Question about Mitsubishi WD62628 62" Projection HDTV
Wd62628 after you plug tv in it will flash for about 70 sec. then when you turn set on set will power up, get a blue screen for about 20 sec. then will turn off, like being unpluged, then start blinking another 70 times.
  • 5 more comments
  • rontv311 Sep 30, 2010
    lamp is almost new, there is no sound or pix., no menu,or on screen. all caps look ok. ron311
    set shuts off as if you unpluged it. which means error code is reset to 12 ( no error ) its like some one unpluged set.
    It does it by itself. its like it was unpluged but it was not unpluged it just resets itself. all by itself. rontv311
    Yes I have a service manual for this set. will check all output volts. thanks rontv311
    standby 18 v reads 17.89 v +15 v reads 17.84 v - 15 v reads 18.28 v. at power up 5 v 3.3 v 12 v are there. ballast volts 320 volts. rontv311
    sorry about that the -15v reads -18v i forgot the - sign. rontv311
    I don't have another set to swap parts from. will order engine power board. thank you rontv311
  • 10,594 Answers
When did you replaced lamp in tv last time?
If lamp has not been replaced in last 2-3 years then its time to get it replaced as weak lamp, that has reached to end of working life, can cause that symptoms in tv.
Let me know if you have additional question.
Thanks.
Posted on Sep 30, 2010
  • 5 more comments
  • Shahid Electronics
    Shahid Electronics Sep 30, 2010
    Please check any light flashing in tv as shown in below table.
    Let me know your findings, then we will perform error code check.
    Do not unplug tv, let it shut off on its own then preform error code check to read it out.
    Unplugging will reset that error code.
    OK, it sounds power supply board issue as standby power supply is not providing sufficient volts to system control section and it does not boot up properly.
    Check standby volts output in power supply board with multimeter.
    Do you have service manual copy of this model?
    OK, check power supply output volts please
    -15 v reads 18.28 v
    If that is correct then check why it is +18V instead of -15V
    OK, last option is to swap boards in ok tv to find out what board is causing problem. I suspect interface board that drives light engine.
Power Surge
charlie the proble has something to do with the tv guide here is a response from an older post Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was. Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Aug 05, 2012 | Pioneer PDP-6010FD 60 in. Plasma HDTV
Reen turned wite with power only v8.03.6
From the remote select menu and reset the settings to factory default. It might become alright. Else, switch off TV manually, switch off power, remove plug and retry after 48 hours.
Aug 01, 2012 | LG 42LE5400 42 in. LCD TV
When I push the device button on the remote, I
I had this same exact problem with my WD-62627. I got mine to work by re-initialing the tv. I could not believe this worked. Try this, 1) turn on the TV
2) press MENU 2,4,7,0 then ENTER
3) the TV should INITIALIZE
4) Press the front reset button on the front of the TV.
5) should work again....if so.....
6) email me at Larry1965@hotmail.com to thank me. :)
Dec 30, 2009 | Mitsubishi WD62628 62" Projection HDTV
Flashing Power light
Ur power board ic inverter is dead.
U need a new board.
Aug 19, 2009 | Toshiba 57H84 57" Rear Projection...
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
Flashing
I have the same problem- however, a simple solution is to unplug the power, wait for about 20 secs, and plug it back in, and the screen will turn on... You may also take the screen and tilt it backwards until it turns on....
Aug 10, 2008 | LG Flatron L1715S 17" LCD Monitor
System won't power up
ITS BROKE - YOU HAVE TO GET IT FIXED OR THROW IT OUT. SAME THING HAPPENED TO US -UNDER WARRANTY BUT WE HAVE TO PAY THE $80 TO SHIP IT TO THEM. WHAT A FARSE.
Aug 04, 2008 | Olevia LT42HVi 42 in. LCD Television
Sony Bravia KDL 52 keeps turning itself OFF
i had prob where my sony would switch off for a few secs thenh come back on . The solution was in menu / tv settings / sleep timer . Go into that and make sure its set to off. there are opions for off , 5 min 20 min 30 min etc... mine was set to nothing just blank.
Apr 06, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
BLUE POWER LIGHT
Jan 26, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Mitsubishi WD62628 62" Projection HDTV Logo
315 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
