Question about Lexmark X75 MF All-In-One InkJet Printer
Lexmark x75 printer/scanner
I was given a lexmark x75. i have plugged it in the outlet in the wall. it doesn't have an area for additional cable to be attched to it. so my problem is, there is power, the status light keeps blinking, and does this model hook up to the computor or not. what do i need to do?
    Scholar:
  • 187 Answers
This printer/scanner, hooks up to the computer via USB. The USB cable goes into the back of the printer on the right hand side (opposite side from the power supply). The status blinking could indicate either; 1. No paper 2. No or very little, ink.
Posted on May 25, 2008
My lexmark x7350 has stoped working. The lcd screen is very light colored like its not getting enough power. Please advise what to do as the printer has been a good one?
Please rebrick your printer. Pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
If that doesn't help, try to plug the printer into a different known working power outlet in the wall.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 23, 2011 | Lexmark X7350 All-In-One Printer
I cannot get my Lexmark 5600-6500 to turn on
Try to unplug the power adapter from the printer.
Then unplug the power cord from the power outlet. Wait at least 10 seconds before re-plugging the power cord into the power outlet in the wall (bypass any power strip) and the power adapter into the printer. This will give enough time for the printer to reset itself. If printer won't automatically turn on, press the power button. If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Jun 28, 2011 | Lexmark X5650 All-in-One InkJet Printer
Power to switch, will not come on, is there a reset button?
Try to unplug the power adapter from the printer. Disconnect the power cord from the power outlet in the wall.
Wait at least 10 seconds before you re-plug the power cord into the power outlet (bypass any power strips or surge devices). Re-plug the power adapter into the printer. If printer won't automatically power on, press the power button. If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Jun 27, 2011 | Lexmark X75 All-In-One InkJet Printer
Lexmark X75.........computer can read the scanner but not the printer
Please ensure that the Lexmark X75 printer driver is properly installed on your computer. You can download and install the X75 printer driver by visiting the Lexmark website at http://bit.ly/iSpJjv. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
Note: The Lexmark X75 printer is not compatible with Vista and Windows 7.
Jun 15, 2011 | Lexmark X75 All-In-One InkJet Printer
I have been given a lexmark x75, with no instructions how do i install this
It would be better if you install the software/driver first in your computer. The software also shows you the instructions on how to setup the printer itself. Here are the drivers available for download in the Lexmark website. Just click on the driver compatible with your computer's operating system.
- Lexmark X75 AIO Printer driver for Mac OS X, Mac OS X 10.1, Mac OS X 10.1.5, Mac OS X 10.2, Mac OS X 10.2.1, Mac OS X 10.2.8, Mac OS X 10.3.x, and Mac OS X 10.4.x.
- Custom Driver for Microsoft Windows 2000
- Driver for Microsoft Windows XP
These are the only available drivers. That means the printer is not compatible with Mac 10.5, Mac 10.6, Windows Vista and Windows 7.
For additional information, here's the Setup Sheet (Lexmark X74, X75) and the User's Guide (Lexmark X74, X75) . Hope this helps.
Apr 13, 2010 | Lexmark C533DN InkJet Printer
Lexmark x75 all in one. Started with communications device error. could not print. went through troubleshooting-still wouldn't print. started printing randomly(not initiated by me). Couldn't clear print...
Hi. That's quite a problem you have there. Have your attention first on the power supply. It does get hot but it's unusual if it gets very hot. Take out the power supply (the black box behind the printer where the power cord is attached). Check the power specifications. Most of the Lexmark power supply has input ranging from 120-240 Volts and an output of 30 Volts. Make sure you're plugging it in the right voltage range. Check if you're using power surge protectors or power strip, disconnect it and plug directly into a properly grounded wall outlet. Power surge protectors can also draw power away from the printer. When everything's well, try printing again. Hope this helps.
Mar 18, 2010 | Lexmark X75 All-In-One InkJet Printer
Lexmark X8350 does not turn on. Had it plugged in a CyberPower battery back-up. I unplugged it and then plugged it back in, even into another wall outlet to see if that was the problem. Green light is...
Try to refresh the status of the printer by taking out the cartridges, turn off the printer, REMOVE the AC adapter at the back of the printer, disconnect the power cable from the power outlet, disconnect also the USB cable. After 20 seconds, put it back all again and turn the printer on. If that doesn't do the trick and you are still having the same problem, you'll have to contact Lexmark for replacement (in warranty), or have it repaired by reputable repair establishment. Given it's sub-$90 price tag however, the repair will more than likely NOT be cost effective.
Aug 12, 2009 | Office Equipment & Supplies
Its a lexmark x75 scanner/printer. I can't find any printer/scanner icon's. It was hooked up and working 6 month's before it was given to me. it's a flattop scanner & the paper loads in the back. I...
Make sure You have  driver for it. Drivers are available on numerous sites for it. Any USB connection on the system unit should work with the installation.
Jun 06, 2009 | Lexmark X7500 MFP Flatbed Scanner
MY COMPUTER IS NOT RECOGNIZING MY LEXMARK X75 PRINTER
My lexmark x75 is not work with my window vista computer, could you please help
Mar 26, 2009 | Lexmark X75 All-In-One InkJet Printer
Lexmark x75 printer scanner
I am not sure if you need the X75 or X7500 so here are both of them.
X75 download
X7500 download
Jan 18, 2008 | Lexmark X7500 MFP Flatbed Scanner
Lexmark X75 MF All-In-One InkJet Printer Logo
99 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
