Question about Yamaha CDC-675 5-Disc CD Changer
I have a cdc 675 CD changer, When I close the draw it stays close about 10 seconds, the display reads "open" and it opens back up whether there are discs in it or not
    Brigadier General:
  • 10,406 Answers
It's reporting that it (correctly or incorrectly) detected that the drawer has not fully "closed", i.e., it thinks that there was a "jam" while the drawer was sliding towards the "closed" position.
This sounds (pun intended) like you need to take the unit to a qualified audio/video technician, to trouble-shoot, and maybe check the "alignment" of the drive-tray.
Posted on Sep 30, 2010
Why does my yahama cdc-505 cd changer not play cd, or change tracks
This is a result of the deck kicking out you disc as an unacceptable media. This usually means that it can not read the data on the disc or the necessary TOC (Table of Contents).
The other possibility is that your draw in detection switch has gone bad and when the processor- control type, tries to load a tray or close the drawer it is not getting the door closed signal. Depending on how the unit is programmed it might just sit there and do nothing or in your case throw the disc back out.
It is kind of telling you it wants to go see a Technician.
It could also be a bad belt that loads the Pickup assembly- it might be good enough to move the drawer in and out but the Pickup assembly needs more torque and it might not be there.
Dec 13, 2012 | Yamaha CDC-505 5-Disc CD Changer
Need drawer belt for Yamaha CDC-805 CD changer - the one needed that opens and closes the changer's door - not sure where to get it or the part number. I thought I ordered the right one and got the 'drive'...
Any decent repair shop should have a large supply of replacement belts. The Part number isn't necessary. Just take the old one in and get a new one just 2mm smaller than the original. Some repair shops won;t sell them because they don't want you repairing your own property but a decent shop should sell you one.
Apr 07, 2010 | Yamaha CDC-745 5-Disc CD Changer
The disc tray of my Yamaha cdc-745 CD player does open properly.
It's the belt inside the machine - open tray and look in front left side and you will see it. Easy to change out with new one.
Dec 13, 2009 | Yamaha CDC-745 5-Disc CD Changer
Blaupunkt CD Changer CDC-A08 - Cartridge eject problem
I am waiting for a reply from the Authorised Blaupunkt Service Agent for a solution to this problem &
shall let you know when it is solved. As per my telcon with him it is an alignment problem of the
Cartridge carrier, but he will have to look at the Unit later, when he is free.
Mar 22, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
Disc door keeps opening.
The drawer belt may also lift the laser up to meet the CD . If the belt is bad , the CD player will kick out the CD.
Change the belt.
Try studiosoundelectronics.com
or
mcmelectronics.com
Jan 11, 2009 | Yamaha CDC-585 5-Disc CD Changer
Cd Tray
Hi Fred..
I've done about 100 CD transports so far.
Try changing any belts in the unit. On some CD players ,if the open/close belt is bad, it wont allow the CD to be read either.
Also,VERY lightly cleaning the laser lens and dusting the unit out helps too.
Dec 28, 2008 | Yamaha CDC-845 5-Disc CD Changer
Won't stay closed
even if the laser lense cant process the data being read it should not eject and just display disc error or no disc. That's how it normally does. anyway if is is different from yours, try cleaning the laser lense with cotton bud, dampen a bit with rubbing alcohol, then the other end to dry it. rub it in circular motion please and not too hard or excesiove force on it.
lubricate the spindle motor shaft if you can reach, not too much oil, the very thin type household use only. likewise the traverse mech. the mech is not the source of your problem but since you are lubricating the spindle motor then you might as well lubricate the rest of moving parts. try not to put oil in you platine table and other rotating parts like the rubber belts or you'll find another problem later.
Reden
Dec 12, 2007 | Yamaha CDC-502 5-Disc CD Changer
The CD changer is locked and won't move
Open the player. (Undo the screws) take off the cover and nudge the tray gently take a look around and see if the white plastic gears are locked up. A little gentle prodding should loosen it up. Barring that call Yamaha!
Feb 25, 2007 | Yamaha CDC-675 5-Disc CD Changer
Yamaha CDC-675 5-Disc CD Changer Logo
198 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
