Question about Car Audio & Video
Bought second hand fusion enat112 subwoofer online and have problems wiring it up as the only cable with it was the remote control. or is it broken??
2 Suggested Answers
  • 18 Answers
SOURCE: replacement Kenwood KSC-WA82RC Car Subwoofer remote control wire
It looks like the S-video you need one end to be male and the other is female end.The high quality the S-video wire the better the sound.Make sure you get a long enough cord. Take it with you to radio shack or and car audio or home audio find the female end of the S-Video and it should plug in perfect.Wire it up and enjoy some tunes
Posted on Mar 03, 2009
New subwoofer
You will probably have to get the remote. You can search online as there are a number of vendors who sell replacement OEM remotes.
Dec 11, 2013 | Pioneer VSX-D498 Receiver
Not getting power when ignition is on and what is the rem imput for
the rem input (probably a blue wire) is what tells your amp to come on. the power supply is the red wire, that means that the amp is powered. it is not 'on' until the remote (rem) wire is powered. It acts like a power button or switch that is controlled by your unit. there are ways around conventional wiring if you have trouble getting your unit out.
Jan 29, 2011 | Fusion FEW12PK Car Subwoofer
I have brought and wired everything up but cannot seem to get the remote to work it keeps saying something about a blue wire but the blue wire that came with my package will not fit the remote
The blue remote lead hooks up to your stereo head unit in the dash...when you turn the radio on the remote lead becomes hot(+12V) to turn the amplifier on...without the remote lead the amplifier would stay on all the time and would then drain your battery...the blue lead is a turn on signal sent tot the amp
Jan 20, 2011 | Fusion FEW12PK Car Subwoofer
Need a weiring diagram
go to the manufactures website or go to a best buy or jo dies they can help
Jan 08, 2010 | Fusion FEW12PK Car Subwoofer
I have a fusion sub and amp and have no instructions on how to wire this can somone please help ive got green wires red wire and a small thin blue wire
Hello nicole_murra,
The green wires are for signal input to the included amp and should be connected to a pair of RCA preamp outputs on your head unit. The thin blue wire connects from "remote" on the amp to a switched 12V output on the head unit (usually blue or blue/white). The red wire is for power and goes through the fuse to positive battery. You also need to connect the amp terminal marked "ground" to the metallic chassis of your vehicle, within a distance of about 1/2 meter or less. There's usually a short piece of wire with black insulation included in most amp wiring kits. If your Fusion sub did not come with such a wire, you can use any wire that is the same gauge (or bigger) than the red power wire.
Hope this helps.
Sep 08, 2009 | Fusion FEW12PK Car Subwoofer
H ,ive brout a second hand fusion 10 inch sub,with built in amp .i have already tryed to c if its going to work ,all conectins are fine but no power is running to sub and amp i checked the fusez no...
Do you have the remote on from the head unit hooked up. If there is nothing to tell the amp to turn on it wont. You can bypass this to see if the thing works by using a jumper wire from the power wire to the remote on. I don't suggest leaving it like that though cause it will drain your battery over time. You need to hook the remote on to a power source that is only on when the radio is on. Like a power antenna wire.
Aug 14, 2009 | Car Audio & Video
Have no wires for a Fusion EN-AT110 Basstube!!!
The best place is to go to any store like halfords or maplin, or a lot cheaper if you wanna wait is ebay, many fusion amps/ active subs need special wiring !!!£80 from them direct only way, or you can go to maplin and get this product: A21GF (power supply extender 24pin) then cut off the three columns you need and the top and bottom of each are the respective 12v positive input remote and earth, cut the wires off half way and twist the top and bottom together, then add the twisted wires to your normal sub cables. make sure you use insulation tape around the naked wires for quality and stop it short curciting
Dec 09, 2008 | Fusion FEW12PK Car Subwoofer
Fusion Amp Starts In protected Mode
check remote wire coming from back of radio
Jan 08, 2008 | Fusion FEW12PK Car Subwoofer
I cant instsall the whole system, does anyone have any ideas??
bagman Fat Red wire from batter + to Fuse. Fat Red wire From Fuse to Amp +. Amp- Fat Black wire to body Ground. RCA cable run from Head unit RCA jacks down opposite side opf car from power wires. To Amp RCA inputs. Wire Speaker REd terminal to Plus on Amp. Balck Terminal to Minus on amp. Blue Wire is REmote, and wires to Blue on head Unit. Remote on Amp.
Oct 03, 2007 | Fusion FEW12PK Car Subwoofer
AMPLIFIER PROBS
check all power coming to your amp remote especially
Jan 21, 2007 | Fusion FEW12PK Car Subwoofer
Car Audio & Video Logo
161 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
