Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
Power head stops and starts
I have an Electrolux Oxygen model REL6988.  The power head stops and starts.  I stops when I pull towards me and will start again when pushing. I can't seem to get it to do it by holding the handle and the head and wiggling the tube between the two.  What do you think is the problem and how can I repair it?
Thanks Bruce
  • 1 more comment
  • Brucecop May 28, 2008
    I switched the two wands and this seems to have fixed the problem.  I think the issues is poor electrical contact in the wand connections.
  • DCGJ Sep 28, 2008
    I have exactly the same problem. It appears the connectors are loose when you pull the head towards you causing the power head to stop. It starts again when you push it away.
  • tlader
    tlader Oct 27, 2012
    SAME WITH MINE AND HAS BEEN DOING ALOT ONLY USED 15 times. THAT IS REDICULOUS !
    Problem Solver:
  • 8 Answers
The problem is with the connection between the flexible hose and the handle - there is a joint between the two that allows the flexible hose to rotate in the handle and the electrical connection here is not great!
If the head stops working you should rotate the flexible hose at this joint (i.e. where it joins the handle) and you will see that the head unit will start to work again.
Not sure what a long-term solution would be - probably to clean this connection, grease it again with white lithium grease, and perhaps to bend the spring connection here so that it makes a reliable connection again.
Posted on Nov 28, 2008
  • 328 Answers
Sounds like there is definately something stuck inside it. You;ll need to dismantle the floor head carefully using a screwdriver. Make sure your machine is switched off though if it is a power head and not an air turbine turbo head. Once inside check the main roller brush as well as the side caps as these can become clogged. Also check the main dirt channel leading to the pipes of the vacuum.
Dont forget to rate, thanks.
Posted on May 25, 2008
Intermitant fault in power head for electrolux z8420
could be a burnt out hose,turn machine on with PN then move the hose around and try to see where its stopping.If this is it you need a new hose.It could be many things but start there/
Dec 08, 2014 | Electrolux Vacuums
I have an Electolux Oxygen canister vacuum and the power head suddenly stopped working. It is only a few months old. Any suggestions.
1. You have to verify if it's simply the belt that has broken and the spinning brush isn't spinning because of it. Place your ear next to the top of the power head to listen for the power head motor. If electricity is getting to the head you'll hear the motor and know to inspect the belt.
2. If the motor doesn't run, look at the electrical pin connectioins in the pipe from the hose to the head. Are they burnt? If yes a new wand is needed. Also check the electrical connections in the hose handle and make sure they are not burnt.
Let me know if this helps
Oct 09, 2009 | Electrolux Oxygen Z5540 Pet Lover Vacuum
I havea -1year old Oxygen Vacuum and the powerhead just quit.
the vacuum you have is made by eureka (cheap)
the original electrolux today is called aerus
Jun 26, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
9 month old electrolux oxygen vacuum just quit
my electrolux oxygen canister just quit- i think it's the sumo board and the whole fuse problem why does this keep happening over and over (my 4th time w/ this model) and where can I buy a replacement sumo board myself?
Jun 19, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Power brush will only operate on push stroke
If the motor runs, the circuit breaker is working. If it only works on the push stroke, you probably have burnt contacts where the handle and/or wands and/or power head connect. When you push, the contacts are pressed together; when you pull, they are separated and the motor loses power. The only solution is to replace the connector parts.
May 06, 2009 | Vacuums
Powerhead Keeps Shutting Off
Open up the power head and check the toothed corners where the power head sits - it sounds like thread has caught up at the sides which can only be removed by opening up the powerhead to clean it.
Nov 14, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux oxygen vacuum
WARNING WARNING Danger danger Will Robinson! The power head "wand" and the hose from the body of the vacuum have shorts in them. While my wife was using this machine.. she started smelling plastic.. seeing whitish smoke and then sparks... The pin connector arc'd through the plastic... Some research on Google found that this has been a large problem for Electrolux, when i tried to call the factory.. robots.... no solution. Then I contacted a distributor and they informed me that it was not really that big of a problem. Only later to say, that they had replaced ALOT of them. My unit was past its warranty period so I just hardwired it. (now the unit is only two pieces, body and hose w/wand.)
Sep 01, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux oxygen plus 2100w telescopic tube is stuck. I wanted to extend it but the handle will not release and is stuck. Can you offer any suggestions?
I have a electrolux 2000 and my tube has a small tab that you push before it would let me release it. I had trouble getting it off as well. What I did was push the tab, Plasing one foot on the vaccume head holding it down while pulling up and twisting. I'm not sure if yours is attached the same way but this method worked for me. Good luck!
Aug 18, 2008 | Electrolux Vacuums
Power Head for Electrlux Oxygen Ultra
I work for Aerus Electrolux. My office # 570-326-1731 Call me and I will help you order the part. Liz
Feb 26, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
481 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
