Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
X-Spa 300, winterized for 3 months, when turned back on: Day 1 - worked Day 2 - temp flashed 60, and water was cooling. I tried to turn up temp and jets came on, but when i removed finger from button temp dropped to 60 again. Day 3 - display reads "Sn", won't respond Day 4 - display is dead. Balboa LB70 board with MVP 240 display. I called company and they want me to replace LB70. LB70 was replaced 1 year ago!! I checked connections and everything is tight, board looks brand new (no burns), fuses all ok. Is there no way to test parts, or no serviceman who comes out to run diagnostics. I could replace LB70 for $200, MVP 240 for $200, and pump for $400, and it might STILL not be working. Mike, NJ
  • 2,382 Answers
Hi, you can try out any serviceman you know around you to run a quick diagnostic, but i know for sure they have their own service men that run diagnostics for them and if your display is dead as you said, i would have also recommended that you should change the LB70 because that is the only way to fix the dead display on it..
Posted on Sep 30, 2010
Jandy display flashes on and off
if it is flashing error code 1 while flashing you have a shorted temp sensor if no flashing 1 sounds like display board you can disconnect temp sensor 2 black wires that go into power control board disconnect with unit off then turn back on if no flashing it was the temp sensor
May 24, 2013 | Jandy Laars Lite2 Pool & Spa Heater -...
Panasonic 60" LCD Projection TV Turns off every 1-2 hours
What is the model# of your TV?
Do you see any blinking (LED) lights on the front of the TV?
How many blinks?
Which LED light is blinking, Power, timer or lamp?
Nour Sabre
www.aaatvservice.com
Nov 15, 2011 | Panasonic Televison & Video
Hi have problem with canadian spa (balboa mrspa1) control panel digital reading when turned on goes to OH,circulation pump will not run
OHS, OH, or SPA TEMP LMT Message There is an "Over Heated Spa" (OHS or OH) Water Condition.
One of the Water Temp Sensors has detected 110°F (43.3°C) Incoming Water Temp and Spa Functions are Disabled. System will Auto Reset when Water Temp is below 108°F (42.2°C). Check for Extended Pump Operation or High Ambient Temp, or contact your Dealer or Service Organization.
Spa Water Cool Down
• In order for the Spa Water Overheat Error Message to Automatically Reset and Clear, the Spa Water Must Cool to below 108°F (42.2°C).
• Check the Topside Panel Display to see if the "OHS", "OH", or "SPA TEMP LMT" Spa Water Overheat Error Message has Cleared. If the Error Message has Not Cleared, the Spa Water is still too Hot to Continue Testing.
• Either Wait for the Spa Water to Cool Below 108°F (42.2°C), or Exit Now and Retest at a Later time.
You can find answers to COMMON SPA MESSAGES at the following website:
COMMON SPA PANEL MESSAGES
Hope this helps.
Mar 30, 2011 | Balboa Instruments Duplex Digital Panel 2...
1998 Saturn Wagon 2 For the last few months my car cooling system seems to be running hotter than normal per the dash gauge. For years and even the the summer the temp gauge would never get over 1/4. I...
I would do a sniff at the tail pipe to make sure you are not pumping coolant out the exhaust pipe.
sound more like a bad gasket than a bad water pump to me.
Jan 27, 2011 | Saturn SW2 Cars & Trucks
My hurlcon mx series pool/spa heater stopped and displayed F2 fault. The operation manual action is" Allow water to cool,turn heater off then on again".Having tried this it did not fix it. Any...
Look at the pool water temperature readout. If this is a crazy figure say 60 to 120d deg C replace the thermistor line probe that senses water temp. its in the black water manifold.
Jan 23, 2011 | Pool & Spa
My dehumidifier runs, but no water is collecting. Humidity in the house is about 57%. The unit is only 3 months old.
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Jan 01, 2010 | Kenmore 5230 Dehumidifier
No water in Dehumidifier
1) low outside temp means low inside humidity
2) If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 20, 2009 | Dehumidifiers
Power vent 50 gal tank flashing code 2-3
1. Turn off power vent blower and set water heater temp to vacation (lowest temp)
2. Turn on power vent blower
3. Turn the water heater temp from vacation (lowest temp) to hot (highest temp) four times.
4. Set the water heater temp to normal
Aug 21, 2009 | Rheem Water Heaters
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
115 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
