Question about Dell Inspiron 1525 Laptop
Keys b,n,/,spacebar , arrows (directional) suddenly stopped working
  • Dell Expert
  • 393 Answers
Need to replace keyboard thanks
Posted on Sep 30, 2010
The far right and left ends of the spacebar do not work. In order to use the spacebar function, the direct middle of the button has to be pushed down.
You need to reposition (clip) the torssion bar under the spacebar key (a steel wire formed in a wide U shape), it is unhooked, call for a professionnal if you'r not sure how to do this as you may brake the plastic hinge if you don't know what you'r dooing...
Aug 09, 2011 | Toshiba 310CDT Keyboard
On my acer aspire one, how do i switch off the numbers on J K L U I O?. When i type i get only numbers on these keys and no letters.
I've done this to myself on my own Aspire One 10.1" netbook.
  1. Look at the last row of keys on your keyboard [The row your spacebar is on]
  2. Look to the left of the spacebar, you will see four keys labeled: [From left to right] "Ctrl" , "Fn", Window's Start symbol and "Alt"
  3. Now at the top right where the F1-F12 keys are located, you will see directly under the F11 key is the words "NumLk" that translates into Number Lock
  4. Press and hold the "Fn" key
  5. While holding the "Fn" press F11
  6. Now you should be able to use the letters
On a side note: All the blue symbols on your keys can only be activiated by holding the "Fn" key.
You can disable and enable many aspects of your notebook by using the Fn key.
[Many can be found on the F2-F8 key and the arrow keys]
Please just let me know if you need anymore help!
Dec 27, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have Dell inspirion 1525. Few keys of the keyboard have suddenly stopped working the keys are b,n,/,spacebar, Alt on right hand side and the arrow keys. I am using onscreen keyboard and have also...
There might be a hardware problem with your keyboard. You can run a quick diagnostics for the keyboard. You can access diagnostics by going to the advanced bood option.When you turn on the system as soon as you see the Dell logo keep tapping on F12, select diagnostics and pre boot system assessment will load. After running a quick diagnostics for the system it will give an option to select Custom test and select the test for keyboard . It will ask you to tap on the keys and if there's an error shows you have to replace the internal keyboard already.
Aug 09, 2010 | Dell Inspiron 1525 Notebook
Some keys not working
Keyboard no good. Just get a new one since you also have an intermittent situation that sooner or later will stop working permanently.
Sep 11, 2017 | Fujitsu LifeBook T4215 Tablet PC
IBM Wheelwriter 10 Series II Typewriter 6783. Spacebar suddenly does nothing. Everything else functions fine. Removed spacebar key and vacuumed dust underneath. When investigating possible problem we found...
you will need to replace the keyboard. we see this alot,keyboard starts to fall apart due to age. batteries are only used to hold tab and margin positions in memory. machine works fine without batteries.
Dec 15, 2009 | Televison & Video
Ok, my laptops keyboard is going weird
The keyboard is retiring. The keyboards are not terribly expensive. You can obtain one from your local agent and replace it or have it replaced by them
Jul 06, 2009 | Computers & Internet
The spacebar doesn't work consistantly unless ''pounded''
The spacebar is the most often used switch on your keyboard, so, yes, it's from overuse, but also from
the fact that it is the longest key on your keyboard and the closest to the edge, all of this combining to
make it the dirtiest key on the board.
So, get a keyboard cleaning kit, either professional or DIY which would consist of the following, cotton
swabs, compressed air, and maybe a toothbrush and realize that all the stuff that accumulates under
your keyboard's space key makes it harder to depress to the point where contact is made.
Apr 11, 2009 | Computers & Internet
Spacebar...not..working..
use a compressed air can to clean under keyboard.
Jan 11, 2009 | Packard Bell Easy One Silver 2120 Notebook
Need directions to store keystrokes in Xerox 610 Memorywriter
you can store phrases by -
1 - turn on the AUTO RETURN button above the keyboard
2 - hold down the button on either side of the spacebar, type a titile (any character from a - z)(SPECIAL ENTRY light will turn on)
3 - hit the +/= key (if you hear a beep, it means this title is already used. Press STOP and start over with another title.)
4 - type the phrase
5 - hold down the special key on either side of the spacebar and hit any key (a - z) to store the phrase (SPECIAL ENTRY light will turn off.
to re-call a phrase
1 - hold down the key by the s/b and type the title (SPECIAL ENTRY light turns on)
2 - press the SPACEBAR one time
Nov 12, 2008 | Olympia Mastertype 3 Typewriter
My-laptop's-spacebar-just-stopped-working-all-of-a-sudden-all-the-other-keys-work-fine.-any-ideas-or-suggestions?
hi it sounds like the laptop key board has a fault try going back in to your region settings and putting in your correct region place eg uk or usa or even restoring defalt setting this will be in your control pannel ok if this dose not fix your problem then you may need to take it to a pc shop for a new key board fitted .
hope this helps thanks and all the best
May 22, 2008 | Computers & Internet
Dell Inspiron 1525 Laptop Logo
198 people viewed this question
Alun Cox
