Question about Sanyo Refrigerators
Punctured frion in freezer, now the refrigerator isn't getting cold.
    Genius:
  • 3,587 Answers
The freezer line is punctured? that's a fairly serious issue..you may want to call a professional service person..
Posted on May 25, 2008
Punctured freezer liner will fridge still work
NO, all the cold for the frig comes from the freezer. No separate cooling coil for the frig. You probably just killed your frig. I've never been able to repair a puncture line and recharge.
May 05, 2014 | Smeg FAB30 Top Freezer Refrigerator
Unfortunately the freezer side of the Whirlpool Fridge Ice & Water Filter Freezer has stopped working!
Look for the possibility that there is power on the refrigerator. The door gasket must be tight that cooled air isn't going outside. Check the temperature control, be sure it is in correct setting. Also the defrost timer setting, set it to the correct settings.
Be sure also that the freezer has no pinhole otherwise it is cause by a sharp object punctured the evaporator.
Thank you for asking.
Sep 01, 2011 | Refrigerators
I have a GE Model GSS22SGRF refrigerator. The freezer is cold but the freezer isn't staying cold. Any suggestions?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 23, 2011 | GE Refrigerators
Freezer works fridge does not
Needs to be completely thawed for 2 days. Or wlse the circulator fan under the freezer panel inside freezer is not working. Take the plastic bottom of freezer out and let thaw. Then plug in fridge and check if the fan is running inside there. Do not poke around inside there or fridge will be punctured and ruined.
Jan 28, 2011 | Roper RT14DKX Top Freezer Refrigerator
Chipping away ice in magic chef freezer section i punctured freon line in freezer panel can refridge still get cold
No, the fridge will not get cold any more. The coolant goes to the coils in the freezer. The fridge takes a small amount of cold air from the freezer to lower its temperature.
I am sorry to say that unless you can find a way to repair the puncture and refill the system with freon, you are going to have to buy another refrigerator.
Feb 05, 2010 | Magic Chef CTB1922 Top Freezer...
Punctured freezer
You should contact a local welding shop to fix the leak. The tubing is made from aluminum and can be hard to solder for someone who doesn't do it all the time. After that you need an appliance repairman to pit more freon in it. I guess the question is...how old is your freezer? More than 6 years old? Anything older than that, you may just want to get a new one.
Mar 20, 2008 | Sanyo SR-2410 Compact Refrigerator
Refrigerators Logo
152 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
