Question about Zenith ZN-501S Remote Control
Zenith LCD TV model #L15V26B will no longer accept signal from remote.Remote has been checked and is not faulty.
    Master:
  • 473 Answers
Check on the front panel of your TV look for Menu Setup and check for parental safety swich.. Possibility off.
Posted on Sep 30, 2010
Need some help!!! I have a Zenith 60" plasma tv(model#PDP60R30110, serial#109K460R3087562.ASLGBDD). The tv had a missing remote and wouldn't come on, unless you had a remote to unlock it, is w
If your Zenith TV remote is missing, you can obtain a replacement OEM remote by searching online for several vendors that offer them. OR, try purchasing an inexpensive universal remote and using it to control your TV.
Jan 28, 2015 | Zenith P60W26 60 in. HD-Ready Plasma...
Zenith tv, model #b27a11z. My remote stopped working with my tv. The remote lights up and the controls all work manually. I changed batteries, even got a universal remote with negative results. Its as...
Hi Keith,
First of all, thank you for posting your question here at Fixya.
My first advice is to confirm if the remote control is not the issue here and ensure that the fault came from the TV itself. Point directly your remote control's infrared emitter(Sensor) to your cellphone camera and then press any button key at the remote control, you will be able to see the flash of an infrared through your camera if the remote control is working fine. Watch the video below to have an idea how you gonna do this.
If you've confirmed that the remote control is not faulty, this is an indication that the problem is on the infrared receiver inside the TV. I would advice you to clean the TV's front panel infrared lens using a soft cloth, keep away all obstruction from the IR receiver, turn of the bright light in the room and check if the symptoms still persist. If yes, then the IR receiver inside the TV is already faulty and needs to replaced with a new one.
mjsazon
Jan 20, 2012 | Zenith A27A23W 27" TV
My will not work with the remote any longer. I replaced that. When I manually turn power on, it takes 3 or 4 times before coming on. Then, it will turn off after about 30 seconds. ANy ideas?
There is an infrared sensor inside the tv to receive infrared signals transmitted by the infrared signal generating light emittin diode fixed on your remote control. Either the sensor inside the tv or light emitting diode in the remote controller faulty, remote function will not work. For manual operation troubles, check the wall power socket of plug of the tv is faulty, loose contact etc.
Oct 13, 2010 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
I have a zenithZ remote control and i need to kni=ow if it will work on my rca television
if you have this zenith remote the ZN110. then yes it should work your RCA TV. but no one knows the codes or how to program it. so i suggest for you to try and get your original remote that goes with your tv. find the model number of your tv and go to www.replacementremotes.com and search for it. then they will bring up your original remote, if your original is no longer available then they will show you a compatible replacement.
Dec 30, 2008 | Zenith ZN110 Remote Control
Rest lamp timer zenith
Hold mute on the remote and enter on the front panel of the tv simultaneously for 5 seconds. Make sure the remote is getting signal to the TV. This works on newer model zenith and lg digital projections.
Dec 07, 2008 | Zenith D52WLCD 52" Rear Projection...
Zenith to
The key lock is a function that can only be reset with a remote. Go to www.zenith.com and under "support" you'll find product manuals. You can enter your model number and get the manual, but once "key lock" is on, you'll need a remote to change it.
Jul 08, 2008 | Zenith L13V36 13" Flat Panel LCD Monitor
Toshiba tv code for Zenith remote
Check the manual for your Zenith; many of the Zeniths (and many others) have a 'scan' mode you can call up, in which you can repeatedly press one key (^ for example), then the Power Button. That will force the remote to set every code it has available, step by step.
If you no longer have the manual, you may find it here or several other sites that offer these.
Apr 09, 2008 | Zenith MBR3447 Remote Control
Zenith Remote controller
It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code (www.xdiv.com) press Enter.
Jan 10, 2008 | Zenith HCS3000R Headend Controller For...
TIVO Remote
Your tv doesn't accept the code. The tivo remote uses the code that is programmed in it to control your tv. Go through settings and tell it you want to program your remote for your tv and follow the on screen instructions.
Oct 08, 2007 | Tivo DirectTV Remote Remote Control
Zenith ZN-501S Remote Control Logo
43 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
