Question about Ovens
User instructions for a Samsung Primo microwave oven, model M6244
Shortly after end of 1 year warranty, KEMS378SSS04 began displaying F6E0 Lost Communication on lower over UI (not on the microwave). Turning power off/on (multiple times required sometimes) fixes the...
Below is the complete instruction sheet.
You are having a communication error between the appliance. Here is the actual tech manual instructions for that code:
PROCEDURE: Before proceeding, press OFF, OFF, START to enter Diagnostic
mode and verify the error codes. Ensure AM software, UI software and EEPROM
CHECKSUM versions appear on the lower text line. If AM software and EEPROM
versions do not appear, UI and AM may not be communicating. Verify this for the
lower oven UI and for the microwave (upper oven) UI. The lower oven UI will show
the AM software version for the lower oven appliance manager, and the microwave
UI will show the AM software and EEPROM versions for the microwave appliance
manager.
If the lower oven UI is not displaying the AM software version, go to UI IS NOT
DISPLAYING AM SOFTWARE VERSION.
If the upper oven UI is not displaying the AM software and EEPROM versions,
go to UPPER OVEN UI IS NOT DISPLAYING THE AM SOFTWARE AND
EEPROM VERSIONS.
If lower oven UI and microwave UI are both displaying an error, go to LOWER
OVEN UI AND MICROWAVE UI ARE BOTH DISPLAYING AN ERROR.
UI IS NOT DISPLAYING AM SOFTWARE VERSION:
A. Unplug oven or disconnect power.
B. Open the back panels and make sure the P6 and P2 connectors are fully
inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step F.
- If they are plugged in, go to step C.
C. Visually inspect all wires between P6 on the appliance manager and P2 on the
lower user interface.
- Make sure wires are not cut or pinched.
- If the wires appear to be intact, perform a continuity check between
P6-1 of the appliance manager and P2-1 of the user interface board.
Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to
P2-5(UI). All the measurements made should be less than 5 ?. If any of
these measurements exceeds 5 ?, go to step E.
D. Replace the appliance manager. Ensure all connectors are properly inserted.
E. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
F. Replace all parts and panels before operating.
G. Plug in oven or reconnect power.
H. Observe for longer than 1 minute to determine if error has been repaired.
I. If error does not appear, initiate a bake cycle. Let the cycle run for at least
1 minute.
- If no error occurs, cancel the cycle, the problem has been repaired.
- If error occurs again, restart the troubleshooting procedure at step A.
At step D, replace the lower oven user interface board if appliance
manager has already been replaced.
- If both are replaced the problem has been repaired.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 22, 2011 | Ovens
I just got an old microwave and don't now how to use it. Please is there a way to find a user manual? National Dimension3 Microwave/Convection oven
Try the Panasonic website below. National became Panasonic a number of years ago. I just went there and did a search for demension 3 under microwaves and it definitely has a few results for instruction manuals. You will need your model number (most likely on the back of the oven)
http://www.panasonic.com.au/Support/Customer+support/Downloads+and+documentation
Good luck :)
May 04, 2011 | Ovens
I need an User Manual for sanyo microware oven model: EM-G4775 Thanks
Hi and welcome to FixYa, I am Kelly.
You can download your manual here: (2.08 mb / 17 pages)
http://uk.sanyo.com/AssetBrowser/Technical%20Database/Instruction%20Manuals/Microwave%20Ovens/EM-G4775.pdf Rt click link then "save as" or you can open it in your browser and then save it.
I was able to successfully download the manual using the above link.
Thanks for choosing FixYa,
Kelly
Apr 05, 2011 | Ovens
Microwave light burnt out - need part # and instructions to replace
My friend whenyou want a technical help , you must first be specific. the brand of your microwave oven, model????? please, problem?????
Jun 10, 2010 | Whirlpool GMC305PD Electric Single Oven
I need user manual of kenwood microwave mw 320.
The manual for the requested model MW320 is here:
http://www.buyspares.co.uk/images/mediator/90/instructions-mw320.pdf
Feb 16, 2010 | Ovens
Need instructions on how to remove microwave to fix oven latch...
In the cabinet above the microwave there wil be 2 to 4 screws that have to be removed.
You need 2 people to remove this unit.
Feb 25, 2009 | KitchenAid Ovens
Ovens Logo
247 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
