Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Nikon d40 fully damaged?
Hi!!
The Nikon d40 fell down fell down from my hand, on a hard floor. There were no signs of physical damage at all. But ever since this incident,
1) flash does not work - I get a 'tik' sound making me feel the camera is 'trying hard' to get the flash on, but doesnt work. There were no obvious signs of flash section damage. What all should I look in to to see if the damage is localized to flash only?
    Problem Solver:
  • 6 Answers
My standard response: Contact Nikon USA (if you're in the US) and ship them the camera and lens.This will cost, which they will estimate up-front, but it is the absolutely best solution to the problem. Anything else is a hack job!
Posted on Jun 06, 2008
My nikon AF-S NIKKOR 18-200 mm lens will retract from 200mm to 50mml. It won't fully retract. Help pleaseeee(:
This could be due to either dirt/dust/debris that is blocking the inner workings of the mechanism, or some physical damage to the unit from being dropped or overextended.
This article may be able to help you with a "do it yourself" solution.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
In the event that your problem is due to physical damage and not just dirt or debris, you will need to take it to a local camera repair shop for troubleshooting. Be prepared, this type of repair may not be inexpensive.
Mar 12, 2011 | Nikon Cameras
I have nikon d40 with 18-55 lens. when i press capture button there is a noise(i think inside the lens) and r07 displays in the viewfinder at right hand side corner. is that a problem or its normal?
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its stuck & you get that noise. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there is a system error. So please visit the service center for repair that. Its a very common & repairable problem. Thanks.
Apr 07, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
I am having nikon d40 with 18-55 lens. when i press the shutter button there a noise (might be in the lens) and r07 appears in the viewfinder at right hand corner. is that a problem or its normal?
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its stuck & you get the noise. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there is a system error. So please visit the service center for repair that. Its a very common & repairable problem. Thanks.
Camera wont turn on.
Hi there do not worry . It can be fixed. After fall down on the floor the lens guide pin is damaged or the power supply connection disconnect from the inside. That's why its not recognized the power supply. In both case the solution is visit service center they will fix it for you. Maximum charged is 40 - 70 USD. Thanks & waiting for your feedback.
Apr 01, 2010 | Kodak EASYSHARE M1063 Digital Camera
My nikon d40 dropped on concrete, but there was no physical damage. However, now it wont take pictures anymore and gives a *whirring* sound when i click on the picture snap button. Any advise???
You may not see damage but obviously bouncing off cement is not good for delicate camera electronics. Some serious damage has happened to your camera.
If under warranty send to manufacturer. You will likely have to pay for repair but waranty may cover some of it. As always weight the possible costs of repair with the purchase of another camera.
Jun 17, 2009 | Nikon D40x Digital Camera
I have just turned on my Nikon D40 and tried to take a picture, there is a crackling noise and a flashing question mark showing,can anyone help! as this has not happened before.
Are you using a official Nikon battery? Is there any unusual damage or debris in the battery compartment? It sounds like a fairly severe fault considering the crackling noises. I'd send it to a service centre.
Mar 28, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Flash not working
Hey influenza,
Nearly dropping the camera should not affect the operation of the flash unless the flash was extended and you caught the camera by the flash and it is somehow physically damaged. What is more likely is the camera is either set to a mode that doesn't allow the flash to operate, or the flash is set to auto off. Directions on how to turn the flash on or off start on page 34 of your camera manual. I have included a link to a PDF download of your camera manual in case you need it. I hope this helps!
http://www.nikonusa.com/pdf/manuals/noprint/D40_noprint.pdf
Sincerely,
Allan
Go Ahead. Use Us.
Jul 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Will not turn own it reads contact manufacturer for repair.
The hard drive became disconnected. I took out all of the screws to the outer case (5), gently slid cover down until the small ribbon connector for the power buttons is exposed, unclip and remove. Set aside back of unit (at this point the hard drive might come with it if the ribbon has come out of the back) at the top there is a two screw metal bracket that covers the ribbon connection for the hard drive. Remove the ribbon from the main unit and gently force it back into the hard drive ribbon connector. once fully seated you can reinsert the other end, replace the two screw bracket in a way that holds the ribbon down. Slide the backing back far enough to reinsert the power buttons ribbon connector and then test it before you throw in those last 5 screws.
Jun 06, 2008 | Toshiba gigabeat S MP3 Player
My Nikon d40 build in flash not working after fall
I have also had the problem of flash not working on my Nikon D40. I found out the problem and I made a quick video to help those who are having this problem. Here's the link to the video: Hope this helps !
Nikon Flash Fix
Oct 04, 2007 | Nikon D40x Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
135 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
