Question about Coleman Heating & Cooling
Pilot light goes out when burner stops.I have change therm.couple & gas value
  • Coleman Master
  • 2,519 Answers
Try cleaning pilot or changing pilot injector , see if pilot is too small,
Posted on Oct 01, 2010
The pilot light does not remain on when the button is released. While holding the button in and turning on the water no ignition happens. Gas cylinder is full. Please assist. Thanks! Mark
Your gas valve works in conjunction with a therm o electric valve it is a 2 stage operation. 1 is when you push it in and light the pilot. 2 is when you release the button. This prevents full gas to the burner and prevents ignition taking place if the pilot light fails. The thermo-couple provides a small electric current around 30ma which holds the therm o electric valve open and in turn keeps the pilot light on. The thermo-couple needs to be replaced, if it still cuts out then ths therm o electric valve which is a n integral part of the gas valve has failed and a replacement gas valve would be needed.
May 06, 2015 | Water Water Heaters
Pilot will not stay lit. Which part should be replaced? Where purchase parts?
Dose the heater have a free standing pilot? Meaning you turn the gas valve knob to pilot position and push down and light the pilot. If so then there is a therm o coupling sticking up when the flame hits it for a min or two and this is what sends a signal back to the gas valve letting it know that a pilot flame is present. If the therm o coupler is bad it will not let the pilot stay lit. also see where the other end of the therm o coupler screws into the gas valve back it out and clean the end up and install it back. Now if it is electronic pilot and the pilot fires and then goes out there is a rod that is in line whit the pilot acts the same as a therm o coupler replace it. if you send me the Model number and make of unit i will be able to help you better.
Mar 06, 2015 | Heating & Cooling
Desa heater
For (fire) safety, there is usually a thermostat that will turn off the gas if pilot light goes out.
So when you try to light the pilot you will have keep press & hold the pilot gas supply for at least 10 sec until the thermostat is heated up. Then only when the pilot light stays on continually, can you turn on the burner.
Forget about changing to a High pressure regulator!
Dec 24, 2013 | Heating & Cooling
Fireplace burner won't stay on
try cleaning the pilot sounds like its a short pilot and when the burner comes on it pulls the gas from the pilot light .
Feb 22, 2013 | Heating & Cooling
Pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Sep 20, 2011 | Heating & Cooling
I have a Kenmore Power Miser 12 gas water heater that the pilot light keeps going out. The water heater has been in service for 45 months. The pilot light has a blue flame with some orange flame flares...
check and or replace the thermal coupling. the coupling goes into the main gas control, if the coupling is bad it will shut off gas supply. as a safety measure.
Mar 09, 2011 | Water Heaters
Enviro temp hot water heater. 1 week ago pilot out. Able to relight but would go out again once water heated to temp. Replaced thermal couple (tc) with same result. replaced gas therm/valve (t/v). ...
Remove your entire pilot assembly from the heater and gas valve. Remove the aluminum gas line that feeds the pilot assembly. There is a small orifice inside the pilot assembly that may or may not fall out when you take the line off. If it does not fall out remove it and be sure that the very small holes in the top of it are clear. It sounds to me like even though the flame is blue and in contact with the thermo-couple, when the main flame turns off it causes the pilot flame to wave away from the thermo-couple thus shutting it down due to a weak pilot. I have run into this several times and should do the trick.
Feb 02, 2011 | Water Heaters
I have a Rheem Power Vent propane water heater model3 21VP4OE-1P that is acting up. The pilot lights and then the burner lights, but goes off after 5 - 10 seconds. It cycles like this 2 or 3 times, then...
check the thermal coupling for the pilot light. if it goes out it will shut down gas supply, its a safety feature to put out pilot light if the thermal coupling is bad. to prevent gas from leaking and causeing a fire. check coupling.
Aug 12, 2010 | Water Heaters
Wall Heater
If you have already changed out the thermocouple and the pilot goes out when the burner goes out, it leads to reason that the gas valve has a weak magnet or that the pilot is dirty. The cheapest thing would be to remove the pilot assembly and clean out the orifice. If it still drops out, you will need to replace the gas valve.
Nov 02, 2009 | Heating & Cooling
Pilot will lite but goes out as soon as i let button go. could it be the thermal coupling?
could be first check that therm/coupl is in correct position and that flame is in contact also check that therm/coupl is not dirty carbon on surface also some times it may take therm/coupl a little longer to heat up hold pilot a little longer if no good and still goes out replace therm/coupl
Oct 21, 2009 | Rheem Water Heaters
Heating & Cooling Logo
35 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
