Question about Kenmore Dryers
The drum all of a sudden started making making grinding noises, took out several dollars of change and other stuff, now drum will will not turn, belt seems fine, heat fine
  • Kenmore Master
  • 17,129 Answers
Make sure with a manual movement of the hand that the drum is rotating and the motor is free.
now when the drum was struck did it cause any errrors in the motor orr the control board or a fuse tobeblown.
so checkthis out if the drumis free and the motor is not getting supply from the control board.
Check the safetydoor switch to latch for the unit to work, check if any wires were pulled off while you repaired the drain to cleanup.
Posted on Sep 30, 2010
My frigidaire fer231cas2 makes a horrible loud GRINDING noise after its been running for 10 or so mins
Hello friend, thank you for your post!
I see that you have changed multiple parts within your Frigidaire dryer due to a grinding noise. Since you have changed the bearing cup, felt, pulley, and belt I would recommend having a technician come out to diagnose your appliance to avoid any further unnecessary part purchases. You could be seeing an issue within the drum or motor. I hope this information is helpful. -Matt
Aug 26, 2014 | Frigidaire Dryers
Loud grinding noise within the engine and stalling after braking hard
Flex plate is cracked. That is another reason it stalls.
Nov 08, 2011 | 1996 Eagle Vision
Dryer making a grinding noise when turned on. How do you get the top off to check the barrel motor?
Clanging Sound
1. If the noise coming from your dryer can be described as a clanging sound, the solution is probably well within your grasp. This common sound is typically the result of loose debris accidentally put in with the load of laundry. Change may be left in pockets of pants or other objects may be dropped in the laundry basket by children --- perhaps a toy car. The objects may not be noticed when put into the wash, and the water in the washer may have dampened the sound. Simply remove these items, and restart the dryer to resolve the issue.
Sometimes the clanging is from snaps or buttons that are actually part of the clothing. If you are drying a jacket with metal snaps or another garment with metal attached, you should expect this clanging sound as they tumble and strike the inside of the dryer tub.
Humming or Whistling
2. Many Roper dryer models are equipped with a safety feature known as a lint signal, which is usually a light that often accompanies a warning signal, telling the machine owner that the lint trap has become clogged. When the dryer cannot pull adequate air through the lint filter, it can overheat and become a fire hazard. The warning alarm may sound like a hum or whistle to get your attention. Look at the lint signal light, clean out the trap and the noise should stop.
Thumping or Grinding
3. If the noise you are hearing can be described as a thumping sound or a metal grinding sound, the device that turns the dryer drum, known as the drum rollers or glides, can be worn out. As the drum turns, there may be a constant and rhythmic thump each time the drum rotates. A severely worn or broken roller could cause the metal of the drum to rub against the metal housing of the machine, causing a louder grinding noise. The rollers will need to be replaced to remedy the problem.
Squeaking or Squealing
4. Most dryers work by using belts to turn the rollers, which in turn make the drum rotate and tumble the clothes dry. When these belts get loose, a worn belt or a malfunctioning tensioner spring may keep the belt tight. In either case, belt slippage may occur and will produce a squeaking or squealing sound that is easily recognized. The problem is likely to be the tension on the belt since most belts will break before wearing out to this degree.
Feb 24, 2011 | Whirlpool Dryers
Dryer suddenly started making a loud banging sound like a washer out of balance. The drum still turns. I have disassembled the dryer and the belt looks ok and the rollers seem ok. It was very sudden onset....
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 24, 2011 | Dryers
LG dryer was making a squealing noise, then suddenly started making a loud noise like gravel was being rolled around in the drum. Could this be a broken belt?
heatman101
dfhjdg
Aug 03, 2010 | LG DLE5955 Dryer
Dryer is making a grinding noise when the drum turns
hi your belt is ready to give up take does it smell of burning if not it soon will take the name make and model to comet they will sort you another and they are very easy to replace you just open the back of your dryer make sure it is unpluged first take the old one off and just slide the new one straight on problem sorted
Apr 26, 2010 | Maytag SDG3606A Gas Dryer
Dryer drum does not turn - only by hand?
Try this link, the first one the maytag one has the actual instructions, all dryers a pretty similar you just have to route the belt according to the diagram!! Good luck,, ps a good rating would be nice! thanks
http://fixitnow.com/wp/2004/08/19/appliance-repair-revelation-how-does-that-dryer-belt-go-back-on/
May 10, 2009 | Dryers
OKI C5100 Making grinding noises
Click the following link, it should solve your problem
http://www.fixya.com/support/t238726-sensor_error
Regards Wayne
Aug 05, 2008 | OKI C5100n Laser Printer
Dryers Logo
90 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
