Question about Intex "" Metal Frame Pool Set (56998e) 56998e
Can't find my assembly instructions. Trying to disassemble. How do you get the plastic pins out?
    Problem Solver:
  • 19 Answers
On the back of the plastic pins is a bit that looks like a plastic washer but it is soft ruber if you take that off the pins will pop out it should work because i hve the same pool.
Posted on Sep 30, 2010
  • AmyP Sep 19, 2013
    I had tried that and it didn't work. I ended up having to tap a hammer on the bottom of the pin topop it throught the first whole. It worked great and thankfully none broke.
Loose power connection on motherboard of Satellite L640D-ST2N01
Toshiba Satellite laptops often have problems with their power connections becoming loose and losing contact between the positive pin on the DC power jack and the motherboard. Laptops are not designed to operate on the battery when the AC adapter is plugged into a viable power outlet. You will have to disassemble your Toshiba Satellite laptop to repair this problem. This task requires a thorough knowledge of laptop repair and safe soldering practices.
1. Disassemble your laptop according to the instructions for your specific Toshiba Satellite laptop model. Cut the plastic supports off the base assembly with a knife.
2. Cut off the plastic wall that encircles the mount opening with the knife. Extend the circumference of the hole by carving it open with the knife to make it wide enough for the new jack.
3. Bring the ends on the negative lead for the jack together and cover the ends with solder.
4. Remove the original DC power jack and trim the wires from the jack box with the knife, until they sit close to the edge of the jack box. Use the knife to strip the wires. Use your fingers to twist the wires together, and then coat the point where they meet with fresh solder. Locate the positive wire -- it is either red or green. Plug this wire into the positive lead on the new jack, and then find the negative black wire and attach it to the negative lead on the new jack.
5. Place the new power jack in the base, keeping enough extra space available for the plastic laptop cover and right speaker to fit back in later. Cover the negative and positive leads with the electrical tape, and then manually rotate the nut on the power jack clockwise until it will go no further.
6. Figure out which walls will stand in the way of the power jack after you secure the plastic laptop cover. Cut these walls out with the knife. Reverse the disassembling instructions you followed previously to put your laptop back together.
Dec 01, 2013 | Lifetime Toshiba Satellite L640DST2N01...
I have received two cables that need to be replaced on my machine (nautilus treadclimber 5000) one is the I/O cable 8 Pin 75", Rt. Upright and the other is I/O Cable 8 Pin 42" Upright MCB. How...
The first one, "I/O cable 8 Pin 75", Rt. Upright", runs inside the right side upright tube from the handlebar to the base of the machine. The machine will have to be partially disassembled using the original assembly instructions in reverse to access this cable.
The second cable, "I/O Cable 8 Pin 42" Upright MCB", runs from the base of the right side upright back to the Motor Control Board. If you tip the machine carefully onto it's left side with the side plastics removed you can see this cable.
Jul 16, 2011 | Bowflex TC1000 Treadclimber
I have a Stanley SharpShooter PHT150 that's jammed. I would like a diagram/instruction sheet showing how to fix this problem. Thanks.
Here is a copy of the instruction manual for your stapler.
1. Press end clip in, then up.
2. Pull out spring assembly.
3. Load staples into channel.
4. Reinsert spring assembly and
snap end clip into place.
EASILY DISASSEMBLED
FOR CLEANING:
1. Squeeze stapling end of hammer
tacker together, taking care to
avoid sharp staple.
2. Remove locking pin.
3. Press end clip in, then up.
4. Pull out spring assembly.
5. Remove staple channel.
6.Clear and reassemble
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 16, 2011 | Stanley Tools Hammer Staple/Tacker -...
Trying to remove Peerless P99196 but don't know how to depress the plastic tabs to disassemble
OK, since you're going to need "the rest of the story..." to get this faucet un-installed without breaking anything.
Here's a copy of the manufacturer's installation instructions, which, if you read in reverse order - provides the disassembly instuctions!
http://www.peerlessfaucet.com/media/Product_Tech_Docs/Maint_Installation/50001to80000/59238RevB_10a3f.pdf
It even has pictures, which will really help since we all forget about the one screw (that's fastened from underneath the sink in the middle of the faucet assembly) which holds it onto sink.
Don't forget - only licensed plumbers are allowed to display their "plumbers crack" while working, (all others have to keep it covered!)
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
99 olds culass headlight bulb replacement
Look at the top of the headlight assembly. There is a plastic panel on top of the assembly that is held in place by two plastic pins. Remove those pins by lifting the center of the pin and then pull out the pin. Remove the panel. Then you will find two small plastic levers that will lift about 1/2 inch. They do not come out but they will release two studs that secure the assembly. After the assembly is released, slide it forward to access the bulbs you need to replace. Installation is the reverse of these procedures.
Feb 25, 2009 | 1999 Oldsmobile Cutlass
Spin brush removal
Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
follows:
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
Oct 19, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Intex "" Metal Frame Pool Set (56998e) 56998e Logo
690 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
