Hp photosmart c7180 unable to send or recieve fax
    Master:
  • 473 Answers
Issue with Pre- initial ... Check Menu Setup... Check your USB Cable make shure it connect it on both side PC and Fax machine Or Re-install your driver and software for your Printer fax machine
Posted on Sep 30, 2010
.photosmart c6180 ink system has failed unable to copy recieve fax or printerror 0xc18a001
As always I start with the dreaded question. Did you use a refilled cartridge in your printer? If so, remove it and install a new HP cartridge. Recycled cartridges are famous for this type of failure. By the way the error code is a Windows error code. If you haven't found a solution to the " ink system failure " yet, it is quite easy to reset (using the buttons) on HP C7180. You can find the reset instructions on my website: http://www.inkbank.com.au/webcontent21.htm
Try this:
May 04, 2015 | HP Photosmart C6180 All-In-One InkJet...
Error: 0xc18a0106
replace the print head unit not the cartridge.
Jun 17, 2012 | HP Photosmart C7180 All-In-One InkJet...
We changed our telephone package last week, eliminating the dedicated fax line to one multi-ring line. The faxes aren't coming through now. Any suggestions?
You will have to set the Multi-ring pattern in the Printer Fax Setup to distinguish between the phone ring and fax ring
Press Setup button
Scroll to Advanced fax setup ( Press OK )
Choose Distinctive Ring Pattern ( DRP )
Set the multi-ring you have been assigned for Fax
Press OK -
Try dialing the no., the Fax should ring
Try sending Fax or Recieving, it should work.
Also, Turn off the ECM
under SETUP - FAX Settings - ECM ( Error correction mode ) - Turn it OFF
Jul 06, 2010 | HP Photosmart C7180 All-In-One InkJet...
Fax reception fails
Hello Dear,
The error message 242 appears in HP Photomart C7180, when the remote machine (the fax machine at Fax Sender side), is having problem, and it is trying to receive fax instead of sending. So actually both these machines try to receive the fax at the same time.
On many fax machines it is possible to accediently initiate the fax reception when:
1. The paper is not loaded in the machine
2. Or The paper is not correctly loaded.
You may contact the fax sender to check the above things. There is absolutely no problem with machine at your end.
Thanks
Mar 10, 2010 | HP Photosmart C7180 All-In-One InkJet...
C7180 can't send or receive fax? this worked a
press setup button. scroll to advanced fax setup. press ok. scroll to ecm press ok. select off. then press ok. then press cancell button to go back to main screen. now try to send and recieve fax.
Dec 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart C7180 won't print!! I had an IT person come to my home earlier today, and it was printing when she left. Not 20 minutes after she left, it wouldn't print for me!!! This is the second time...
It would seem that your default 'printer' is set to fax and not print.
When you select print from the file menu it probably says something like HP Photosmart C7180 Fax in the printer option. If it does, go into the printer section from the control panel and make the C7180 (without the fax reference) the default (right click>set as default)
Oct 15, 2009 | HP Photosmart C7180 All-In-One InkJet...
Cannot send fax
plz chek telephone line or fax roulers
Jul 01, 2009 | HP Photosmart C7180 All-In-One InkJet...
Unable to send or receive fax
Test the phone line with a regular phone.
Make sure you are plugged into the LINE port.
Jun 29, 2009 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart C7180 not scanning
I had this very same problem yesterday & solved it, after about 4 hours, with a clean install!!
Check my "solution" post at another question where I explained it in detail.
Jack
Dec 29, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP photosmart c7180 scanner failure
you can run a reset on the printer and clear the scanner failure yourself. You can find the instructions at: http://www.inkbank.com.au/webcontent21.htm
good luck...
L.C.
Apr 04, 2008 | HP Photosmart C7180 All-In-One InkJet...
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
