1st timer. How can I Test this 4 pin fan from a desktop e-machine with a digital multimeter?
  • Eleazar Cruz Oct 09, 2010
    Thanks! drifter, After you answer I figured I could still use a three pin fan and it worked...
  • 4,924 Answers
Yellow is +12v, red is +5v, black is ground the other blue is the negative...
Posted on Oct 01, 2010
  • 1 more comment
  • Catalin Turcu
    Catalin Turcu Oct 01, 2010
    I forgot to mention ..to test it ..keep the negative ..and connect and verify the resistance in he other 2 positives..
  • Catalin Turcu
    keep in mind that the fans are different color coded that the power supply ..
  • Catalin Turcu
    I don't know the exact values..but if the connection is interrupted..will sow no resistance ...
    I usually test them with a power supply with the right voltage for each ..and see if they make any life signs..
How to install a digital timer model HD48S
HD48S is 8 or 11 pin timer.
Copy following link for illustrations
http://waterheatertimer.org/How-to-wire-pin-timers.html
Always test the pins with multimeter set to ohms to check which pins have continuity.
Usually with Pin timers, the Input terminals give power to the timer.
The other pins or terminals are dry, which means they have not power when input voltage is applied.
With dry terminals, you add a jumper wire from the input terminal to the Com terminals.
Jun 10, 2012 | Hardware & Accessories
I use Omron H3CR 8pin to my CCTV in my car. I use pin 2 for ground,pin 7 for ignition, pin 4&5 for direct current from battery and pin 8 to +ve CCTV. My problem is when I off the engine the timer is...
I don't have exact schematic for your 8-pin timer.
Use multimeter read ohms and voltage from pin socket to pin socket.
Use multimeter set to ohms to read continuity of pins on timer.
Pin timer relays have NO NC pins.
Some pins are Normally Open (no current flows until timer turns on)
The other pins are Normally Closed (current flows until timer turns on, and when timer turns on, this circuit turns off)
Apr 08, 2011 | Omron Healthcare Omron H3cr-a-ac100-240v...
Cant get the timer to power up, I know incoming power is on 2 and 7 .do i need to jump to other terminals?
RTE-p1ad is 24-volt AC 8-pin on-delay timer.
Manual for RTE-P1 & RTE-P2
http://www.idec.com/language/english/catalog/U908/G_Timers_RTE.pdf
I have not wired the P1 timer.
Manual shows for ON-delay, 24VAC input power goes to terminals 2 and 7
Using multimeter set to read ohms, check continuity between pins 7 and 8 to see if these pins are connected internally, or if you need jumper.
Also check continuity between pins 1 and 2 for same.
When power is applied to 2 and 7, the ON delay countdown begins.
When countdown ends, the switches are activated.
geno_3245_268.jpgSwitches are represented by angled line that connects to terminals 1 and 8. When countdown ends, the switch moves left and and completes circuit to other wire.
Using multimeter set to 24VAC, you can check each of the pins by putting power to 2 and 7 and checking which pins have power after countdown ends.
The NC normally closed terminals are 1 and 4, and 5 and 8, so it appears that these terminals are ON all the time until countdown ends and 'contacts transfer power.' Test the pins to be certain.
There are contact numbers for product:
USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC
Feb 02, 2011 | RTO Idec Rte-p1ad24 24vac/dv Electronic...
When my computer starts the power light will blink and the fan starts. When the computer first had problems it froze and the fan turned on and wouldnt stop. I also smelt a burnt rubber smell. I read to...
Yes the voltmeter measures the voltage.
When you power up the computer to test the voltage on the 4 wire connectors.
Test the voltage red and balck wire should read 5 volts.
Test the voltage yellow an black wire should read 12 volts
If the burning smell is from the power supply then most likely a capacitor has blown in the switch mode power supply.
I would advise you purchase a new power supply, do not try and repair it, these mains devices can be dangerous if you don't have knowledge.
Sep 14, 2010 | HP Pavilion a705w PC Desktop
Kelvinator mrs20hraw lights work fan and compresor does not rtc relay does not rattle and there is no digital read out on this model
The compressor relay would not have been the first item I would have checked. The cold control and the defrost timer control the on off cycles of the compressor and the fans. Cold control part #5303300027 est $60, Defrost timer part #215846602 est $35 - 60. The cold control switch can stick and not sense when it needs to turn the compressor back on. Turn the control to a colder setting and or lightly tap in the area of the control when you suspect a issue. Wait at lease 15 mins once you notice an issue. Second... find the defrost control and turn the actuator clockwise a couple of clicks. The unit could have been in a defrost and not advanced out. If none of these work and you have and can use a multimeter test the cold control contacts and Omh out the compressor cross each pin an deach pin to ground.
If all else fails...it might be best to call a tech.
Ric
Mar 09, 2010 | Refrigerators
CPU fan turns for a few seconds and stops, pc will not turn on. Have tried a good PSU, same issue. Removed all connection to motherboard apart from 20 pin, 4 pin power + cpu fan and PW switch: same issue.
1. First of all Remove dust from your CPU fan and try again if issue has been not resolve
2. Second test your SMPS by the help of Green & Red wire. In case fan is turning properly it mines your SMPS is ok
3. Third & last kindly replace your SMPS For the same.
Nov 19, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
Cannot turn on cpu
when you say cannot turn on cpu - what do you mean - ?
cannot boot up?
try removing the cmos battery for a minute then replace and try again.
any error beeps ?
working fine before ?
Oct 11, 2009 | E-Machines eMachines Desktop PC
Switched it off last night. this morning no power. won't switch on. not lead have tested. thanks
Verify whether the SMPS fan is working or not, working of this fan indicates that power output +12V is OK, if not you need to check the SMPS, probable reason SMPS fuse blown.
If you observe SMPS fan rotates for few seconds and then stops, this indicates minor repair is required, let me know the symptoms.
Oct 09, 2009 | Acer Power S290-EC3600P PC Desktop
No spin cycle
Probably a bad timer. Do you have a Multimeter? If so, I can walk you through the tests for a timer. If the timer is bad, it will not tell the machine to start the spin cycle. Let me know if you have Multimeter or Ohmmeter and I will post the test procedure.
Sep 26, 2009 | Roper RAS6233KQ Top Load Washer
Computers & Internet Logo
David Payne
David Payne
