Question about Sanyo PLC XU35 Multimedia Projector
When you press the power button the projector light is green for a moment and making a sound as if it is turned on but no screen appears then after a few seconds the red light comes on. The lamp replacment light does not come on so I'm not sure what the problem is. Can you help?
  • 10,594 Answers
I hope our talented expert would have given you helpful and correct info in chat session from related service manual, feel free to ask further help if required.
Thanks.
Posted on Sep 30, 2010
2 Suggested Answers
leethedeuce
  • 4472 Answers
SOURCE: Lamp will not turn on.
It sounds like an internal problem. How long have you owned the projector? How long have you been experiencing this issue? Once I have more information I can assist you further.
Thanks,
Lee
Posted on Sep 23, 2008
Sanyo pro xtrax projector
Lamp LED should be lit when the projector is in Standby. However, the problem you are describing sounds like one of two issues. Either the lamp is bad and needs replaced, or there is a power supply fault. If you have tried replacing the lamp already, make sure you reset the lamp counter or the projector may still not function properly.
does the temp warning light come on when the projector shuts off? if so you may also try cleaning the air vent filters and ensure there is proper air flow around the projector. if that checks out then have the projector serviced as the power supply is likely suspect.
Dec 09, 2013 | Sanyo Office Equipment & Supplies
I plugged in my xd490u [mitsubishi] data projector...and then power turned red, status turned green for few some seconds. later power blinked [red + green] and did not work. can anyone tell me what the...
It sounds like your lamp may need replacing. Before you go that route try all of these:
-Make sure the lamp cover on the bottom is fully attached. -If you unplug the power cord while the fan is rotating, the lamp may not turn on about 1 minute when you plug the power cord next time. After the status indicator stops blinking press the power button to turn it back on. May have to press it multiple times. -If your Power Light continues to blink red/green then you should contact your dealer.
Sorry I couldn't be more helpful.
Feb 28, 2011 | Mitsubishi XD490U Multimedia Projector
I my projector is new one used for 4 hrs, when i try to turn it on it just has a blinking green light. Please help Solve It! .
The blinking green light means the unit is either Powering On (Warming Up) or Powering Off (Cooling Down).
Powering On the Projector
1. Remove the lens cap.
2. Securely connect the power cord and signal cable. When connected, the ON/STANDBY LED will turn Amber.
3. Turn on the lamp by pressing " " button either on the top of the projector or on the remote. The ON/STANDBY LED will now turn Green. The startup screen will display in approximately 10 seconds. The first time you use the projector, you can select your preferred language from quick menu after the startup screen displays.
4. Turn on and connect the source that you want to display on the screen (computer, notebook, video player, etc). The projector will detect the source automatically. If not, push menu button and go to "SETUP". Make sure that the "Source Lock" has been set to "Off". If you connect multiple sources at the same time, press the "SOURCE" button on the control panel or direct source keys on the remote control to switch between inputs.
If you are still unable to get the unit to turn on, try unplugging it for 10 minutes and plugging it back in. If it still ceases to work, contact Optoma here: http://www.optomausa.com/rma_policy.asp
Their Technical Support line is 1-888-887-5001
Feb 25, 2011 | Optoma HD20 DLP Projector
Projector screen displaying "Searching" message. Does not recognize computer. Worked with one of your associates (Guru?) and we tried a number of solutions but none worked. She asked that I come back to...
If you are connecting to a laptop then you may need to hold the function button down and press F1, F2, F3 etc. there should be a sign with the latop on there and a sign with an external device (monitor,PROJECOR)
hope this information was useful to you.
Jan 21, 2010 | InFocus Office Equipment & Supplies
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Dell 2300mp
Replacing the lamp module requires special considerations:
  1. Turn off the projector.
  2. Wait 30 minutes for the projector to cool down and then unplug it.
  3. On the bottom of the projector, loosen the two screws on the lamp cover and then remove the cover.
  4. Loosen the two screws on the lamp module and pull out the module.
  5. Insert the new lamp module and tighten the two screws.
  6. Install the cover and tighten the two screws.
  7. Turn on the projector. If the lamp does not turn on after the warm-up period, try reinstalling the lamp again.
  8. Press enter on the projector or on the remote control to open the on-screen menu.
  9. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Setup and then press the right (c00589412.gif ) arrow.
  10. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Reset lamp hours and then press enter .
Jun 18, 2008 | Dell 2300MP Multimedia Projector
Green light flashing and then shuts down
Hi Gary
Have you resetted the lamp timer ? It must be done when a new lamp is inserted into the unit.
You can reset the lamp timer by holding the up arrow key on the Projector in until a online message appears. Then just follow the on-screen instructions.
If the problem persists , you will have to replace the Ballast wich is the lamp's power supply.
Mar 16, 2008 | BenQ MP610 Multimedia Projector
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
DELL 2300 MP NOT TURNING ON
Have the same problem here. Have two of these units. Took the bulb out of the one that had the Lamp light on, and put it in the other projector. The other projector worked perfectly. I have three bulbs, they all work in the one projector, they all cause Lamp Light in the other one. The manual states nothing about hard resetting the unit. Also note that, the fans do not power up instantly on power on, they come on about 5 seconds after pressing the power button.
Aug 30, 2007 | Dell 2300MP Replacement Projector Lamp -...
Sanyo PLC XU35 Multimedia Projector Logo
116 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
