Question about Belkin (F6C1500-TW-RK) (F6C1500TWRK) UPS System
Belkin ups not working properly.... green and RED light on ...indicates bad battery. But unit not more than 1 yr old, no battery time at all when plug pulled...not enen i min on (desk to an d monitor
UPS not working properly. Belkin 1500 (f6c1500-tw-rk). Red light on full time .. along with green. System has no 'on battery' time with minimal load...not even 1 min...not 10 secs. The batteries can not be that shot unless the charger was bad. Any suggestions? Had a similar problem with a APC and just replaced it. Any ideas??? Thanks -
  • dancour Sep 08, 2008
    Same problem here with new setup.
  • rmm2 Mar 13, 2009
    Same problem with a an F6C1100-UNV with brand new batteries measuring 26.5V. Charger puts out 27.2V, so I don't think it's a charging issue. Under no load, if I pull the plug, the unit beeps, the yellow inverting light comes on for half a second or so, then all lights turn off. All the while, the battery remains at >26.5V. There are two 12V batteries in this UPS.
    Sergeant:
    Champion:
  • 271 Answers
Your batteries are weak...(causes
1:-not powering the UPS for a longtime
2:- long use(3 to 4 years) )...you will have to replace them
PLEASE RATE ME.................
Posted on May 25, 2008
12v 7ah batteries have a 2-4 year life span.. most websites claim about 260 deep cycle dis/recharges although ymmv.
Make absolutely sure you've re-wired up the ups the way it should be (ie in series-- not parallel).they are in series, not parallel. ie, each cell produces 12 v so
wire the two so that the pair produces 24 v, the (-) terminal of the
first cell to the (-) connection in the unit, the (+) terminal of the
first cell to the (-) terminal of the second, and the (+) terminal of
the second cell to the (+) connection in the unit.
Or in other words:
+ of unit to + of top battery
- of unit to - of bottom battery
then connect + of bottom battery to - of top battery.. this completes a series circuit with both batteries.
Posted on May 17, 2010
Greetings Gurus. I have Makita charger model DC18RC, battery model is 18v BL1815...manual is of limited help. I'm trying to understand what the indicator lights mean, what the time is for charging,
I agree that the pictographs are not very helpful. You probably have one of the new chargers. I have an old one, which is a little easier to figure out.
From top to bottom
1. The flashing green light with the electric plug indicates that the unit is plugged in and ready to go.
2. The flashing red little fan means that the battery is too warm so it is just cooling it and not charging it at that moment.
3. The solid red empty battery outline means that it is charging but hasn't got very far, less than 80% full.
4. The mostly full battery outline with both solid red and green lights at the same time means it is 80% full or more
5. The full battery outline and solid green with the musical notes means it is full up.
6. The broken battery outline with flashing red and green means you've got a broken battery.
7. The yellow light with the wrench means the charger is "conditioning" the battery, whatever that means.
8. The yellow light with the fan means "cooling abnormality."
Hope this helps
Nov 01, 2014 | Drills
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
Replace the 2 bulbs. Unit powered up correctly and turned on like normal. Then Lamp1 and Lamp 2 indicator lights blinked (Indicating Start UP). After some period of time, it switched to Red 6 times blink...
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Ray.
Jun 05, 2011 | Sanyo PDG-DXT10L Projector
My question is related to an Invacare-Nutron R51.Production date 1-7-03,joystick[MKIV R11] flashes red 1 time, than green 5 times repeatedly? Can you please tell me what this means.?
Ranch well the red flash indicates a low battery and the 5 flashes indicate a bad left brake. Now try charging the batteries until you get a green light on your charger then turn on the chair it shouldn't flash the red if the batteries are accepting the charge. If your batteries are 2-3 years old it could be time to change them. If Medicare paid for your chair then they will pay most of the repair costs. You can contact your provider for help or a service company like Roadrunner Mobility @ 1-800-467-2668 or Repair Xpress @ 1-877-581-3733. If Medicare did buy the chair then you are eligible for a new chair every 5 years and yours is almost 8 years old. Contact a local provider that you trust to check into getting you a new chair. Hope this helps you
Sep 29, 2010 | Invacare Pronto M51 Power Wheelchair
I can't tell if the battery needs to be replaced in our Belkin 900. Should the green indicator on the front be completely lit up? Only one seems to be.
Link to manual:
http://cache-www.belkin.com/support/dl/f6c900.1100unv.pdf
Turn on your UPS by pressing and holding the On/Off/Test
button for approximately 2 seconds until the “ON LINE” Green LED
comes on. Pushing the On button less than 2 seconds is a test function.
Simple test: plug a light into one of the battery backup outlets. Then unplug unit. If the light stays on then it's working and the battery is ok.
Mar 02, 2010 | IBM Belkin Enterprise 900VA (31P7076) UPS...
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Belkin (F6C1500-TW-RK) (F6C1500TWRK) UPS System Logo
3,397 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
