Question about Samsung SyncMaster 740N 17" LCD Monitor
A vertical line appears across the screen - Samsung SyncMaster 740N 17" LCD Monitor
  • 33 Answers
That is LCD problem. you need to replace lcd panel to fix that problem.
Posted on Oct 02, 2010
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Vertical line down screen
This problem can be caused by a lose connection between LCD and motherboard, however you can check it by opening the LCD or hinge bezel to ensure if there isn't any lose connection.
Oct 28, 2013 | Dell Vostro Computers & Internet
White vertical lines across the screen. Why and what can be done? Thw white lines appear and stay all the way across the screen. They are about 1.5" inbetween each vertical line,
You have a failure in the vertical circuit. Service can run between $75 to $150 depending on your area.(In home repair will cost more) If set is older then 3 years and under 27" recommend replacing it.
May 06, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Lines across my tv where the picture is reversed
You have bad capacitors in the vertical deflection. And you will have to resolder the vertical IC as well. Replace the caps in the area of the vertical IC. Find a TV tech or hobbiest to do this!
Apr 14, 2010 | iLO IWT3206 TV
JVC AV-27730: horizontal bright line across screen in the
it could be an electrolytic capacitor or the vertical output I.C. in the vertical circuitry,if you remove the rear cover tap on the board in different places and see if the picture fills out or atleast jitters like it might fill out,then it could be just a cold solder joint,then remove the main board and resolder all joints and this should repair the condition you have
Nov 18, 2009 | JVC AV-27730 27" TV
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
Jul 01, 2009 | Televison & Video
Line across middle of screen.
The line of color is due to a failure in the vertical circuit. The main suspects are the vertical Ic AN15525A and/or capacitor c308 220uf@35volts
If you have the capacity to do so, you should check the other electrolytic capacitors in the vertical circuit which are USUALLY located near the vertical IC in most cases
you can purchase the part at
https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=5760279&smodel=CT32SL15N
or mcm electronics
Mar 13, 2009 | Panasonic CT-32SL15 32" TV
Vertical lines across the screen
Change ballast and lamp at same time. Ballast #75006507 lamp #23311153
Sep 11, 2007 | Toshiba 46HM95 46" HDTV
Samsung SyncMaster 740N 17" LCD Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
