Question about Lexmark X5470 All-In-One InkJet Printer
Faxing unable to fax on my all in one set up. should I have a disc to do faxing
  • 23 Answers
This is a standalone fax machine. check if u hav connected the tel line frm the wall to the line port on the printer & then try to send a fax. In fax mode press the option button & then press the arrow till u see on hook dial & chk if u have a dial tone.
Posted on Jun 20, 2008
Xerox Phaser 3200MFP
you have to set the fax receive mode to fax or ans/Fax.
Is there a toner low indication?
try to reconnect telephone cable
Memory can be to full, clear some data
May 16, 2013 | Xerox Phaser 3200MFP/N Laser Printer
SAYS UNABLE TO CLEAN
"How do I clear the message Unable to..." ( "Unable to Change" "Unable to Clean" "Unable to Init" "Unable to Print" "Unable to Scan" )?
Step1: To clear the message follow the steps listed below:
1. Check for foreign objects, such as a paper clip or scrap of paper, inside the machine.Unplug the machine from the power outlet and open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
2.If the error continues to appear, the machine may have a mechanical problem.If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. Please make sure you have followed the instructions in the Step1.
3.If the error still continues to appear, move the print head and examine under the print head.
3-1.Disconnect the Brother machine from the poweroutlet.
3-2.Open the scanner cover by pulling up on the lower right corner of the cover.
3-3.Check the print head's position.
3-4.Gently move the print head to the center.
3-5.Examine under the print head. If anything is found, remove it.Use a flashlight if necessary to check thoroughly.
3-6.Close the cover and reconnect the machine to the power outlet.
If the message continues to appear on the LCD, the machine will require repair.
Step2: Check if the machine has faxes in its memory
1.Transfer the Fax Journal Report
1.Press Menu/Set or Menu on the Control Panel of the machine.
2.Press the up or down navigation key until Service appears on the LCD. Then press Menu/Set or Menu.
3.Press the up or down navigation key until Data Transfer appears on the LCD. Then press Menu/Set or Menu.
4.Press the up or down navigation key until Report Trans appears on the LCD. Then press Menu/Set or Menu.
5.The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Black(Mono) Start.
2.Verify and Transfer faxes in memory
4.Press the up or down navigation key until Fax Transfer appears on the LCD. Then press Menu/Set or Menu.
5.If there are no faxes saved in memory, NO DATA will appear on the LCD. Continue to Step 3. If faxes are present, the LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the faxes. Press Black(Mono) Start .
3.Reset the machine
After the Fax Journal Report and faxes in memory have been transferred to another fax machine, disconnect the Brother machine from the power source for several minutes and then reconnect it.
Feb 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
Unable to receive faxes on HP Photosmart Premium
Check the configuration set for incoming FAX and rectify the settings may resolve your problem.
Thank you for using Fixya.
Jul 22, 2010 | HP Photosmart Premium C309A All-In-One...
Able to send faxes but unable to receive faxes.
You probably have to set something up in your settings.
Usually this goes: Settings>Fax Setup>Receive
Of course, this is generic, and all Fax machines are different. Is there a model number?
Jan 15, 2010 | Compaq Office Equipment & Supplies
Everything works fine except receiving a fax.
Check the answer mode, you should easily be able to see it in the display when in idle mode.
The CD is not needed for the machine to perform actions not requiring a computer, e.g. sending/recieving faxes.
Also, check the phone cable connection so that it's connected to the LINE outlet, and not the EXT one. Connecting it to the wrong contact would still make the machine ring (as it detects the "call" on the line) but unable to lift the call since the modem communicates only through the LINE port.
You could troubleshoot by letting the machine be alone on the line to see if it can send and/or recieve faxes.
Jun 03, 2009 | Brother MFC 420CN All-In-One InkJet...
Hp4300 series disc won't work with my new hp window vista computer my printer is a 4315v
Please perform the steps given below and check if yuo are able to fax
1. Open a MS Word Document.
2. Click File -> Send to -> Recipient using a fax modem.
3. Follow the instructions given in the fax wizard. Ensure that you select the HP all-in-one as the fax program.
Now check whether you are able to send the fax.
OR
Try setting up the Fax once again
=== Fax Setup wizard ===
- Double-click on the HP Solution Center to open it.
- Go to Settings --> Fax Settings & Setup --> Fax Setup Wizard.
Complete the fax setup wizard and then, try to fax
Vishwanath V U
May 19, 2009 | HP Officejet 4315v All-In-One InkJet...
Fax problem
Check your preference settings and make sure the fax is set to receive faxes (my friends has 6 different settings) Your manual should tell you how to do this. The default is different for many fax machines.
Jan 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
Unable to init.
Error message Unable to Change Unable to Clean Unable to Init Unable to Print Unable to Scan Cause The MFC has a mechanical problem. ?OR? A foreign obstacle, such as a clip or ripped paper, is in the MFC. Solution Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in the memory 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. ?OR? If faxes are present, you can transfer them to another fax machine. Go to Step 3. ?OR? You can forward the faxes to your PC. Please see Transfer faxes to your PC. Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1 Transfer faxes to your PC You can move the faxes from your MFC?s memory to your PC. 1. Press Menu/Set, 2, 5, 1. 2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC. 3. To transfer all faxes to your PC, press 1. ?OR? To keep all faxes in the MFC?s memory, press 2. 4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. (For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
Sep 06, 2007 | Brother MFC-5840CN All-In-One InkJet...
IT will not print.
Error message Unable to Change Unable to Clean Unable to Init Unable to Print Unable to Scan Cause The MFC has a mechanical problem. OR A foreign obstacle, such as a clip or ripped paper, is in the MFC. Solution Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in the memory 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. OR If faxes are present, you can transfer them to another fax machine. Go to Step 3. OR You can forward the faxes to your PC. Please see Transfer faxes to your PC. Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1 Transfer faxes to your PC You can move the faxes from your MFC?s memory to your PC. 1. Press Menu/Set, 2, 5, 1. 2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC. 3. To transfer all faxes to your PC, press 1. OR To keep all faxes in the MFC?s memory, press 2. 4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. (For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
Sep 01, 2007 | Brother MFC-5840CN All-In-One InkJet...
Printer problem
MFC 5840cn - lcd shows 'unable to print see troubleshooting and routine'
Aug 20, 2007 | Brother MFC-5840CN All-In-One InkJet...
Lexmark X5470 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
