Question about Toshiba 43HX70 43" Rear Projection Television
Convergence problem? Hi, The words on the lower third of the screen are double one pink the other green. Do we have a problem with the convergence? If so what do we need to do? Any recommendations?
  • jbpeach Aug 04, 2008
    I have the same problem. The lower third and the top left hand corner. Does this sound like the same fix will work?
  • lbs031 Sep 10, 2008
    The lower third of my television is also showing double. How difficult would it be to change the convergence IC my self and do I need more than 1 to fix the problem?
  • Toshiba Master
  • 8,617 Answers
You need to replace both convergence ICs STK392-110 you can get replacement ICs at the following link and they provide free instalation instructions with pictures so you can do the job yourself. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 25, 2008
We just started having convergence problems with our WS65905. I performed the standard convergence adjustments and have the red/blue bars perfectly aligned. On the screen we have green and pink bleeding...
Yes, call local tv repairman to fix the issue because convergence output section got some problem like cold/ dry solder joints, devalued few resistors that can also cause of these symptoms and defective convergence output ICs are also one of bad convergence reasons in rear projection tv, all that happened because of heat and high amount of current drain in convergence circuit and its common problem of rear projection tv.
Visual check by experienced tech is necessary and repair would cost you around $250 to $350
Hope these info will help you.
Thanks.
Jul 25, 2010 | Televison & Video
Double picture & color problem
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
see if the mirror in side is broke or cracked
Pink and green with double writing
Are you able to do a multipoint convergence adjustment in the convergence menu? Do the red and blue adjustments move in all four directions/ Let me know and I will try to assist you.If the anser is no to either problem you will need new convergence ICs and convergence resistors.
Jan 08, 2009 | Philips 60P8341 60" Rear Projection...
Color seems to be pealing up from the bottom of screen
If the screen is bouncing...expanding/shrinking you need to get a repair kit from www.TvRepairKits.com
If your screen looks 3d in color, has a stationary bow, or if you can't adjust one or more colors from the "convergence" menu you need to buy a convergence repair kit. You can get one from the same site listed above.
Hope this Helps,
Nov 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
The words on the screen is doubled or trippled.
Go to the picture control menu and turn the color to minumum so that you are watching a black & white picture. Do this to determine if the color offset affects the overall screen or just the lower corner. If the center is off, go to the convergence adjustment menu and align the red and blue onto the green as described in the owners manual. Some models also allow you to align the outer edges as well. If the bottom is still bad you may have a problem in the convergence circuit. If the outlines are not seriously bowed or distorted a minor convergence toutchup by a qualified technician should correct the problem, otherwise parts are involved and the repair is considered major.
Nov 21, 2007 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 43HX70 43" Rear Projection Television Logo
95 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
