Question about Dishwashers
Kenmore Ultra Wash Model 665 - 158* Front panel not working properly. Pressing Normal does not light that option. The only option that lights is "Quick Rinse", pressing this lights that option and also the "No Heat Dry" light. After a few seconds the lock light comes on. Looks to me that the "No Dry Heat" button is stuck on, which causes all the other things to happen Is there a way to fix this?
SOURCE: Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
My guess is that the foil that the buttons are mounted to is defective.  The control module "reads" the buttons that are pushed by the fact that the resistance between two pins on the circuitboard becomes zero ie. your pushing the button shorts out two pins.  the foil could have moistire damage or the resiistance of the tracks could be too high.  Solution for both would be to replace the control panel button foil.
Posted on Oct 17, 2007
SOURCE: Kenmore Ultra Wash Dishwasher - 665 - 13783
Posted on Feb 26, 2008
SOURCE: My kenmore ultra wash model
my model #665 dishwasher will not pump water into the unit
Posted on Jul 15, 2008
SOURCE: Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Posted on Jul 02, 2009
  • 523 Answers
SOURCE: Dishwasher will not operate. Kenmore 665
control panel
Posted on Jun 01, 2010
Kenmore Ultra wash mod.# 665-77963K703. normal wash light flashing. How do I reset.
How many times does it blink before pausing and repeating? 7 times? (That's a common problem - means "water not heating" error.) In some dishwashers, instead of pressing Heated Dry, Normal Wash, Heated Dry, Normal wash, you press the 3 left-most keys in the following order: 1, 2, 3, 1, 2, 3, 1, 2, 3. That will start the diagnostic cycle and clear the error, but if you don't find and fix the cause, the problem will come back the next time you run the DW. But before I try to explain how to fix the root cause, I would need to know how many times the light is blinking.
Jan 09, 2015 | Kenmore Dishwashers
Kenmore Ultra Wash Model 665.1388 problem the normal wash green light is on heated dry light is on and the start resume light is flashing but wont startup helpppp
see your instruction manual and go to the section troubleshooting and fix it.
if you do not have the i.manual download for free or
see the diagram
God bless you
Jun 18, 2012 | Kenmore Dishwashers
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore Dishwasher displays the number "98"
I have a very similar problem. When I push a wash selection, every light on the panel shows up...and when I push Start, nothing happens. When I push cancel, it trys to drain, even tho no water is in there any more. Have you ever had an answer to your problem?
Feb 06, 2008 | Kenmore 16872 Built-in Dishwasher
Normal wash flashing Red
We have the same problem with kenmore model 66513839k600
we press light wash and normal wash lights up, we have to wait over a month for sears to service. This will be the second control panel they will install on warranty, a month is far too long a wait for service on any appliance.
Dec 03, 2007 | Kenmore 24 in. 17039 Built-in Dishwasher
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
