Question about Sport & Outdoor - Others
Desa 5411A automatic outdoor floodlight does not turn off. Red flashing light above sensor.
  • matthewholle Sep 30, 2010
    solved the problem
    Brigadier General:
  • 3,917 Answers
When it won't turn off, try resetting it:-
1. Set RANGE control to MAX.
2. Set DUSK delay to LIGHT.
3. Set TIME DELAY to 0.1.
4. Set THIS UNIT switch to SENSOR.
5. Turn off power at circuit breaker panel. Wait 10 seconds.
6. Turn power back on at circuit breaker (the floodlights will turn on again).
7. Wait 1 minute, then walk in front of Motion Detector.
8. Ensure that Motion Detector does not see any movement for 10 seconds, lights should turn off.
9. Set RANGE, DUSK, and TIME DELAY controls as desired.
Please check the links related to your query hope it will be helpful:-
http://www.ehow.com/how_6401733_flood-lights-won_t-turn-off.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 30, 2010
ASTA09JEC Fujitsu model number operation light not on but time light (red/orange) flashing turns on then turns off automatically I have tried the reset button and turned the timer off on the remote
This is a serial signal error which means the outdoor unit is not talking to the indoor unit or vice versa. Most likely the outdoor board is stuffed but you need to count how many times the timer flashes to be absolutely sure which error it is. If you turn power off at the isolator for 5 mins then restart, this can sometimes clear an error caused by power supply fluctuations. If not, you will have to replace one of the boards. Indoor board allow around $200 - $250, outdoor board allow around $300 - $400.
May 09, 2015 | Fujitsu Heating & Cooling
Sh5412. The red lite blinks when walking past but the spot liters do not come on. The test was ok
What test did you do? Did the floodlights come on with the sensor switch in the Test position? Did you wait two minutes after turning the circuit on? Is the sensor in the dark? If your answer is yes to those questions, then try the following:
Double check the wiring. Sometimes a wire will come loose if the stranded wire from the fixture is wrapped all the way around a solid house wire. The solution is to gently bend the bare tip of the solid wire in a soft s shape so that the stranded wire does not completely wrap around the solid wire when the wire nut is twisted. (I know that you said the sensor red light is coming on but the additional load of the floodlights' current may not flow if there is a loose connection, very little current needs to flow to operate the sensor.) (The wires should be connected something like this -White from house to white for sensor (and to whites for lights unless this light connection is done internally in the sensor by Heath Zenith), Black from house to sensor, Other colored wire from sensor to lights (again unless this light connection is done internally in the sensor by Heath Zenith)- Also check that the spotlights are not burnt out and that they are tight in the sockets.
http://www.heath-zenith.com/servsup_instvideos.htm
Oct 22, 2014 | Heath Zenith Secure Home Motion Activated...
Flood Lights. 180 Degree Motion Activated Solar Powered Floodlight -
Sounds like the batteries are not getting charged. Check to see if there was some packing material in place to keep the batteries disconnected for shipping.
Dec 05, 2013 | Cooper Lighting Flood Lights. 180 Degree...
User manual for fl09sbk light
It appears this device is rate 10 amps at 230 volts = 2300 watts.
Use at least #14 wire and 15 amp breaker.
Connect wire at connection point on light.
Unit appears to have a transformer, and might make humming sound.
There is override located somewhere on unit. Possibly as a button on the motion sensor
If infrared motion detector requires separate wiring connection, then use following wiring illustration:
http://waterheatertimer.org/images/How-to-wire-motion-sensor-230V.jpg
Motion sensor will probably have 2 settings.
1st setting for sensitivity, so it will not activate when cat walks up driveway.
2nd setting for time duration, selectable from 30 seconds to 7 minutes
ML FL09SBK IP44 36W Fluorescent PIR Floodlight c/w Lamp
IP44 Low Energy Floodlight c/w PIR & Override.
Black finish.
T4 twist and lock lampholder.
36 Watt 6500k T4 spiral compact fluorescent lamp included.
(replacement lamp - product code FL09L).
Electrical termination via 10 Amp connector block within secure enclosure c/w cord grip.
PIR detection range of 12 meters at 2 meter height from ground.
Detection arch of 160 degrees.
Time range 30 seconds to 7 minutes.
Manual override.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 12, 2012 | Woods Outdoor Lighting Timer
Motion sensor light wiring
problem could be sensor, not light, black is power, white is neutral, green is ground, sensor may have a red wire, black wire and a white wire, hook black wire to power from sensor, red to black wire on light,
white wires will connect together, then wire black to power on home, white to white on home and green to ground, if you need help call an electrician and they will wire it for you
Feb 03, 2012 | Home
Outdoor floodlights burning out quickly
Cheap fixtures NOT likely the problem.
Many floodlights have limited life of the bulbs certainly 750 hours or less.
If these are on for 10 hours at night they should burn out after roughly 2.5 months.
You should probably test the voltage at the fixture since the life of incandescent bulbs is related to about the twelfth power of the applied voltage.
If the voltage is 5% high, the life will be reduced about 40%.
Apr 03, 2010 | Hammering
Have Cooper lighting outdoor motion detected flood
Sounds like the relay in motion sensor. Change the bulb. Rechargeable batteries are no good after 3-4 years also.
Jul 18, 2009 | Desa International 240 Deg. White Twin 150...
Sport & Outdoor - Others Logo
462 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
