Question about Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishwasher was put on this morning but still on at tea time --- water is cold any ideas steve
    President:
  • 2,501 Answers
The program is probably waiting for the temperature to reach the washing temperature.
I suspect that the heating element has failed.
Posted on Sep 30, 2010
How do you clean a metal coffee pot?
To clean your metal coffee pot you can pour boiling water into the pot and add a few drops of liquid dishwasher cleaner. Leave it to sit overnight and in the morning tip it out and rinse it out carefully before you use it.
Feb 25, 2013 | Home
Detox your body
drink 2ltrs of water a day eat healthy
Feb 15, 2012 | Health & Beauty
Couldnt find if this needs hot or cold water supply. Steve
The unit should be hooked up to the hot side of the supply. A lot of dishwashers have heaters, but using hot water saves them the time to heat the water to the prescribed temperature, around 140 degrees. The following website discusses this:
http://www.dslreports.com/forum/r18973777-Which-water-supply-for-dishwasher
A positive rating is appreciated if this answer helps you.
Jan 25, 2011 | Dishwashers
How to use mr coffee tea appliance
First clean the pitcher, lid, steeping basket and steeping basket before you use it the first time. Run a brewing cycle without any tea the first time and discard the water.
With the unit unplugged, fill the pitcher with water to the top water level mark on the pitcher and then pour the water into the reservoir. Do not overfill. Place the steeping basket and lid on top of the machine. Place a tray of ice cubes into the pitcher. Turn the steeping dial to open. Put the lid with the spout open on the pitcher and slide it, spout first, under the machine. Plug in the unit and turn it on. Wait until it turns off automatically.
For brewing, fill the pitcher with water to the line for the desired amount of tea. Pour this water into the reservoir (with the steeping basket and lid removed). Place a Mr Coffee filter into the steeping basket and add the desired amount of tea bags or loose tea. You can add sugar or lemon over the top of the tea if desired. Slide the steeping basket into the unit and put on the lid with the steeping dial set to closed. Fill the pitcher with ice to the desired ice level or with cold water to the same volume as poured into the reservoir. (If you are using water, put the pitcher in the refrigerator to chill.) Slide the pitcher with the lid on under the brewer and make sure the lid is open over the spout. Plug in and turn on the brewer. When the brewing cycle is done, it will turn off. Turn the steeping dial to open to drain the remaining tea from the steeping basket. (Let the remaining tea sit longer before opening the dial if you want stronger tea.)
You can get the manual from http://www.mrcoffee.com/Products.aspx?cid=43 . Click on the link for the TM3 (all the models in a series work the same way).
I hope this helps.
Jan 16, 2011 | Sunbeam Mr. Coffee Iced Tea Maker, TM3PS...
My 2007 chev express vans check engine light comes on and flashes 4 or 5 times about every mile for the first 10 miles in the morning then never comes on again until the van is cold the next morning. Any...
Take the vehicle to Auto zone to clear the computer. It may just quit doing that after the codes are clear. if the flashing continues the computer is at fault
Jan 14, 2010 | 2007 Chevrolet Express Passenger
TB3 Brewer is brewing weak tea - how do I adjust?
Hello. Yes, however, you would need to adjust the brewing cycle time to make up for the lost bypass water in order to get the same container level. In other words, the cold water part of the brew cycle is separate from the hot water part of the cycle, if you put in less cold water, and want to keep you container filling to its current level, you would need to increase the hot part of the brew cycle to make up for it, other wise it will brew less into your normal container. If you go to:
http://www.bunnomatic.com/
find your unit by model/type, you should be able to get a owners/installation manual, this will tell how to do it, or call the manufacture.
Hope that helps, and thank you.
Dec 22, 2008 | Bunn TB3Q, 29" Trunk, 3 Gallon Tea Brewer
How to
Fill the pitcher with water to the water level park on the pitcher and pour into water intake in the top of the tea brewer.
Fill pitcher to ice level mark (if there isn't one, put in about 2 - 3 trays).
Make sure that the brew basket lever is closed by pushing in then down.
Put 6 - 10 regular tea bags in brew basket and place brew basket on top of pitcher.
Slide the pitcher with the brew basket under the machine where the water comes out and make sure it is snug. Turn machine on.
When the machine is done brewing, the unit will shut off automatically.
Carefully slide the pitcher away from the machine and release the lever. This will let the tea pour into the pitcher.
That's it! Just don't put the pitcher, lid or brew basket in the dishwasher - that's how I ruined my first one.
Jan 24, 2008 | Mr. Coffee Iced Tea Maker TM1S
All my lights are on!
turn breaker off and on to see if it resets if not it could be your control board.
Dec 12, 2007 | Hotpoint 23 in. BFI68 Built-in Dishwasher
Hotpoint Aquarius Dishwasher DWF31
MY DISHWASHER TASTES OF SALT AFTER EVERY WASH .I HAVE RINSED IT THREW AND IT STILL THE SAME
Jan 03, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Tecnik 24 in. TKD795/3 Built-in Dishwasher Logo
74 people viewed this question
Top Tecnik Dishwashers Experts
Renee Knafel-Bullock
 Mikey
Mikey
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
