Question about Ovens
Revent oven manual model # 1x1 135 - HSG 400
Temp shows 400 but oven is at 300
Is it continues to heat up then its working fine...if it continues to heat pass 400 then your have a thermostat problem and the oven is out of control. I do believe that the display is not an actual reading of the oven temperature, instead it is a reading of where the operator has set the temperature to . I have yet to see an oven with a actual reading temperature display.
Dec 01, 2013 | GE Profile JTP18 Electric Single Oven
When I turn the oven to 400 degrees for instance the temperature doesn't go to 400 degrees and the top element is hot, not super hot and doesn't get red. It is a Whirlpool Gols, Acubake system. Model...
Hi
Thanks for using FixYa. This indicates oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 14, 2010 | Whirlpool Ovens
Oven takes forever to preheat
check to see if both broil and bake elements/gas works
May 25, 2010 | Maytag CWG3100A Gas Single Oven
When self-cleaning my oven do I turn up the temp to 400.
No, the self-cleaning cycle is automatic, and will raise the heat in the oven to a very high temp (500°F-600°F) then cool the oven.
Here is your manual, see page 17 for cleaning instructions.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0309524.pdf
Feb 06, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Magic chef manual
You can download it here but you need the right model #.
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=MCF
As for the temp adjust it is best if you get an repair man out to do that.
Good Luck
Dec 18, 2008 | Magic Chef 9522 Electric Double Oven
Top oven has an error code (f2) It happen after a cleaning
F2 - Oven Temperature Too Hot - Depending upon model, replace relay (if present) or oven temperature sensor. Make sure to check sensor harness.
Dec 09, 2008 | Jenn-Air JJW8630C Expressions Collection...
Ovens Logo
523 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
