Question about Kodak EasyShare DX7440 Digital Camera
My DX 7440 'broke' somehow and I cannot turn it on. The round selector switch on the back is stuck on 'off' and will not turn to any position. I love the camera but it is now completely useless. Any suggestions other than sending it away for (an expensive) repair?
  • 38 Answers
Remove the screws on the front cover and gently take it apart. Look on the selector for some broken plastic parts and remove them.With patience and attention you may succeed and save a lot of money.
Posted on Sep 30, 2010
Why wont my 2001 ford windstar blow out of vents ? only on defrost?
Air Flow Control
Air flow control is accomplished in the following manner:
  • Primary control is through the function selector knob , mounted on the heater function selector switch, which is part of the heater control .
  • The function selector knob has the following positions: OFF, PANEL, PANEL/FLOOR, FLOOR, FLOOR/DEFROST and DEFROST.
  • The heater function selector switch combines a vacuum selector valve with an internal electrical switch.
  • The vacuum selector valve directs source vacuum to various vacuum control motors (18A318) . Refer to the System Airflow Schematic and Vacuum Control Charts.
  • An internal single-pole electrical switch is also controlled by the selector. The switch controls the electrical supply to the heater blower motor switch (18578) .
  • The position of the function selector knob determines the manner in which the system will operate.
  • Each position of the function selector knob is detented for positive engagement.
  • You probably have a vacuum leak , Pull heater control panel an check for vacuum . A broke vacuum hose or The vacuum selector valve is bad ! Or check for a vacuum hose in the engine compartment being off somewhere !
Mar 08, 2015 | 2001 Ford Windstar
How do I stop calculator from rounding up?
Hi Carol,
There are switches at the top just under the screen called the "Rounding Switch" and the "Decimal Point Selector Switch".
With the rounding switch you can select rounding up or down, but you may also want to use the second switch to show more digits after the decimal. Put it in the "F" position to show all decimal places. When it is in the 0, 1, 2 positions, it strips off and round the numbers.
Here is the link to the manual as well, look at the section detailing the "Decimal Point Selector Switch".
(You will need an Adobe Acrobat Reader to look at the manual.)
Hope this will help you. http://downloads.canon.com/cpr/software/calculator/P23-DHV-(USA-HWB).pdf
Nov 15, 2014 | Canon P23-DHV Calculator
Gear got stuck in nuetral, and in park position in the dashboard and the vehicle won't move--this is my problem on my 2003 trailblazer suv.
It may be the gear selector switch on the tranny where the linkage bolts on its a odd shaped plastic peace you can see if its broke or loose.
Jun 26, 2011 | 2003 Chevrolet TrailBlazer
My calculator is rounding to nearest whole number. How do I fix this?
You should move the rounding switch on your calculator. It has three options: an up arrow on the left side (for rounding up) a 5/4 sign in the middle (for rounding off) and a down arrow on the right side (for rounding down). borbalint.png
You may also have to move the decimal point selector switch to set the decimal point position.
Mar 15, 2011 | Canon P23-DHV Calculator
Ignition cylinder stuck in on position. how do you change it if it won't move?
if your shift selector cable broke/came loose, the vehicle will still think you are in gear and will not allow you to lock the column and remove the key. easiest way to see the cable is to remove the instrument cluster and look behind the orange "PNRD21" indicator.
Feb 21, 2010 | 1995-1997 Chevy Tahoe Ignition Starter...
It powers off immediately when I turn it on
Hi
Thanks for using FixYa. From what you have described it seems the fault is in the voltage selector rotary switch, it’s the round voltage selector switch not the other one, because you'll notice that there are 2 voltage selector switches at the back. The lock might be broken so you couldn't switch the primary terminals of the main transformer. In other words this amp has 2 power transformers, the small standby transformer and the large main transformer. Try to press that round switch and press the front panel power switch. If it goes ON, then fix the center lock of that round switch. If not then you might have to replace the switch.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 16, 2010 | Pioneer VSX-D508
Loooking for Parts for kodak dx 7440
bought a used non-workjing dx 7440 camera for cheap on ebay and just took mine apart and replaced the rear housing assembly. the solution to the parts problem was googling it and finding some ebay matches that were hard to find on ebay's site itself ...
Jan 27, 2009 | Kodak EasyShare DX7440 Digital Camera
Ballacolla kodak dx 7440 joystik not working properly
Let me see if can come up with something. As you probably well know, there are many tiny parts that are involved and opening up a camera without a service manual is not always a good idea...
Sep 28, 2008 | Cameras
Broken lock switch zune Pink
My zune lock switch completely broke off in the locked position. I used a paper clip to remove the small plastic tray under where the switch use to be. It came off pretty easily. Then I could see a small black toggle switch can I was able to flick it in the unlock position.
Jun 17, 2008 | Microsoft Zune JS8-00001 Digital Media...
Brush doesnt turn
Hi.
If you have all floors type ensure the clutch drive selector knob on bottom front left is in drive position when handle is pulled back.
http://dysonmanuals.llc.nu/
Chris
Dec 24, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Kodak EasyShare DX7440 Digital Camera Logo
70 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
