Question about Compaq Evo N1020V Notebook
Doesn't boot up
The prob is; does not boot all,
Light comes on
no boot
then turns itself off within 10- 20 sec...
I would like any advice on how to remedy this problem,
as I have had modem repair success in the past,
ready to take it on, appreciate any advice
Thanks ahead,
jc
ram 1G
pent 3
2.4
  • chippyme May 10, 2009
    have tried ram, hdd runs externally in caddy,
    Scholar:
  • 187 Answers
First thing to do is check your RAM. If there is more than one RAM chip, remove one of the chips, and try booting. This will allow you to rule out a RAM issue.
Posted on May 25, 2008
Hello fixya experts i'm having problems with my computer When i press the power button the light around it lights up but it doesn't make the 'beep' sound it's supposed to i felt...
In most of the cases i have found this kind of problem occurs due to the faulty RAM, You can try with new RAM or if you are using two RAM with 1GB each than you can try booting PC with single RAM one by one This way you can know the faulty RAM.
All the Best
Jul 08, 2011 | Computers & Internet
The SRS light will go off. Tell how to turn it off.
Hi, you cannot turn it off rather you have to reset it by following the instruction below...
  1. Turn ignition switch off, remove service connector cover.
  2. Connect (jump) the MES (Memory Erase Signal) connector (this is 2 pin connector wrapped on yellow plugged in the front of the under dash fuse box).
  3. Turn ignition switch on.
  4. SRS light will come on for 6 secs then go out, remove the jumper within 4 secs after the light goes out..
  5. The SRS light will come on again, reconnect the jumper within 4 secs after the light has come on.
  6. The SRS light will go off, remove the jumper with in 4 secs after the light has gone off.
  7. The SRS light will blink 2 times indicating the memory is reset.
  8. Turn the ignition switch to off and wait for 10 seconds.
May 25, 2011 | 1994 Honda Civic
I have a new key cut and the security comes on. What can I do?
If your old key has a chip in it,then the dealer ship will have to code it.If not,try relearning the key to the ignition,turn the key on,leave it on 10 minutes,then turn it off,and right back on,do this three times,a total of thirty minutes,if this was at all helpful,please rate,thank you.
Aug 21, 2010 | 2000 Chevrolet Venture
Gps won power up when car charger burn frm fuse
Unfortunately it sounds like when the car charger went bad it also did in the board on your tt. It would be cheaper to just purchase another unit than to get this one repaired out of warranty. My advice would be to sell it on ebay. People buy these all the time for spare parts.
Hope this helps
May 09, 2009 | Tomtom GPS
Tower problems
You may need to replace the cmos battery, its a cr2032 3v button cell
Make sure all your expansion cards and memory are reseated.
Make sure all cables are reseated.
your power supply could be bad
If that doesn't work try this
Here is my fix for the dell dimension 4400 amber light problem. It works!
replace cmos battery.
then unplug power cord form wall about 5-10 secs.
then plug it back in, wait 5 secs.
If amber light comes on, press and hold power button until it goes out.
(with light out, press and hold power button while amber light comes on and goes off again holding power button 2-3 secs after light goes out.) repeat whats in parenthesis until computer turns on
it should only take about 6, 7 tries.
After the computer boots, you may want to setup cmos or boot into windows.
After you shutdown, unplug power cord for 5-10 secs then plug it back in.
Press and hold the power button, computer should come on.
I found that's the only way to turn on the computer.
If you shutdown and don't unplug power cord the computer may not boot, mine didn't.
Strange I'd say
A+ Technician
Apr 01, 2009 | HP Computers & Internet
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
EVO ! wont boot
If the RAM is fine, but it's turning itself off after 10 seconds or so, then it's highly likely the motherboard needs replaced. What I would suggest, if you are comfortable doing it however, is to check the fan isn't simply clogged up (this will determine whether it is a problem with the motherboard itself, or simply a problem with the fan overheating, and the motherboard turning off as a fail-safe). Bear in mind, this will require stripping the laptop down, and should only be done if you can put it back together properly.
May 26, 2008 | Compaq Evo N1020V Notebook
Computers & Internet Logo
118 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
