Question about Refrigerators
My refrigerator is beening eight time the control box on the door is warm
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 30, 2010
The freezer freezes but the fridge is barely cool at best
Good Morning Friend,
I understand that the freezer is freezing but the refrigerator is barely cooling on your Frigidaire refrigerator, model# BFPH31M6LM. I suggest checking the following:
    1)Check to make sure the temperature control is not set too warm. Try turning the control to a colder setting. Allow 24 hours for the temperature to stabilize.
    2)The door is opened too frequently or too long. Warm air is entering your refrigerator causing it to run more. Try opening the door less often.
    3)The door may not be seated properly. Check to make sure that your refrigerator is level. This can cause the door to not close properly. Also, check the seal on the door and make sure that it has not been compromised in any way.
    4)Try not to put large amounts of hot or warm food in at one time. This can cause your appliance to be warm inside for several hours, until the food has cooled off.
    5)Make sure your refrigerator has not been disconnected. It will take your appliance at least 4 hours to cool down completely after power has been restored.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your microwave status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
May 30, 2014 | Frigidaire 3.1 Cu. Ft. Compact...
My refrigerator and freezer are warm. Everything is warm and melting but the refrigerator is running i have a frigidaire commercial upright freezer modelffu20fc6aw4. The fan works and the kight shut off...
bring all the controls to zero..unplug the unit for 10 minutes..plug it back in..and then bring the controls up to full range..it is equivalent to having an engine that is flooded..if this is not working to resolve this, then the compressor or the capacitor on it, are shot.
Oct 15, 2008 | Refrigerators
Have a kenmore refrigerator freezer works but not refrigerator
You mean "How to Fix a Kenmore Refrigerator That Is Not Cold But the Freezer Is Good?"
Well this what i say,
Kenmore combination refrigerator and freezers combine the short- and long-term food storage options in a single unit. There are some occasions when the refrigerator compartment might appear to be malfunctioning while the freezer box stays cool. Ruling out these occasions ensures you have done everything you can to correct the problem before calling for a technician if necessary.
1.Verify that the temperature controls for the refrigerator compartment are properly configured. Tap the "^" or "v" buttons beside the refrigerator's LCD temperature display until "38," the ideal temperature, appears. The compartment could have been set too warm. Allow 24 hours for the the appliance to reach 38 degrees Fahrenheit.
2 Check that the refrigerator compartment door closes completely, objects inside the appliance could be holding the door ajar. When cool air is allowed to escape, the internal temperature rises. Cracked, holed or corroded door seals may also raise the refrigerator temperature.
3 Change how you use the refrigerator compartment; storing hot or warm food strains the appliance and causes a rise in internal temperatures. Do not prop open the door or leave it ajar for more than a few seconds at a time for the reasons outlined in Step 2.
4 Contact Kenmore if the refrigerator compartment remains too warm for your food. There may be a problem with the motor or any one of the other parts that regulate the temperature
If this was helpfu.l please let me know.
Thanks for using FixYa
Sep 06, 2011 | Kenmore Top Freezer Refrigerator
GE Profile, Side by Side model # PSCF5RGXAFBB. Al of a sudden, both Refrigerator and Freezer sides started warming. Checked power supply. Appliance lights are on and the the House Circuit breaker is...
I also have the PSCF5RGXAFBB, it quit working completely. Mother Board and Evap fan replaced 2 times. Had 5 appointments with repairman. They finally decided it was a Sealed System Leak - covered by warranty.
Feb 03, 2011 | Refrigerators
Side of refrigerator getting really hot from top to bottom on freezer side about 1 inch from the door back. Also where the two doors meet in the middle, really hot. What can I do?
The unit has a auto defrost feature. Every six to eight hours these heaters come on to melt ice build up.The cabinet will feel warm to the touch during this cycle.If it is always hot, I suspect a stuck defrost thermostat
Nov 14, 2009 | Samsung RS2630SH Side by Side Refrigerator
GE g2220iephww Refrigerator too warm at top, too cold at bottom.
If you are manually defrosting by turning the refrigerator off or unplugging to defrost, then you've got one of the following -
1) Defrost heater has failed
2) Defrost sensor has failed
3) Defrost timer/refrigerator control has failed.
As ice builds on the evaporator, if not defrosted properly, the accumulated ice restricts airflow through the evaporator, which reduces air flow and air velocities through the box. Lower velocity allows the cold air to fall to the bottom of the box, warmer air to the top of the box.
Dec 26, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
