I pressed several times according request and my GPS Garmin Nuvi 1390 started work,but repairing company wanna charge me $100 Canadian dollars.I didn't connect GPS to computer
Mar 29, 2013 | Garmin nuvi GPS
2 months old noticing touchscreen won't respond all of the time. Is there a screen sensativity adjustment? Also sometimes it locks up on power up at loading maps. Thanks, Rick Jackson
unfortunately, there is no screen adjustment on your Gps. I would suggest you reset the unit,if that doesn't solve the problem, then you will have to update your garmin nuvi, I think its out of date and needs to be updated. Follow the procedures below on how to update your garmin nuvi:
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Also, in case you don't know how to reset your garmin nuvi, you can follow the steps below: There are two types of reset;
Performing a Standard Reset
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
2. Hold the switch in the position for at least eight seconds.
3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
1. Turn your Nuvi off by sliding the power switch to the left.
2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Good luck
Sep 25, 2010 | Garmin nuvi 1300 Car GPS Receiver
My Garman GPS touchscreen
Hardware issue and needs replaced. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Jun 16, 2010 | Garmin Nuvi 660 GPS Receiver
My tom tom Go 910 while updating crashed, it is turning on but iis not working i tried to reset same not working?
Check in your box that the unit came in, see if you have couple cd's. You are going to have to reinstall the original software before you can attempt the upgrade again. Original should be on the cd and should have the option to reinstall the software plus maps.
Hope this helps
Apr 26, 2010 | Tomtom Go 910 (Europe, USA and Canada...
Touch screen on my Garmin Nuvi 650 doesn't work
You may need a new touchscreen, but to make sure it is not a software problem, do this: The software on your gps system may be corrupted and unreadable. You will need to update it/re-install the software on it. To do that, you can download this software which will automatically search for the latest updates: http://www.tomtom.com/services/service.php?id=16&tab=87
If that does not work, you need to get the touchscreen to be replaced.
Oct 30, 2009 | Garmin nuvi 650 GPS Receiver
I have a Garmin Nuvi 680 and the touch screen stoped working.
The touchscreen needs to be replaced. Please see this link which explains why this happens:
- Jim
Oct 20, 2009 | Garmin Nuvi 680 GPS Receiver
660 touchscreen doesn't detect touching
Yes, the touchscreen is defective. Please see this link for more info on this probem:
- Jim
Oct 08, 2009 | Garmin Nuvi 660 GPS Receiver
Touchscreen not working
You may be able to go the TomTom website and download the last update programming. If the problem is software this should fix it.
Jun 22, 2009 | Tomtom ONE 3rd Edition GPS
Gps not working with tom tom nav 6
google for GPS TEST, instal the little program it will fix your problem. good luck
Apr 25, 2009 | HTC P3300 Smartphone
SNK Blackmore Mobile Electronics Blackmore Mobile Blackmore In-dash Multimedia Player and Navigation GPS Units GPS Receiver Logo
281 people viewed this question
Top SNK GPS Experts
Robert Struzinski
Are you a SNK GPS Expert? Answer questions, earn points and help others
