Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Adjusting the wheel height
I cant seem to be able to adjust the height of the wheels can you please help me. thank you. its a model m2140 electric. mabey 10 or so years old.
how do i do this
jeff in pointe claire
  • Anonymous Mar 28, 2014
    How do you adjust the wheels on a 2550
    Champion:
  • 313 Answers
Its in the left side at the back end. a plastic orange color lever that you have to press up while pushing the mower up or down
Posted on May 29, 2008
I am trying to figure out how to adjust deck height
most mowers have a lever to raise and lower the deck . that is the height adjustment also then the wheels need adjusted to meet the ground . without a make listed we really can do no more
Sep 03, 2016 | Garden
How do I adjust the height of the front wheels?
U need a shopmanual. U may not have propr tools. Cud b a safety issue tu. A mechanic w experienc probly the way. Dont go to a dealer
Jun 04, 2015 | Briggs & Stratton Craftsman 42" 22hp...
How do I adjust front wheel height?
Are we talking tractors or mowers here? If its a mower we are talking about there should be adjusters on each wheel. Possibly three holes that you bolt the wheels on. Each wheel should be in the same hole as each other wheel.
Jun 04, 2015 | Garden
I have a John Deere LX178 lawn tractor and the mower deck will not raise/lower. It is all the way down and pushing in the button is how i've ALWAYS adjusted the height. It will not budge
1) NEVER adjust to where the deck wheels touch the ground. The wheels are to ride 1/4" off the ground. 2) The long lever to your left which raises & lowers the deck has 3 settings. 1- Fully back toward you which has the deck raised (called transport mode). 2- Halfway down which is the normal mowing mode (called float mode) 3- Fully away from you which sets the deck fully on the ground. This mode is ONLY used for VERY rough terrain where the deck risks getting pushed into "transport" or "full up" mode & getting stuck there. 3) On front-to-back tilt, the front should be 1/2inch lower than the back for least damage to the grass. Ok-now to adjust "cutting" height. 1) Park on a level, flat surface. 2) Pull the deck lever fully back toward you to put the deck into "transport" mode. 3) twist the "cutting" height knob (just below your seat) to the height you want the grass cut. Has choices by 1/2" increments from 1" to 3.5". The deck in "transport" mode is 4". 4) Lower the deck lever to the midway/"floating" mode point. 5) Adjust each deck wheel with its own peg & pin to have at least 1/4" clearance from ground. Thats it for "cutting height" adjustments
call your deere dealer,
Troubleshooting
Service Mower
cant find info for you,call dealer
Jun 03, 2015 | Garden
Front wheels on manual mower lock when pushing for awhile.
1 Locate the height adjustment lever on the inside of the left rear wheel.
2 Kneel next to the mower and push the left height adjustment lever toward the center of the mower. This will unlock the lever from the locking pin on which the height is currently set.
Read more: How do I Adjust the Height on a Great States Reel Mower? ' eHow.com http://www.ehow.com/how_6834215_do-great-states-reel-mower_.html#ixzz21NOr1e8d
3Rotate the lever toward the front of the mower to lower the height of cut, or toward the rear of the mower to raise the height of cut.
4 Release the lever over the locking pin closest to the desired height of cut.
5 Repeat these steps with the adjustment lever on the right-side rear wheel. Be sure to set the right wheel lever to the same position as the left-side wheel's lever for an even cut.
Jul 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I purchashed a used 26 54 husqvarna 2007 model rider and it will not cut low enough.My murray will scalp ground if i lower deck to ground.It looks like the blades are designed to be set higher off...
Low under the steering wheel there may be an adjusting knob. If it is there are you turn it, it should adjust the height of the deck. If you lower the deck and try to turn the knob it will be difficult to turn and you will know that is what it is for, the deck lower stop. Then pull up the deck and adjust a bit and lower the deck and see where it is, repeat until satisfied with the deck height when lowered.
Sep 20, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
How do I adjust depth
You can adjust the depth by adjusting the heights of the wheels and how far the lever drops the mower deck...
Adjusting the wheels higher will allow the deck to go lower...
heatman101
Apr 23, 2011 | Garden
Murray rider deck adjustment
place on flat level ground, remove floating wheels, open the flap on the deck height adjuster place handle all the way down, on the deck you will find a big plastic wing nut on each side loosen both of them, wiggle the deck and retighten them pull deck up replace floater wheels, close flap and use
Aug 20, 2010 | Garden
I need to know how to set the mowing height and do not have a manual
Almost all mowers' cutting height is adjusted by little "tabs" at each wheel. The tabs need to be pushed in to adjust.
May 03, 2010 | Black & Decker 19" Electric Lawnhog...
Electric clutch adjustment
.012" is the recommended air gap for the electric clutch. Use a feeler guage in the slots beside the nuts and check in circular pattern. Go at least 3 complete circles with your guage when adjusting.
Hope this helps,
Dolf-
Oct 14, 2009 | Garden
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
106 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
EugenesDIYDen
EugenesDIYDen
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
