Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
F1 failure on model wtw6400sw - Whirlpool Cabrio WTW6600SBT Top Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you'll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 30, 2010
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I have a wtw6400sw and i'm getting the same f1 error code that alot of people are getting. even though its over 4 years old since it's a recall will whirlpool still fix it?
Hello & Welcome to FixYa
F1 error in your whirlpool cabrio indicates bad control and should be replaced to resolve the error code. However, you can contact Whirlpool as well prior to replacing the control yourself as I have seen whirlpool paying for the parts themselves just because this is known to be a common issue and yes even if its a 4 yrs old they have to fix it. Please get back to me if you have any other questions.
Kevin
Jul 31, 2011 | Whirlpool WTW6400SW Cabrio Washer
Wtw6200sw2 keeps giving F1 code when filling with water. Have to stop the washer and restart 6-7 times during wash load. Customer service tells me this part is not covered on this model only on other...
you will need a new machine motor controller part# W10189966 which is located in console
Three screws in back of console and head completely flips forward.
Jun 19, 2011 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool wtw6400sw0 washer-already replaced control module and user interface, still spins unbalanced, can I reset it somehow or calibrate it?
Please see the following Whirlpool installation and maintenance PDF on Cabrio washers. An F1 relates to a "primary control failure".
It also has a very extensive troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
May 04, 2011 | Whirlpool WTW6400SW Cabrio Washer
Cabrio washer F1 error
Hi
Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you?ll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 07, 2010 | Whirlpool WTW6400SW Top Load Washer
I keep getting an F1 code when my washer starts the fill up
Hi
Thanks for using FixYa. Error F1 indicates primary control failure and to resolve this you’ll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 05, 2010 | Whirlpool WTW6400SW Cabrio Washer
I have a cabrio purchased in dec of 2007.. model
Hi
Thanks for using FixYa. Yes you are right you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 05, 2010 | Whirlpool WTW6400SW Cabrio Washer
My Whirlpool Washer Cabrio model# WTW6200SW has a F1 error (fault) code? Does anyone know what this is and how to clear/reset the code?
Called 1-800-253-1301 was told by the Whirlpool agent that there was a quality issue associated with the F1 fault code. They would take care of parts and labor free of charge! My machine is 28 months old. Talked to a woman named Valerie.
Mar 18, 2009 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
109 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
