Question about Amana Refrigerators
Refrigerator portion has quit working but freezer still works.
    President:
  • 834 Answers
The problem is most likely either the defrost timer, and/or the defrost heater element(s) are faulty. The problem is that the defrost heater elements are not functioning properly and the evaporator core is actually freezing up and blocking the air flow through the evaporator core and also freezing up the thermal sensor, and when that happens there is no longer enough cold air being circulated through the refrigerator (that is actually how the unit operates and air must be able to flow through the evaporator core and then be circulated throughout the refrigerator to properly function) and as a result the refrigerator stops functioning and food can even thaw out in the freezer although the freezer seems to be iced up. (Usually at the rear wall where the evaporator core is located)
(Air flow through the evaporator core and cold air circulation and re-circulation through the refrigerator is performed by the air circulation fan and it also must be functioning)
Be sure to only use a blow dryer (with a towel on the bottom of the freezer) to thaw out the evaporator core and do not use any hard or sharp objects or the evaporator core can be damaged. The defrost timer can be located inside of the refrigerator itself, (see lower image) or it can be mounted outside usually either behind the air intake cowl or kick panel at the front base of the refrigerator, or most likely located behind the service panel on the rear of the refrigerator, and usually if the defrost timer is turning then it is most likely working, however the defrost timer can move very slowly and you can place a mark on the timer and the housing to check after about fifteen minutes to see if the position on the defrost timer has changed. The deforst timer on newer digital models can be built into the circuit board and is not a seperate timer mechanism.
Here are some images that should be similar to your situation to help assist you, and let me know if you require any further assistance.
2f9008a.jpgRefrigerator portion has quit working - 8c8c7f8.jpgbr /> 8c8c7f8.jpg
Posted on Sep 30, 2010
  • Zaraki Sep 30, 2010
    The rest of the images.
lojacksdad
  • 121 Answers
SOURCE: Fridge quit working but freezer works
check to see if the back wall of the fridge is full of ice
if so that is an automatic defrost problem or check to see if your frezzer fan is blowing
Posted on Apr 17, 2009
SOURCE: The refrigerator portion has quit cooling.
I have the same problem and have found that if you take the panel off inside the refrigerator and with a blow dryer defrost it. It should work for a few weeks. I have been doing this once a month since March and I hope to found out how to fix it also.
Posted on May 18, 2009
  • 10865 Answers
SOURCE: I have a Dometic RM 2652, the freezer works fine.
Here is the trouble shooting manual for your Dometic.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
It will tell you what the possible problem is.
Posted on Jun 04, 2009
freetek
  • 5568 Answers
SOURCE: Freezer is cooling but the refrigerator is not cold
This setup uses a fan to push air around to distribute the cold air. It sounds as if your fan isn't running anymore.
It may not be a lot of fun to access it for replacement or lubrication which might be the problem. This type of fan motor normally uses a phosphor-bronze bearing with graphite embedded and while they shouldn't ever need oil, this type of bearing has tendency to get sticky over time eventually jamming the motor shaft.
Modern motors are 'impedence protected' so they don't 'burn up' anymore but do get hot.
What you might try is to check Sears parts section to see if your model is listed for replacement parts (they sell parts for about every US brand) and they may have an illustration of your fridge that shows you how you can access the fan.
Posted on Jul 15, 2009
SOURCE: My Kenmore refrigerator is not
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Posted on Jan 08, 2011
Electrolux refrigerator not cooling
Is your freezer side working fine? If it is, and it is just the refrigerator portion of your appliance, then I would check the damper switch/door that is between the doors. The freezer actually sends its cool air into the refrigerator portion to help cool it.
Aug 20, 2012 | Electrolux EI26SS55GS Stainless Steel ...
The freezer portion works, the fan and light in refrigerator section works but Fridge does not get cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 25, 2011 | Amana ARB2257CSR Bottom Freezer...
Refrigerator is not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 25, 2010 | Frigidaire FRS26R4A Side by Side...
Amana 25 Cu. ft. French door Freezer Fridge quit
IN MOST CASES THERE IS A FAN THAT SENDS COLD AIR FROM THE FREEZER TO KEEP THE FRIDGE COLD. EITHER YOUR FAN MOTOR HAS GONE BAD OR YOUR THERMOSTAT IN YOUR FRIDGE IS BAD.
Feb 20, 2010 | Televison & Video
Freezer portion doesn't freeze.
check settings. if good check if compresor is running. a relay on compresor could fail
Feb 10, 2010 | Maytag Admiral Top-Freezer Refrigerator
Help! In 2006 I purchased a used RV with a dometic model 2408 refrigerator that did not work. After reading up on Absorption refrigerators and repair facilities I had it rebuilt by RV Mobile in Everett,...
The evaporator coil is usually located in the freezer compartment, and there are ducts with dampers that send cool air to the refrigerator. It sounds to me like that may be your problem. It seems that if you move the appliance around a little, (cleaning it and the like), then for a short period you start to get a semblance of cooling. Hope this helps
Sep 10, 2009 | Refrigerators
May 17, 2009 | Samsung 26 Cu. Ft. Side-by-Side...
Refrigerators Logo
100 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
