Question about True 49 cu. ft. / 1388 liter Commercial Freezer GDM-49F-RC
I have a true freezer m/# gdm-49f s/# 5140302 ... this unit is set at -17* it runs fine when it gets to the set point turn off of course by it doesn't come back on until it reaches 0* .... I like to know if that is normal? .. no product is damage
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 141 Answers
Well most t stats have a differential of 5 to 7 but almost never more than ten deg so that the compressor wont short cycle .something you can check .some t stats you can adjust the differential on check if yours has that adjustment screw on the side or back of T stat if you need more help or parts e mail me at airforceac@live.com
Posted on Oct 01, 2010
I have TRUE freezer model number GDM-49F. the compressor start but the evaporator fan wont start what culd be the problem
Could be a number of things. It has a thermistor that sits on the evaporator to keep the fan off until it gets cold. It also has a switch above the door that switches the fan on when the door's closed. It could be a loose connection in the wiring, or, lastly, it could be a seized fan
May 04, 2012 | True 49 cu. ft. / 1388 liter Commercial...
Product in my true gdm-49f freezer is frosting up and there is an ice build up around the inside of the case. what could be the causes of this.
Try defrosting the unit by shutting it down until all ice is gone. If this corrects the problem and the ice returns you may either have a defrosting problem or a low freon charge.
Jan 20, 2011 | True 49 cu. ft. / 1388 liter Commercial...
How much open space should I provide around my True freezer?
This unit pulls air in through the lower louvers in the front and pushes the air out through the back . It produces a lot of heat when running. 3 or 4 inches at the back should be sufficient if the air can escape over the top of the freezer.
Sep 23, 2010 | True 49 cu. ft. / 1388 liter Commercial...
True 49f goes into defrost mode the contact opens for the compressor but the compressor keeps running
in many cases, these units have relays or contactors where the contact points actually weld together. this causes the unit to stay running even though power to the coil has been stopped. I'd start looking there first. don't over look the possibility that someone could have mistakenly miswired the unit.
Aug 19, 2010 | True 49 cu. ft. / 1388 liter Commercial...
True upright freezer. coil fan not running.
Let it run. Coil temperature has to be low enough for the fan delay switch to close.
Jul 14, 2010 | True 49 cu. ft. / 1388 liter Commercial...
T-49F freezer cant get bellow 25
cap tube/ has unit been serviced before/ if you know it has correct charge compressor may have failed easy fix. expansion valve or cap tube maybe another thing to check i always remove entire charge get a good micron reading put exact charge back in if wont pull down comp. likelly
Jan 18, 2010 | True 49 cu. ft. / 1388 liter Commercial...
True freezer gdm 35f to cold
you just have to change the temperature control. I recommend using a white rodgers part no. 1609-105 set the cut out to about 33 cut in at 38 or 39 you might have to set defrost time to less minutes about 5 or 6 if coils dosent frezze with the setting i gave you. the bulb of the temperature control can be placed on the border dof the difusser.
Apr 14, 2008 | True 49 cu. ft. / 1388 liter Commercial...
Won't run
The first thing you need to check is if the contacts are getting power to the coil. A safety may be preventing the compressor from coming on. Read the wiring diagram. If the digital thermostat has a display, I would rule out the transformer. But I'm guessing at this point with what little info.
Feb 01, 2008 | True 49 cu. ft. / 1388 liter Commercial...
Your unit should have a defrost timer.The timer may be stuck in a defrost.It should be located at the bottom of the unit next to the compressor.Open the door to the timer and observe the position of the timer.If you turn the knob and the unit starts up,it's the timer. If this is the case, you can purchase a new one at any local a/c supply.Let me know,Mike
Dec 13, 2007 | True 49 cu. ft. / 1388 liter Commercial...
True 49 cu. ft. / 1388 liter Commercial Freezer GDM-49F-RC Logo
222 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
