Question about Canon PIXMA iP90 Mobile Printer
Printer goes through the motions like it's printing, I don't get any error messages, you can see the ink cartridges moving back and forth, it pulls paper in and acts like it's printing, but the page comes out blank...suggestions?
    Scholar:
  • 78 Answers
Remove the cartridges and press the end with the ink sponges onto a paper towel. If you see ink on the towel, insert the cartridges and run the cleaning 3-7 times. This will use up some ink, but is the only way to resolve this issue. If you continue to see improvement in the prints, continue to clean until quality is acceptable.
Posted on Sep 30, 2010
  • lisa581 Sep 30, 2010
    Thanks! How do you run the cleaning???
  • hughestech Sep 30, 2010
    This is assuming you run windows. Locate the printer in the printers folder. Right click and select properties. At the bottom of that window, select preferences. Look on each of the tabs at the top. The tab may say "Maintainence", but if not, just look through the tabs until you find "cleaning". Run this feature and follow any directions it gives you.
Epson printer error codes
The error code E-90 appears when the print head is not able to move back and forth freely.
If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
  1. Turn off the printer
  2. Lift up the scanner.
  3. Press down on the ink cartridge cover to make sure it is completely closed.
  4. Close the scanner and turn the printer back on.
- or, If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
  2. Lift up the scanner to access the printer area.
  3. Remove the tape from the ink cartridge holder.
  4. Close the scanner.
  5. Turn the printer back on
epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-0.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-2.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-5.jpg
Sep 01, 2014 | Epson Stylus DX6050 All-In-One InkJet...
Alarm message says "cartridge jammed". Does that
What you see moving is the print carriage. The carriage moves the cartridge, adjacent to the printhead, back and forth.
Although the carriage is moving, the ink cartridge can not dispense ink because an obstruction is
blocking the path of the ink.
Remove the ink cartridges, inspect the cartridges as well as the cartridge holders for any foreign debris and reinstall.
If the alarm message continues, I suggest changing the ink cartridges.
Feb 17, 2011 | Canon MultiPASS F50 All-In-One InkJet...
The sgreen says general error, see your printer documentation for information about clearing the error.......of course I can't find the manual
Everything you need; manuals, drivers and interactive guide can be found here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=26322&infoType=Overview
Below are two possible soultions for a General Error:
1. When a General error message appears in the display on your printer's control panel, the print head may not be able to move because of some obstruction. Follow these steps:
  1. Turn the printer off.
  2. Open the printer's cover.
  3. Gently remove any jammed paper or other obstructions from the paper path.
  4. Close the cover and turn the printer back on.
alert_note.gif Note: If you can't remove the paper or foreign object yourself, do not use force and do not disassemble the printer.
2. When a General error message appears in the display on your printer's control panel, the print head may not be able to move back and forth freely.
If your printer's ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps:
Turn off the printer.
  1. Open the printer's cover.
  2. Press the ink cartridge cover to make sure it is completely closed.
  3. Close the cover and turn the printer back on.
Before considering other options you might to try unplugging the printer from the power supply; give it 5 - 10 minutes before plugging back in and restarting.
Hopefully this will help resolve the problem. :)
Dec 09, 2010 | Epson Stylus Photo R300 InkJet Printer
All 8 new ink cartridges, new MT tank, nothing prints. it goes thru the motions of rinting, but no little to no ink is on paper, less and less ink each subsequent print. Most recent print has a hint of...
take your ink cartridge out from your printer. you can see at the ink carriage there are little pipes where the ink usually flow from cartridge. If head cleaning and power cleaning does not work, then try to clean those pipes by using 96% alcohol fluids and **** the pipes using something.
Sep 12, 2009 | Epson Stylus Pro 4800 InkJet Printer
The printer "goes through the motions", i.e. the cartridges run back and forth and the page goes through but there is no printing.
check the ink nozzels it may got ink clogging.
use distel water and one serenze, take out ink tanks and inject the distel water by force, it may open ink nozzels.
then put back ink tanks and from driver do ink charging it will take 1-2 mins then use ur printer normally
Aug 20, 2009 | Canon BJ I6500 InkJet Printer
E-90 error message on Epson CX6000
If the error code E-90 appears on your Stylus CX control panel display, the print head may not be able to move back and forth freely.
  1. Turn off the Stylus CX.
  4. Close the scanner and turn the Stylus CX back on.
Also
  5. Close the scanner.
  6. Turn the Stylus CX back on.
Aug 07, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Hardware Error 0502
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Sep 20, 2008 | Dell A940 All-In-One InkJet Printer
Epson c60 printer
Common problem with Epson Printers.
Either the print head is clogged, or the tube that goes from the pump to the printhead fell off.
Open the printer cover so that the ink cartridges are in open view and then UNPLUG THE PRINTER" so that the ink cartridges wont go back to home position. (If there is a change INK cartridge button, then press that then uplug the printer when the cartridge stops moving.)
You can try to clean the print head by folding up a couple paper towels, then saturate it with windex with amonia. Place it under the print head assembly and manually move the print head assembly over the paper towel back and forth to clean the bottom of the print head assembly. You should start seeing ink on the paper towel.
After cleaning, run the cleaning program that Epson has, and try it out.
If it still doesn't work, then you might have to repeat this a couple more times.
If it still doesn't work, then it might be time to get a new printer.
Hope this info helps.
Good luck.
Mac
Feb 07, 2008 | Office Equipment & Supplies
Wants to print but won't put ink on paper
I'm experiencing the same problem. I tried to troubleshoot through software that came with printer, but no luck. Here's what happens:
The printer worked great for a month or so. Then, I didn't use it for a few months. When I tried to use it again, it acts like it's printing. My computer shows it's printing, the printer runs through all the steps, including moving the print cartridges back and forth over the paper as it should, but no ink comes out on paper.
Any suggestions?
Nov 05, 2007 | Lexmark X1270 All-In-One InkJet Printer
Canon PIXMA iP90 Mobile Printer Logo
146 people viewed this question
old marine
old marine
