Question about Toshiba Regza 37HL17 37 in. LCD TV
I have Toshiba Regza 32wl68p LCD TV which would not turn up using either remote control or tv set on/off switch. TV stays with standby led showing red. Then after some time pressing side on/off switch it would light up. What is the problem?
5 Suggested Answers
djchillsnyc
  • 151 Answers
SOURCE: Toshiba Regza with red LED blinking
hello the red blinking lights is a service code when this happens it means theres a power problem or a fualty circut. it happens alot with these new plasma and lcd tv's its very common since these units have built in protection and power loss a fualt or short will cuase this.
the tv needs service the tech will know what to look for according to the number of blinks.
hope this helps.
Posted on Dec 18, 2008
budmrtn
  • 11361 Answers
SOURCE: LCD TV TYPE GOODMANS GTVL32W8HD STUCK IN STANDBY
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 27, 2010
electrotech1
  • 1126 Answers
SOURCE: my toshiba regza 32cv505d will
The first thing to check is the horizontal transistor by the fly back and see if it is shorted, It will be mounted on a metal heat sink. Your TV has lost the high voltage and that is why it is in shutdown mode. To have it repair if taken top a shop, you are looking at about 150 on repairs,
Posted on Feb 06, 2011
welcomejee
  • 10594 Answers
SOURCE: my toshiba regza model 32wl68p is difficult to
Please replace bad capacitors in power supply board or replace complete power supply board available HERE to solve tv problem.
Thanks.
Posted on Jun 09, 2011
My toshiba regza model 32wl68p is difficult to turn on from standby.Ihave to unplug in and retry numerous times before it turns on
Thanks.
Jun 09, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
TOSHIBA REGZA 24" LCD/TV cannot
"JUST PRESS CINEMA MODE ON YOUR REMOTE CONTROL AND SELECT APPROPRATE VIEWING MODE" it might be located under the left of 0 with an image like stretching as indicated on my remote. It is the issue about the overscanning and underscanning of tv using HDMI connection. I have been the same problem as you but I did solved it using this. Hope this would help!
Mar 10, 2011 | Toshiba REGZA 47HL167 TV
Recently I purchased Toshiba REGZA 47 XL 700 E is LED. Is this TV LED ?
Yes and NO your tv is a LED. To be exact it is a LED Backlight LCD TV. An LED-backlight LCD television is an LCD TV that uses LED backlighting instead of the CCFLs used in traditional LCD televisions. It is not a true LED display but is called "LED TV" by some manufacturers.[1] The use of LED backlighting has a dramatic impact, resulting in a thinner panel, less power consumption and heat dissipation, and a brighter display with better contrast levels. You can go to http://www.regza-asia.com/pdf/LEDTV/XL700/47XL700SPEC.pdf and look at the complete specs for your tv
Mar 07, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Am having the same problems. The TV is on standby (red light on front) but wont turn on from the remote or from the side of the set. This can last 1 or 2 days, then it works fine again for another week,...
There is a problem with the power switch board,there might be short in the IC Unit , you might have to change it. get it serviced by a TV electrician soon before the board gets damaged.
thanks for rating good luck
Feb 08, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
ZV55 toshiba TV
Bad capacitors on power supply board.
Apr 12, 2010 | Toshiba Regza 47ZV650 47 in. LCD TV
Toshiba Regza tv was in storage we took it out and can't find remote is there a way to tune without it? Thanks
Yes,must use the manual control on the tv itself.Very trouble some.Buy a new exact remote on website 1-800-Remotes Factory Original.
Jan 16, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
No Picture on Toshiba 42RV530U
I had a similar problem to this yesterday. Tv is same Toshiba model as you mentioned about 4 months old. In my case, after the TV working perfectly following installation, the standby LED on the front (the one that is red on standby and green when on) went to a flashing orange (after switching on from standby) and the picture disappeared although the sound remained OK. I was unable to get any response from the setup or menu on the remote, otherwise I would have tried resetting the TV. Regardless of how much switching off/on (including disconnecting the powerlead and leaving for few minutes), disconnecting all peripherals, etc., nothing helped. I looked up Toshiba's web site and under support they basically suggest switching off the TV and restarting using the onset buttons (not the remote) and pressing the menu button (again the one on the set (not the remote) and if you could get the menu box to appear then reset to default settings. I tried this but the results were the same. I therefore thought the TV was defective. However, after much frustration I did the following (I think): 1) Disconnect everything from the TV 2) Powered up from the mains switch whilst keeping BOTH the startup and menu buttons on the side of the TV pressed down. The result in my case was that the standby led and one of the two beside it flashed green simultaneously. However, when the buttons were released, the TV started up the same (flashing LED orange and sound no picture). 3) Pretty well defeated at this point, after doing the procedure at (2) several times with the same results, I somehow thought of pressing the standby button on the remote either whilst the two buttons on the set were depressed or just after they were released. I am afraid I cannot remember which and cannot replicate the problem as I don't know what caused it in the first place. 4) The TV then started normally ( no reception as I had not aerial connected, etc.,) but I was able to gain access to the screen menu/setup buttons via the remote which were in French rather than English. However, after reconnecting everyrthing the TV has worked fine (obviously after resetting the language via the menu). I am sorry I cannot be more precise but I hope this might be of help to someone with a similar problem.
Oct 04, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Remote control code for a Toshiba Regza 46'' LCD TV
0154 0156 0060 1256 0845 0832 1356 0650
Dec 21, 2008 | Televison & Video
Toshiba Regza 37HL17 37 in. LCD TV Logo
270 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
