Question about Panasonic DMR-E85H DVD Recorder
Self check i now have a new message after self check i also get TEST AV1
  • geoffrico May 25, 2008
    after iitialization of player to factory default i have downloaded the file as youj said but i cannot open it
  • 2,712 Answers
Is this after downloading the upgrade or after the initialization of player to factory default?
Posted on May 25, 2008
  • Swilin Sampson
    Swilin Sampson May 25, 2008
    You only need the *.frm file (I think its called PANA_DVD.FRM) to be burnt onto the disc and you *must* finalize the disk .
    It should be on a CD (I don't know if DVD will work), and the drive select on the DMR-E85 should be set to DVD and not HDD.
The printer continues in Self Test, the printer is stuck at this point as it tries to continue to cycle through the power up.
Try to power on the printer without the toner kit and the waste toner box. If the printer stacks again at self test. Next step.... remove one part at time and check if the printer displays any message. First remove the developer unit and power on the machine (normal message "Missing Developer Unit"). Then pull out the fuser unit and power on the machine (normal message "Close Rear Cover"). And finally, remove the Drum Unit and power on the printer (normal message "Call Service 7410").
If the printer still stacks at Self Test, then that is not a good sign. Try to upgrade the printer' s firmware (system + engine). There is a possibility to go further from Self Test.
If it does not, then you have to replace the main pwb.
Oct 28, 2014 | Kyocera Fs-3920dn Laser Printer
The message on the screen says primary Hard Disk
Every hard drive has in it a hardware test system - the one from yours has just announced you that your disk has died. Replace it and reinstall Windows.
Jul 22, 2010 | Computers & Internet
I have a new samsung blu-ray player... but manual does not list remote code to make the new remote compatible with my Sylvania TV... any ideas??
try connect to the tv AV1/2 scart connector, with a full scart cable (top quatily),and use tv AV1/2 cannel to test
Jan 02, 2010 | Samsung BD-P1590 Blu-Ray Player
Can't use timer setting to record Foxtel on LG RH397D
Are you trying to use video plus?try manual setting and in the channel space put av1
Sep 21, 2009 | Televison & Video
Printer is hungup on self test
920.08—POST (power on self test) error service check (Sub Code .08 (Exit sensor not connected.))
Check the Exit Sensor for Damage or dust.
Check DC auto-connects on both the fuser and the printer for damage.
If connector is damaged on fuser, replace fuser. If the cable connectors is damaged, replace the JFUSER1 cable.
Check resistance of the fuser, lamp, thermofuse, thermistor
Most Cases you will need to replace the Fuser.
Mar 17, 2009 | Office Equipment & Supplies
Wont start my odometer blinks and says no bus
From the official Durango shop manual......(abbreviated)
Self Diagnosis Test
Vehicle key position is OFF ,or able to pull key out.
Hold in the trip odometer button (dont release yet)
Turn key to the ON position (one notch), but DON'T try to start the engine
Continue holding the trip button for about 10-12 seconds until CHEC appears in the odometer display
Release the trip button.
Series of three digit numeric failure codes may appear.
If no failure message appears, the self diagnostic test will proceed as described in step 6
Code Chart
110- cluster CPU,RAM,EEPROm failure, replace cluster
900-CCD data bus not operational, check CCD data bus connections at cluster, check the cluster fuses,check the CCD data bus bias, cehck the CCD data bus voltage, check the CCD data bus terminations.
920-cluster is not recieving a vehicle speed message from the PCM, check PCM software level and reflash if required, use the ($2500+) DRBIII scan tool to verify the vehicle speed message is being sent by the PCM
921-the cluster is not recieveing a distance pulse message from PCM,check PCM software level and reflash if required, use the ($2500+) DRBIII scan tool to verify the distance pulse message is being sent by the PCM
940-the cluster is not recieving an airbag lamp-on message from the ACM, check the CCD data bus connections at the ACM, check the ACM fuse.
950-cluster not recieving an ABS lamp-on message from the CAB, check CCD data bus connections at the ACM, check the ACM fuse.
960- clsuter not recieving a PRND21 message from the TCM, check the CCD data bus connections at the TCM, check the TCM fuse.
999-An error has been discovered, record the failure message, depress the trip odometer reset button to continue the Self-Diagnostic Test
Step 6
Instrument cluster will test each segment of the odometer (all first, then each one seperately)
Step 7
Bulb test
Step 8
Gauge test
Step 9
test completed
The instrument cluster will return to normal operation at the completion of test, if ignition switch turned off, or a vehicle speed message indicating movement recieved from the PCM on the CCD data bus.
Hope that help you or anyone else in future.
Aug 10, 2008 | 2000 Dodge Durango
No sound from speakers
You probably popped a fuse in the unit..should be on the back of the amp.
you can play dvd through your telle,just run audio video cables OUT of dvd player,and IN to tv (av1),then turn telle to AV1,and wholla...
Dec 30, 2007 | Sony DAV-SA30 System
Panasonic DMR-E85H DVD Recorder Logo
163 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
