Question about Acer AL1706b 17"LCD Monitor
Acer al1706 no video - Acer AL1706b 17"LCD Monitor
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 01, 2010
The screen is blinking too fast to do anything I am on another computer now how can I fix it?
inputs are wrong. use the proper cable. Set up your video to extend displays. Change resolution.
Mar 31, 2014 | Chief Manufacturing Chief Flat Panel Dual...
Acer lcd al1706 a monitor hooked to hp pavillion laptop and previously it worked great but i disconnected it to move and now reconnect and all plugs are fine and connected but monitor says "no...
You should try this monitor and the video cable with another PC to see if it works OK, or try this laptop with another monitor to see which one is not working, I have a feeling something has changed in the laptop setup.
Please post back what you find.
Jan 15, 2011 | Acer AL1706AB LCD Monitor
I have an acer AL1706 with a flashing power led.
First place to check will be the power supply section.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 10, 2010 | Acer AL1706AB LCD Monitor
I have an acer al1706 lcd monitor. it won't turn on. the power light is blinking every 5 seconds.
This is generally indicatve of bad capacitors in the circuits. Take it to a reputable repair person or check my website www.micromendllc.com
Feb 25, 2010 | Acer AL1706AB LCD Monitor
At start up the AL1706 monitor stays black and the green light blinks on and off. I have to restart four or five times before it eventually works
cyndommett, If not into repair work, and can afford trade for new, GET NEW ONE if current AL1706 is 4, 5, 6, years old. To understand your monitor's problem, spend an hour or two reading my and other lcd monitor tech's FIXYA profile's and testimonials. Then and only then will you have a handle on what options are at your disposal and the reason why your unit has FAILED. Bye for now. 12fixlouie
Feb 19, 2010 | Acer Computers & Internet
Acer al1706a driver
Just try here : http://www.bioticaindia.com/al1706.html .
If that didn't work , then get back to this website http://support.acer.com/drivers_download.aspx
and try the nearest numbers to your monitor series for example AL1702 or AL1703 or AL1711 .
that works in the most times believe me .
good luck
rate if that was useful please !
Jan 30, 2010 | Acer AL1706AB LCD Monitor
Acer al1706
hard drive is knackered
May 14, 2008 | Acer AL1706AB LCD Monitor
Acer AL1706b 17"LCD Monitor Logo
132 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
