Question about Sharper Image Ionic Breeze 3.0 Air Purifier
Just cleaned, it won't come on... lights, fan dosen't work?
  • 19,396 Answers
Hi.
Check if the power cord if fused, in case replace the fuse in power cord.
If there is no fuse, then the problem is a broken contact, caused probably by a damaged ozone barrier arching.
About your Ionic breeze purifier, I wanted to report that they are not being manufactured anymore because of heath concerns. New model built from 2008 use a completely different technology. Parts are also not distributed anymore, and the new Sharper Image does not provide any support for the old model.
I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
Posted on Sep 30, 2010
Unit stopped working
I have the same problem. Cleaned filters, lights were never on to indicate they needed to be cleaned but i cleaned them anyway. Tried resetting lights by holding 10 seconds and nothing.....
Aug 07, 2012 | Honeywell 50250-S True HEPA Air Purifier
Fresh air 2, blue light goes out, fan still works, reads
If the light goes out, it is time to replace the bulb AND the bulb starter. They need to be replaced every two years. Beyond that, they are an expensive night light. If you need to order one, call (336) 499-2505. Also ask for supplemental cleaning instructions since the original instructions are incomplete.
Jun 10, 2012 | Ecoquest Fresh Air Air Purifier
My fresh air 2.1 won't go into away mode. I
Fresh Air purifiers are noted for two weak points. The display circuit board and the main circuit board. Call (336) 499-2505 and they will help you work through the problem. They give away information.
May 25, 2012 | Ecoquest Air Purifiers
Perform cleaning on EcoQuest Fresh Air won't go away after pushing reset button
If you did not thoroughly clean the contacts for the ozone plate, the "Perform Cleaning" light will not reset.
May 05, 2012 | Ecoquest Fresh Air Air Purifier
Our Brookstone air purifier sounds like a bug zapper in spite of cleaning filter. It's less than a year old. What is the problem?
have you cleaned the connections where the filter connects . There is prob dust and dirt down inside the filter , keeping it from making a good connection. The zapping sound is from the electricty jumping the gap. A good cleaning of the inside should help. Try attaching a small hose to your vac to fit down inside the unit. give the electrical connections a good cleaning . If that dosen't work take unit apart and wipe down with alchol that you can buy at any drugstore
Aug 12, 2011 | Brookstone Pure-Ion UV Air Purifier
My sister gave me her Brookstone Pure ion Air purifier....The "clean filter" light flashes red....I wiped the filter with a damp cloth...so think it is clean...?....Is this how to clean it? ....and how do...
Wiping it off won't clean the filter. I submerse mine in hot soapy water ( oxiclean w/any favorite multipurpose liquid cleaner.Let it air dry completely before placing it back in unit.I have tried the dishwasher method and it didn't clean it.I also thoroughly wash all crevices of the unit.If red light doesn't go off, reclean the filter(s). It has all ways worked for me.
Sep 23, 2010 | Brookstone Pure-Ion UV Air Purifier
Fan is working but is not cleaning air. joedort13@centurytel.net
Open the back and change the Ozone plate. then slide out the ION plate and clean it with denatured alcohol. If no light inside, you may have to replace the bulb and / or starter. Hope that helps.
Mar 18, 2010 | Ecoquest Breeze AT Living Air Purifier
Ionic pro compact and ionic pro turbo
The clean light stays on and purifier doesn't work but unit is clean.
Jun 09, 2008 | Ionic Pro Air Purifiers
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
