Washer fills and washes but won't drain to continue on with rinse cyce
  • 5,081 Answers
Please give your brand and model number of your washer
Posted on Sep 30, 2010
  • INDIRA KUMAR
    INDIRA KUMAR Sep 30, 2010
    These are usually symptoms of a failed lid switch. The following link explains how to replace the lid switch step-by-step:
    http://www.fixya.com/support/r385199-rep...
    Open and close the lid and listen for a distinctive "clicking" noise.
    The lid switch should activate as the lid closes. If you do not hear
    the switch, chances are the switch has come loose, the lid strike (small
    plastoic piece on the washer lid on some models) has broken off, or the
    switch itself is broken. Please post back with your model number and I
    can confirm how your washer is configured. I hope this helps you.
    PS This repair should only cost you about $25 to $35 if you decide to do
    it yourself. Also, you do not have to drain the wash tub to repair the
    switch. Once the problem is corrected, the tub will drain on its own.
    This will save you the effort of having to bail water out of the tub.
    COURTESY:JS ROCK- A SENIOR EXPERT IN FIXYA
Machine won't run on wash and rinse but motor will start and drain the water out
What you hear is the drain pump, remove back panel to see the problem
Mar 31, 2013 | Haier XQJ50-31 Top Load Washer
Washer will fill and drain but won't wash and rinse
Check for a modular unit in the machine that controls the wash action of the machine. If it has malfuctioned there will be no power for the motor. Check with the spares departtment if your machine has this unit
Mar 02, 2013 | Haier HLP21E Top Load Washer
Washer will not advance in the rinse cycle,water just runs continuely.
check the drain hose it should be only 6 to 8 inch in your drain line if drain hose is all the way in the drain line correct it and you will be fine.
May 21, 2009 | Washing Machines
Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
