Question about Canon PowerShot S2 IS Digital Camera
Cannon powerShot S2
When I turn my camera on it says to replace batteries, even when putting new batteries in the camera.  What should I do?
    Scholar:
  • 46 Answers
Unfortunately this issue is most commonly caused by an electrical failure with the camera's power unit. Sometimes a hard reset will work, though I'm not sure if permanently.
Usually the solution is to call Canon's tech support and have the unit sent in for service. To give the reset a try however turn your camera on and immediately press and hold the Menu button for approximately 7 or 8 seconds (until you get a Reset Camera message). If you can get this far, do the reset and then power down the camera.
Then remove the memory card, the batteries and the date/time battery unit (a small rectangular door located inside the main battery well). Once all batteries are removed, turn the camera's power switch into the on position. Wait two minutes then press the power button as if turning it off. Then replace all batteries and the memory card.
Turn the camera back on and immediately set the time and date.
Turn the camera off and on a few times and take a few shots if possible. This works in about 25% of the time. If it doesn't and you have confirmed that the battery itselef is good (by placing it in another unit typically) then the camera will typically have to be sent in for a service repair.
Hope this helps.
Sincerely,
HeavyDLB
Posted on Jun 01, 2008
    New Friend:
S20is definitive answer to battery problem
If you look closely, ONE of the strapping terminals on the battery compartment door is made of three separate parts. These tarnish with age and go high resistance. If you are VERY good with a soldering iron you can scrape the nickel coat and solder the three parts together without melting the plastic. The other contact is a single piece and is no problem. This was deliberately designed by Canon which is why they never offered a fix. My camera has been perfect for weeks now, unfortunately its technology is a bit dated.
Posted on Mar 17, 2014
My S2 IS shows "change Battery" even if new cells are inserted
replace the CR 1220 Circle battery located close to the AA Battery
Jun 28, 2010 | Canon PowerShot S2 IS Digital Camera
Canon Powershot S2 IS Digital Canera says to change the batteries even with new batteries in
Check that your battery terminals are clean and that none of them are loose. You may also need to change an internal battery, the one that saves the date & time.
Apr 10, 2010 | Canon PowerShot S2 IS Digital Camera
I have a Canon PowerShot S2IS that gives me a black screen and a "change batteries" message even with new batteries. Is there a way to re-set or re-boot the camera?
Try cleaning the battery compartment contacts with a cotton swab "dampened" in rubbing alcohol. Also clean the battery contacts and the charging station the same way. Thanks, Dana
Nov 22, 2009 | Canon PowerShot S2 IS Digital Camera
Camera says "change batteries" even with new batteries
Hi, Has anyone resolved this issue yet, I have a powershot s2 IS with the same issue - i replace the batteries with brand new duracell's and it says replace batteries i reseat the batteries and it works for a few pics if im lucky then says replace batteries again - any help would be appreciated - Canon offers no solution.
Oct 13, 2009 | Canon PowerShot A720 IS Digital Camera
My Canon S2 IS keeps saying 'change the battery' even if I put the new batteries in. Why...? Thanks.
there is a little coing battery located inside the battery compartment for the AA's. CR1220 you can get this at Radio Shack for about $5. If this battery is bad you will get the change batteries screen no matter how many fresh AA's you put in, Use a good quality alkaline battery such as the Energizer rechargable rated at 2700 mAh.
Jul 04, 2009 | Canon PowerShot S2 IS Digital Camera
I have a cannon powershot a 85 it was working fine then nothing i turn it on and it lights up the cannon sign then goes of. it is showing E18 in bottom legt hand corner. i have tried both rechargable and...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 22, 2009 | Canon PowerShot S2 IS Digital Camera
Cannon PowerShot S2 IS lens is stuck
I have the exact same problem, took it completely apart removed the zoom motor, physically turned the zoom gear and retracted the lens, reinstalled the motor, put it all back together, and found that I had the same problem and the lens wouldn't move out, so im pretty certain that the motor is bad, as the lens moves smoothly once the motor is not attached to it... looking for a replacement motor as i type...
May 29, 2009 | Canon PowerShot S2 IS Digital Camera
Cannon s1is turns off even with new batteeries
Try lithium batteries. Sometimes regular batteries even when new cannot run a digital camera.
Jan 09, 2009 | Canon PowerShot S1 IS Digital Camera
The screen turns black when I turn on my camera!? Cannon PowerShot 2IS
Make sure it's not plugged in to a computer or something, even if the plugin is only in the camera.
Dec 21, 2008 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
214 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
