Question about HP LaserJet 4350 Printer
Have a hp laserjet 4350 network printer and have select print on both sides check on the printer preferences and in the finisher tabs. but still doesnt not print on both sides.
  • 1,110 Answers
This would have to be a 4350DN or DTN model to do automatic duplexing. I would make sure you have one of these 2 models. Depending on what driver was loaded the duplex option may show up, but if the printer does not have the duplex option and the associated firmware then it will not duplex automatically.
This is the only thing I have seen that would cause what you are describing.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Sep 30, 2010
I am trying to set the printer to automatic duplexing...?
Hi
If you want to set Print on Both Sides (duplex) as the default setting for all print jobs (even single page jobs) use the following steps.
  1. Click Start , Printers or Printers and Faxes from the Microsoft Windows desktop.
  2. Right-click the HP Color LaserJet 2605dn_2605dtn and select Printing Preferences (Properties in Microsoft Windows 2000).
  3. Click the Finishing tab.
  4. Select Print on Both Sides under the Document Options section.
  5. Click OK to save the setting and close the Printing Preferences window.
  6. Close the Printers or Printers and Faxes folder.
Note:In this scenario, all print jobs, even single print jobs, will be treated as Print on Both Sizes (automatic duplexing) for media that is supported by the duplexing unit. For media that is not supported by the duplexing unit, the job will be treated as Print on Both Sides (Manually) (manual duplex).
Jun 13, 2011 | HP LaserJet P4014n Printer
Laptop running XP desires to connect to desktop running windows 7-driver needed for HP 2840 color laserjet before connection to windows 7 desktop-is driver put on laptop or desktop
There is no driver for win 7, although if you are running on windows 7 32bit there is a work around. Download the software for windows vista 32 bit for the 2840.
Jul 13, 2010 | HP LaserJet 2840 All-In-One Printer
Hp lj m4345mfp printer showing 13.31.00 fuser output paper late jam i am replace the fuser assy but problem is same
If you are using Windows:
  1. Click on Start => Settings => Printers and Faxes
  2. Locate your printer's name and right click on it and click "Printing Preferences"
  3. Under the "Main" (General tab in some other printer models) Tab, and under "Paper Options" group, select the settings for "Paper Type" Paper Size"
  4. Click "Apply" and the click OK.
Your values here will be the default values loaded when you click the print command in any programs in your computer.
Feb 09, 2010 | HP LaserJet 4350 Printer
I want my hp laserjet 1320 to print front and back
Make sure the manula paper feed slot is closed.
Access Printer Properties or Printing Preferences
Select the Finishing Tab
Select OK
Then print the document(s)
Nov 10, 2009 | HP LaserJet 1320 Printer
How do I print double-sided automatically? HP Color LaserJet 2605
Go into the control panel, select the printer, select printing preferences, select finishing, put a checkmark in box where it says "print both sides"
Oct 09, 2009 | HP LaserJet 2605DTN Color Printer
Whenever i change paper size from A4 to letter,
Don't set by using the "Print" option.
Go to [Start]
[Printers and Faxes]
right-click on the HP printer entry
! Don't select "Printing Preferences"! from there
Select [properties]
Select [Advanced] tab
Select [Printing Defaults]
[Advanced}
(I know, the screen looks the same, but it functions differently this way)
Change paper size to "Letter"
[OK, OK, OK]
*done*
Sep 25, 2009 | HP LaserJet 4350 Printer
4350d prints 2 pages for every 1 page received
Your Printer Preferances is probably set to 2... solution is
Go into Control Panel > Printers > right click on the 4350 and choose Properties.
Look for Printing Preferances button near the bottom and click it.
Choose the Advanced tab and make sure Copy Count is set to 1
Sep 23, 2009 | HP LaserJet 4350 Printer
HP Laserjet 2015n printer
Sir, the Hp LaserJet 2015n printer CANNOT automatically do duplex printing since the printer does not include mechanism and paper storage areas to cycle the paper through the printer a second time and print on the reverse side. Manual duplex printing can be done as follows: Choose duplex printing and remove all sheets after the printing is complete. Turn the sheets over while preserving the orientation and insert them in the paper feed path. I have an HP 1020 laserjet printer which is similar to the 2015.
Aug 22, 2009 | HP LaserJet P2015n Printer
How to print 2 sides on hp laser jet 9050
start
settings
printers&faxs
open printer properties
tick mark print on both sides
Nov 28, 2008 | HP Computers & Internet
HP LaserJet 4350 Printer Logo
186 people viewed this question
Seeker5211
Seeker5211
