Question about Dell Inspiron 1300 Notebook
Deleting hard drive
I need help deleting hard drive
I have an error message of interactive logon process failed
  • 1 more comment
  • DianePedigo May 25, 2008
    turning on computer
    ineractive logon failed
  • nv_my_69gto Aug 02, 2008
    interactive logon error box pops up when windows restarts. screen is black except for pop up box with only two selctions. 1. use the x in the upper right corner or 2. use the ok button.
    when i do 1 or 2 it pops back up same window with same options; it also says check error logging in the box but i can not get past the interactive logone box to do anythng. it will not even let me bring up the window button lower bottom left hand side nor use the control alt delete to bring up task manager to see whats is or is not running. we were playing a dvd movie when all this problem started.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    you want to delete your hard disk? and that logon process, at what stage did that happen?
    Genius:
  • 3,587 Answers
I see..try the F8 option...that will take you to safe mode..
Posted on May 25, 2008
Why can't I get into my Asus K53U laptop?
This sometimes happens with Windows installations - your user profile gets deleted or corrupted and this error message results. If you aren't into heavy computer software fixes, I would take it to a computer-savy friend, or a computer service provider. Here is one set of instructions to try and remedy the problem. You receive The User Profile Service failed the logon error message
Sep 04, 2014 | ASUS Computers & Internet
Interactive logon process failed
I would attempt either trying to login as administrator, and if not then a Windows OS repair with the operating system disk. This should repair any of the OS files allowing you to login again.
Dec 29, 2013 | Computers & Internet
When i startd my laptop(dell Inspiron) i got error msg as "interactive logon initialization failed ". I tried to login in safe mode still i got same msg. when i run diagnostics utility, 0F00 131B...
You have to make a new account on the computer to resolve this issue (Or a fresh format/factory reset). If you are able to log in at all, make a new account and move your data. Otherwise, factory reset might be the easiest solution. You can recover your data by removing the hard drive and using an external hard drive to usb cable if you are not able to log in at all.
Jun 29, 2011 | Computers & Internet
When my computer loads and tries to go to the main screen a message pops up saying INTERACTIVE LOGON PROCESS INITIALIZATION FAILED . PLEASE CONSULT THE EVENT LOG FOR MORE DETAILS . But its In Front A Black...
This might work (no guarantees)
Bring up task manager Ctrl+Alt+Delete and click the applications tab
Click on "New Task"
type in explorer.exe and click okay.
If it boots up run malwarebytes available here www.malwarebytes.org
run full scan and delete anything it catches.
Good luck
Oct 24, 2010 | E-Machines eMachines Desktop PC
Trying to remove win32 trojan and inadvetently
If you have your windows cd you can boot from it and do a repair. You'll need to reapply any service packs.
Apr 22, 2010 | Dell Inspiron 1501 Notebook
Interactive logon process initialization has failed
Can you start on safe mode? If you can do that and go to C:\ and type dir/p and look for any file regardless of its extensions that created at the time you lost control, and keep note of it then logout and start again in safe mode by pushing F8 at the startup few times tell you bypass the window startup and click on safe mode…login as admin and uninstall the software then search for any file that was created on the same day that you had the issues with and delete them including the one in the recycle bin. Logout and restart again as admin from safe mode and try to login to the net and go to free scan website and scan your system. If that did not work you can try to restore to the last day that you can and that will not effect your folder that you need unless it is new and after the restore dat..let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Sep 20, 2009 | Dell Inspiron 530s Desktop Computer
Blue Screen c000021a
Next step is remove hard drive and see if it is recognized in another computer. The Hard Drive could just be bad, but you need to rule out the motherboard drive controllers that could also be bad. Also try a known good drive in your system.
Char S.
May 27, 2009 | Dell Vostro 1510 Laptop Computer PC...
My computer screen keeps going blank then a error message appears saying that logon process has failed to create the secuity options dialog
There are two soltions to this problem that i know of
More than likely this happens because you have a non-Vista compatible
security suite installed. Have you installed some kind of
firewall/antivirus/whatever suite? If so, which?
and the second path to follow which i have heard of is that your C Drives S.M.A.R.T Data has errors on it , the only way to fix it then is to buy a new Hard Drive and re-install Vista , then add your old hard drive as a slave and get the data that you want off it.
Apr 07, 2008 | Computers & Internet
Dell Inspiron 1300 Notebook Logo
73 people viewed this question
Alun Cox
