Question about Hotpoint HDA2000G Built-in Dishwasher
Push in by the handle dish washer run let go it stops
  • 4,340 Answers
This sounds like something came loose. Take it apart and inspect.
Posted on Sep 30, 2010
I have a loose door handle .what tools do I need and how do I repair it?
Hello;
My name is Peter. I am a retired field service appliance technician.
This is a difficult question to answer because you did not provide a model number. When you open the dish washer door you will see a metal label. Your model number is on this label.
Generally, manufactures use a special screw called a torque screw. The head of the screw looks like a star. It may be a different head screw.
Dish washer door handles are made of plastic. It is not uncommon for the handle housing, the handle or the retention spring to break.
On some dish washers you have to remove the inside door panel to access the handle assembly and on others there is a cover plate for the dishwasher control panel at the top of the inside of the door.
Before you attempt this task - do not go blind. Give me your model number.
Apr 03, 2015 | Dishwashers
Mdc4650awb stopped working
Is it running to a point or not turning on at all. If it runs to the point when it should pump out the water and stops, then it's not the boards or electrical. I have found with dish washers that they need a good cleaning every 6 months. Dismantle the rotating arms, take out the parts underneath and remove the filters all the way to where the water enters the pump. There's often grease and blockages here. The rotating arms also get stuff forced through them that clogs the outlet holes, so dishes don't get as clean. I've found orange seeds jammed in the outlet holes that then swell up with the extra water. Hair gets in and traps grease and all kinds of stuff. I've found the plastic wrappers from dishwashing "pods" clogging the filters. You'll find everything from toothpicks to bits of bone people leave on their plates
Sep 30, 2014 | Maytag 24" Tall Tub Portable Dishwasher -...
Why do no panel lights turn on when my Kenmore Model 587.1625 is latched and ready
The door latch in Kenmore and Kitchenaid isn't of the best design.The spring steel latching tab is needs to push down the black plastic slide mechanism when the door in closed. That slide pushes down on a micro switch which interrupts the cycle when you open the door when the dish washer is running. Take the latch assembly back out. You can insert two compression springs inside the slide on each side of the latch. They are approx 3/16 Dia x 3/4 to 1 inch long. In the hardware dept at Home Depot or Lowe's..The springs will push the slide down hard enough to activate the switch. Right now your dish washer thinks the door is open.
May 17, 2014 | Dishwashers
GE Dish Washer GSD 2800 DO3 runs a partial cycle...(even empty) and then beep and gives a message on control panel "washer arm blocked". Even ran without dish rack in washer still got the...
the rotating arm has a magnet in it to let the controls know if it is turning. Yours is not turning so
  • check the jets for blockages... you might have to remove the arm to clean them properly
  • make sure there in nothing stopping the arm from turning...spin the arm manually to see if it rotates freely.
  • knives etc sticking upward can stop the arms from rotating on the top rack
  • if you run without the rack the arm will obviously be not telling the electronic it is not blocked because it is not there. the rack must be in the machine with the magnet and the magnet passing correct messages.
  • If there is really no blockage then there is a elect fault that need to be sorted professionally.
  • PS have you taken the arm off anf squirted a hose up the inlet to see if water comes out all of the jets????
Mar 01, 2011 | Dishwashers
I have to replace the handle / latch assembly on a GE Monogram Dishwasher Model #ZBD6600G03SS. For the love of me I can't see how to do it. Do I have to get at it from inside, outside, both sides...
Hi
If the dishwasher door will not latch on your GE Monogram dishwasher and it is a new appliance, check that the door is not hitting screws or cabinets underneath the counter. For a new dishwasher, you might also need to push in the top of the control panel as you latch the door. The new gaskets might not have had time to seat properly. It may be necessary to run up to 10 dishwasher cycles for the heat from the washer to seat the gasket, which becomes more flexible after it is used a few times. For older Monogram dishwashers, check the loading rack to be sure no dishes are protruding beyond the back or front of the racks and that no dishes have fallen through to the lower rack. If dishes are dangling down into the lower rack, they could stop the lower rack from completely rolling into the dishwasher and could also stop the spray arm from rotating. Check that no silverware is obstructing the door.
http://www.acmehowto.com/howto/appliance/dishwasher/check/doorlatch.php
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Aug 03, 2010 | Dishwashers
Washer stops when handle released
unloader valve not functioning properly causes pressure overload and stalls engine
Sep 02, 2009 | Garden
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
Handle broke off the dish washer
The latch and handle are an assm on this dishwasher part is going to run you about $45 -$50.
Mar 18, 2009 | Frigidaire 24 in. FDB750RCC Stainless...
Dish washer that does not pump out the water on it"s final cycle
I had this same problem and after having the repairman over to our house several times and having the circuit board changed, I figured it out on my own...
It turns out that the pressure created from the steam during the water heating stage (HO) was pushing on the door latch just enough to prevent the motor from running properly. Because the door wasn't latched completely, the water wouldn't drain and the dishwasher would go to the "Drying" cycle without ever pumping the water out of the basin.
I adjusted the levelling on the DW and that helped, but I'm still not sure that the problem is fixed. We may need a new latch assembly.
To test this, when the DW stops running at any time, push on the door. If the motor kicks back on, this is the problem.
Dec 27, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Blinking lights
Next time this happens, try pushing in the door handle. If it starts up again, the computer thinks the door is ajar, and it won't run. You'll need the door latch assembly w/ door switches.
Mar 24, 2008 | Kenmore 15632 Built-in Dishwasher
Hotpoint HDA2000G Built-in Dishwasher Logo
55 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
