Question about HP DeskJet 6450 Printer
Printer will not print. Tried turning off then on, tried unplugging.
  • hughestech Sep 30, 2010
    Do you mean Officejet J6450? There is no Deskjet 6450 model. Please clarify so I may provide you assistance with this issue.
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
Without more detail about what happens when you try to print, here's a generic solution that works for most problems.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02114788&cc=us&lc=en&dlc=en&product=357211&tmp_track_link=ot_search
Posted on Sep 30, 2010
Not communicating
try to clear printing queue in both printer and cpu. Also try a different cable.
Feb 14, 2015 | Lexmark X1155 X1155 All In One Inkjet...
Printer stopped working after I cancelled a print job
Turn off your printer and completely unplug the USB cable (from both the printer and the computer). Next check if the stopped document or the later documents are in the print spooler queue. If you can cancel all documents from the queue, do so. Otherwise: from Start Run (or the command prompt)
type: net stop spooler [enter]
then type: net start spooler [enter]
This works in XP and older MS Operating Systems but I've never tried it in Vista.
If you only enter the first command, you need to reboot the computer and then take a long coffee break after logging in before trying to print again.
May 06, 2009 | HP Deskjet D1455 InkJet Printer
Received the following message when I tried printing - "System Error. The printer failed to print due to a system error. Try printing again. If unsuccessful turn Windows off and reprint." Can you sugg
Turn it off and unplug it for about 30 seconds. Plug it back in, turn it on and try printing a Self-Test (Setup, 2, 5). If this works, try printing your document again.
Apr 14, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Paper keeps feeding through and won't stop
Two possibilities;
One you have a messed up print job trying to print and when you turn the printer on the job just starts over.
Two the clutch that stops the pick roller is bad and the roller just keeps turning.
Unplug the machine from the computer and turn it off unplug power for awhile turn it back on not connected to the computer. If condition remains it is the clutch.
If condition goes away delete print jobs and re connect printer.
Hope this helps
Mar 26, 2009 | HP LaserJet 1300 Printer
Brother MFC-8440 will not print or copy
YOU HAVE TO RESET.
TURN OFF THEN PRESS THE STOP /CLEAR BUTTOM THEN TURN ON KEEP PRESS ABOUT 10 SECOND THEN IT WORK .
Oct 15, 2008 | Brother MFC-8440 All-In-One Laser Printer
Lexmark 2500 won't print but no error message
Yes,I unplugged the printer for several hours.  I also tried another printer and it would do the same thing.  No error message but would not print.
Oct 13, 2008 | Lexmark All-in-One Printer with PictBridge
Printing status frozen and won't delete or print
Have you tried unpluging your printer from the computer as well as unpluging the printer from the electrical? If that doesn't work you should start from scratch... that is remove the printer from the computer memory, delete it, turn off the computer, turn on the computer and go through the installation process as if you just purchased the printer. Barring any mechanical problems as in jams or the such, the printer should return to operational status.
Oct 07, 2008 | HP DeskJet 5150 InkJet Printer
Printer
Check cable is secure from pc to printer
Check printer can print a status page via printer keypad and is online/ready
If these are ok then it is a print driver issue
Turn off printer, Unplug usb, delete and reinstall print driver
Jan 11, 2008 | Kyocera FS-C5030N Led Printer
Paper comes out with nothing on it
Possibly sounding silly here, (again) but have you removed the seal from the toner cartridge (This is a breakaway plastic tab, connected to a length on plastic, which seals the toner for transit)
If this has not been removed from the cartridge then it fails in just the way you are describing
Oct 15, 2007 | Canon imageCLASS MF6550 All-In-One Laser...
HP DeskJet 6450 Printer Logo
116 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
