Question about Amcor A12000EH Portable Air Conditioner
Overflows, no power to pump when float switch is closed
    Master:
  • 473 Answers
Issue with Safety Swich Over Flow ...Check for fail connection make shure Tub is empty When your container is full of water the unit wil not power on till you empty the container ...Also check for filter on the back top of the unit it important the filter as to be clean because the unit will over heat then damage the pump inside
Posted on Sep 30, 2010
I have a non auto pump and want to use it with a float and also wire it so that the float can be bypassed by push button controller, hence manual operation any help please
You install two wires at the two terminals on the float switch to a switch so that when the switch is toggled the wires will act like the float switch has closed and make the pump operate.
Jan 21, 2015 | Zoeller 912-0073 Job Ready Simplex Sewage...
I have a AEG OKO Favorite 675 dish washer and if you start it or open the door it sounds as if it is just draining all the time, what can be wrong?
Hello Barbara, I have one of these dishwashers and this is what happens. There is a drip tray in the bottom of the machine that catches any leaked water. There is a float switch in the drip tray that detects water in the tray. If there is water in the tray, the float switch turns on the drain pump. This will immediately pump all of the water out of the machine and keep the pump running until you remove the water from the drip tray. The pump only pumps out the machine but does not pump from the drip tray. Also the pump will keep running even if the door is open or if the machine cycle is stopped. The only way to stop the pump is to turn off the electricity supply. But also turn off the water supply at the same time, because if the valve that feeds water into the machine is faulty, it will fill the machine till it overflows and if the power is off the float valve cannot turn on the drain pump. On this machine, the solenoid valve that let\'s water into the washer is at the end of the inlet pipe when is connects to the water supply. It is powered by line voltage (230 volts in our case). If this is faulty, it can be replaced with a commercial solenoid valve. The is a two core cable running inside the outer plastic pipe on the inlet pipe. This carries the power to the solenoid valve.
To empty the water from the drip tray, remove the panel from the front of the washer. It is below the front door and has two screws on each end. When you remove this you will see a hole on the left that is big enough to put your finger through and feel if there is water in the tray. If there is, push through a small plastic pipe and suck out the water. It does not take much water to switch on the float valve, maybe the door was not closed properly and some water leaked into the bottom of the unit.
I gained the above knowledge by bitter experience.
Dec 27, 2012 | Washing Machines
My d 3122 keeps filling, overflows and pumps out,... it trpis the flooded switch. Ive tested the filling solenoid and it works ok. I suspect the pressure switch....where is it and what does it look...
The float switch is located on the inside of the dishwaser. Under the bottom rack and it moves up and down make sure it goes up and down freely that should tell the water to stop pumping in when the float rises
Jun 21, 2011 | Asko 24 in. D3112 Free-Standing Dishwasher
How do I wire two telemecanique LC1DO910 contactors to operate periodically turning each other on and off. I am going use them to power water pumps, guided by float switches. All I need is how to wire the...
Interlocking. pump1. line 1 to auxiliary normally close contact of contactor #2 to holding coil of #1 contactor, line2 to float switch then to holding coil of #1 contactor.
Interlocking. pump2. line 1 to auxiliary normally close contact of contactor #1 to holding coil of #2 contactor, line2 to float switch then to holding coil of #2 contactor.
Nov 15, 2009 | Electrical Supplies
No power to the main water valve during cycle.
I'm no expert, but I recently had a fill valve replaced. There is a float switch at the bottom of most dishwashers. Its purpose is to cut power to the normally-closed electrically-opened fill valve in the event of an overfill. If the float switch "thinks" there is an over-fill situation, it will cut power to valve, closing it. I would start with replacing the float switch or checking to ensure that it is not stuck in the "up" position due to debris.
Again, I'm no expert.
Jan 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishlex dishwasher global 300. Dishwasher continues to drain with ECO light flashing. Service manual says it is due to an incorrect fill level or fill line.
Some diswashers have a sump in the bottom with a float switch. If the water level overflows the float will activate the switch which will kill the machine and run the drain pump continuously.
Jul 01, 2008 | Dishwashers
Indesit dishwasher overfilling
There are two ways that dishwashers generally fill. One is a float inside the tub, the second is a tube which fills with water, loops and goes to a pressure switch below the machine. That switch is usually about 1.5 inches in diameter, two wires and a small hose going to it. The float witch is found below the float in the motor area. With the float, sometimes they jam with too much old detergent or food goo. Clean out. Both can have the switch weld closed. Change the switch in either case. Since the unit is not filling with the power off, I'm going to guess the water solenoid is okay.
Dec 22, 2007 | Dishwashers
Amcor A12000EH Portable Air Conditioner Logo
71 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Bill Long
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
