Question about Alesis io 2 Portable 2-Channel 24-bit 48kHz USB Audio MIDI Interface
THE POWER LED HITS RED AND STAYS THERE AND THE ONLY OUTPUT THAT WORKS IS THE HEADPHONE BUT ITS SO LOW YOU CAN HARDLY HEAR IT
    Master:
  • 473 Answers
Issue with Voltage Regulator... also main board damage due to over heat... Check Regulator input and capacitor fail to innitiate to IC Chip... Unit seriouly damage dont plug anything On it you may damage the rest of your electronic equipment ...
Posted on Sep 30, 2010
I have an older home stereo system that i would like to connect to my vizio tv. I have a 3.5mm audio to rca plug. Coming out of the headphone jack on the tv, it plays no sound out of the system. Although...
I suspect what you're wanting to do is take the audio output from the TV and run it through your stereo system to leverage the large speakers. Correct?
I suggest using the RCA audio jacks (red and white pair) on the back of the TV. Most TV's still have these. Some are tied to a specific component, and some are general for all sound coming out of the TV. You connect this to the input RCA jacks on your stereo system.
The headphone jack on the TV could also work, but I suspect it may have a low level output. I don't understand how you say your MP3 player plays fine through the headphone jack, as that's an output, not an input. Unless there's some other jack?
Sep 22, 2013 | Vizio 29in Class LED 720p TV - LED TVs
Why wont kinivo bth220 wont link with my phone no matter what i try
Can you confirm if you are able to put the BTH220 headphones in pairing mode. Please try the following steps and see if works:
  1. Make sure that the headphones are fully charged.
  2. Switch off the headphones.
  3. Put the headphones in pairing mode by pressing the MFB button (center) for 7-10 secs till you see the red and blue LED blinking alternatively. Please do not leave the button as soon as blue LED appears.
  4. Follow the operating instruction of your Bluetooth device to start the pairing process.
Sep 29, 2012 | Kinivo Bth220 Bluetooth Stereo Headphone -...
Behringer europower pmp1000, mixer unit, has all leds lit ,is responding to mic. input, bur is not producing any ourput to speakers, can you advise please.
ALL LED's should NOT be lit all the time. If thsy are, there is a failure in the power supply.
plug headphones into the 1/4 inch main output jacks on the top... you will only hear sound in the left side headphone for each. This would verify the preamp is working.
Jun 25, 2011 | Behringer Europower Pmp1000 Powered Mixer...
I am attempting to use my sennheiser rs 110 headphones with my lcd-led tv. the componet jacks coming out of the transmitter are red and black. All my componets on the tv are red and white. so when i plug...
What are you plugging your 2 RCA connectors (from the headphones) into on the television?
You are correct, usually:
White = Left Red = Right
In this case
Black = Left Red = Right
Not sure....guess some manufacturers need to be different...
Back to the issue,
You to need to connect the Black to White and Red to Red to the TV BUT you need to make sure you are connecting to an OUTPUT and not to an INPUT on the TV. Most newer TV's do have an "audio out RCA jacks" on the TV but not all. It should be labeled at the connector if it is an output, or just another input. You can always consult the TV manual to be sure.
Few things you can do to test
  • Does your TV have a "headphone jack", use the adapter (2 RCA female - 3.5mm connector) to plug into the headphone jack and see if there is sound
  • Connect the Black and Red RCAs from the headphones directly to the another output, like a DVD player, CD Player etc....
I hope this helps,
Magoo
Mar 10, 2011 | Sennheiser RS 110 Consumer Headphones
A new DM7 drum set line out has very low output. It is connected with drum combo Stagg EDA40 and if combo drum inputs are used there is practically nothing to hear . With combo maximum volume there is...
The sound on all the stock kits I found to be too low. What I did was create a custom kit and altered the dynamics of all the pads and cymbals - once you're in the dynamics settings, just hit the pads/cymbals the hardest you normally would and save that setting!
Dec 29, 2010 | Alesis DM7 USB Electronic Drum Kit
No output power
It is likely the amps have been blown. Take for repair as further use may cause further damage.
Test the mixer by plugging headphones into the main L and R outputs. Note you will hear only one side of the headphone being these are mono outputs. The level will be low, but will check that the rest of the mixer is working.
ALSO please read my tip on here regarding a hazard of speaker polarity.
Oct 10, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Generac generator on auto runs weekly. light green previuosly green. now red. what causes this??
Hi and welcome to FixYa I am Kelly. Your red LED is telling you that it was 1. overloaded. 2. has low voltage 3. overheated or 4. short in the powered circuit.
OVERLOAD LED (red): Lights up if the generator experiences
a load greater than the rated output, low voltage, overheats or
the powered circuit experiences a short. The output is stopped
even though the engine keeps running.
I do not know which of the 4 conditions caused your red light. If you have the read light with no load I would suspect low voltage from the generator / inverter. If it overheated you will also get the Red LED with no load.
Thanks for choosing FixYa.
Kelly
Aug 30, 2010 | Kitchen Ranges
Ipod shuffle cannot hear music through headphones
Is it really a Head phone issue? lets find out that first.
If your headphones don't work as expected or not at all, connect the headphones to another audio source, such as your computer's speaker jack or another audio device that has a 3.5 mm stereo headphone jack, and test them. If your headphones are under warranty and still don't work, you can order replacement iPod headphones - Link - https://selfsolve.apple.com/GetWarranty.do;jsessionid=1B9ED1B556F0978A6C914A52711E59AA
And about the yellow and green LEDs
The yellow LED shows when the player is charging and a blinking green LED indicates you've paused the player.
At the back is another LED, the 'Battery Status' button, just below the toggle switch; when pressed, it flashes to give you a general idea of how much battery charge remains... green indicates a full charge... yellow, a low charge... red, very low charge... and no glow means its given up its ghost.
Hope this helps :-))
Dec 24, 2009 | Apple iPod shuffle MP3 Player
Leem m86t power mixer amplifier
probably blew the amps or the pre amp section
Sep 09, 2008 | Car Audio & Video
Alesis io 2 Portable 2-Channel 24-bit 48kHz USB Audio MIDI Interface Logo
122 people viewed this question
Top Alesis Televison & Video Experts
Are you an Alesis Televison and Video Expert? Answer questions, earn points and help others
